04-11-2022, 06:04 PM | #23 | |
Rep 1,791
04-11-2022, 06:49 PM | #24 |
Rep 1,716
Max what are the part numbers on those calipers?
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
04-12-2022, 05:48 AM | #25 | |
Rep 412
Max |
04-12-2022, 05:49 AM | #26 |
Rep 412
04-24-2022, 07:32 PM | #27 |
Rep 412
Completed a Mewant Chinese steering wheel cover today. The research I did in addition to Mewant states you can do this with the wheel attached; you’d have to have far more patience and flexibility than I do to do that.
Regardless, it turned out alright and I like the feel of it far better than the OEM leather that deteriorates and becomes greasy so quickly. I had a Coby recovered Alcantara wheel on my last F31 but I like this cover far better and was only $20. We’ll see how it holds up in the long term Max |
alexonahurry221.50 BMW BRAD204.00 |
11-15-2022, 08:29 AM | #28 |
Rep 412
Been a while since any updates. I've been driving the car a decent amount for work (32k miles in 10 months) and am due for some changes. First up is suspension; I went with KW Street Comfort coilovers purchased from ML Performance for far less than anything I've seen stateside. Total price shipped from the UK was ~$1400, customer service was fantastic as well. I was hesitant at first as I had no experience with them prior but would recommend them to anyone
https://www.mlperformance.co I purchased brand new front strut mounts and RSM's so that I didn't have to disassemble and reuse old mounts from my stock suspension. Install was a breeze and to those who haven't done F30 suspension before, follow FaRKle! method for the front struts. I did it the 'BMW way' on my last F31 and it was so much easier this time Waiting on tires to arrive, they should be installed this week. Brakes will also be installed this week or next, more updates to come! Max Last edited by clemsonf31; 11-19-2022 at 07:01 PM.. |
11-15-2022, 10:08 AM | #29 |
Rep 239
That's a steal on the KWs. I love mine but I do avoid any irregularities like raised patched asphalt as much as possible.
I've got a sister in Piedmont and been to Greenville a few times (shopping, eating, ballgame), what a nice city. |
11-15-2022, 10:56 AM | #30 | |
Rep 412
Concerning the KW's, I find them more compliant and comfortable thus far than the Eibach / Koni SA setup I had on my last F31, however we'll see if that changes with my new wheel/tire setup... Max |
11-19-2022, 06:59 PM | #31 |
Rep 412
Had a busy week with the F31
After KW’s installed, my new wheels and tires showed up: Apex ARC-8’s 19x9 et28 General GMAX AS-05’s 255/35/19 This is another tire size not recommended by Apex as it’s not very conservative. This is wheel set #3 that I’ve oversized outside of Apex recommendations and been fortunate enough to not have issues. Also able to install my brake setup from a 440i (referenced in post above). Included StopTech SS lines and a full system bleed. Overall happy with the setup, adjusting the rear coils has been difficult as the threaded sleeve spins with the collar. Will have alignment done on the car next week along with some better pictures. Max Last edited by clemsonf31; 11-27-2022 at 02:33 PM.. |
11-20-2022, 09:56 AM | #32 | |
Rep 78
Drives: 89 Zinno E30/ 18 BSM F31
11-20-2022, 10:45 AM | #33 | |
Rep 412
https://www.mlperformance.co/product...340i-435i-440i Max |
11-20-2022, 11:13 AM | #34 | |
Rep 666
most likely it's not price increase, but rather GBP is getting a bit stronger than USD since the last time you purchased.
right now GBP is about 1.2 USD, probably you bought it at 1.1 rate, about 10% cheaper, which is approx the same appreciation of GBP vs USD. Quote:
11-20-2022, 12:46 PM | #35 | ||
Rep 78
11-23-2022, 06:50 PM | #37 | |
Rep 239
11-23-2022, 10:31 PM | #38 | |
Rep 412
Are you planning to purchase the full M Performance brake setup? I know those dwarf the braking benefit/improvement of these ones Max |
11-23-2022, 11:29 PM | #39 | |
Rep 239
JDAURIA725.00 |
08-04-2023, 10:53 AM | #41 |
Rep 412
Been a while since I’ve updated. Been putting miles on the car for work, at 66,xxx miles now
Maintenance done at 55,xxx miles: -ZF trans pan and fluid replacement -NGK spark plug replacement -Meyle front camber arms, thrust arms and tie rod replacement Recently chopped off my rear muffler to replace with dual setup. Polished a used 440 muffler purchased from a local member in Atlanta. -OEM 340/440 rear muffler -OEM exhaust clamp -EBay rear diffuser Car sounds exactly how I’d like with the muffler replacement and coding exhaust flap to be open all the time. Not loud but a bit more sound than stock. I cannot recommend the diffuser, although it arrived in 2 days and was $50, you get what you pay for. Had to remove rear bumper to fit as clips wouldn’t engage otherwise. Additionally, the ends don’t actually engage at all, it’s too narrow. May replace with an OEM piece later, but this works for now. Max |
JDAURIA725.00 |
08-04-2023, 11:10 AM | #42 |
Rep 1,716
Nicely done. Ironically I did ZF transmission service and Spark plugs at same interval on mine. I've really been going back and forth on dual exhaust or single-sided. OEM 340/440 rear muffler just bolts straight up?
As for the diffuser, I've heard similar fitment issues. The MPerformance is pretty ridiculous in terms of price for ABS Plastic, but my hope is they go on sale at some point.
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 Last edited by JDAURIA; 08-04-2023 at 11:18 AM.. |
08-04-2023, 11:21 AM | #43 | |
Rep 412
Max |
08-04-2023, 11:25 AM | #44 |
Rep 1,716
Is the bumper removal necessary for OEM Diffuser / MPerformance?
