06-30-2013, 04:42 PM | #199 |
Rep 992
I need make some corrections. I figured out the big gain of rear wheel "spin" from stage 1 to stage 2 was mainly due to my rear tire change, which happened with stage 2 upgrade. So now I have to say the excitement gain between stage1 and 2 is not as much as stock and stage 1, even though I certainly felt the power/torque gain. To numerically verify the performance gain(i.e. 0-60), first I need to burn off these poor traction tires i got.
07-01-2013, 07:59 AM | #200 |
Rep 145
Update: I figured out why my FlexFuel install wasn't working at first, seems as though you need to make sure you fully twist and cap the spliced wires from the JB4/Stg2 wiring loom.
I'm running Map 2 with my mods (Magnaflow catback, AFE intake) and a 40/60 mix of E85 and 93 octane fuel. The N20 engine is a monster now; completely different beast than it was running the same mods with Stage 1 and 93 octane. I'm going to move up to a 50/50 mix of E85 and see what Map 7 brings. My hat goes off to Terry and the rest at BMS, I'm more than impressed with Stage2. |
07-02-2013, 05:10 PM | #201 | |
Lurker turned Poster
Rep 51
Past:
'11 M3 Comp. Package '12 528i Current: '13 328i MSport |
07-04-2013, 07:44 PM | #202 |
Rep 66
I'm running BMS stage 2 on my n20, can someone post some pictures of the various jb4 interface screens with the correct settings so I can check I have everything as per what it should be.
Thanks |
07-05-2013, 08:17 AM | #203 | ||
Rep 145
07-05-2013, 08:21 AM | #204 | |
Rep 145
Also, I just found out that there is an updated interface download from BMS as well. Haven't installed it yet but just FYI you can get the updated interface from this thread: http://www.n54tech.com/forums/showthread.php?t=17441 . |
07-05-2013, 08:42 AM | #205 | |
Rep 145
One thing that I worked through in moving up to 50/50 E85 and Map7 is that right after I made the switch, I encountered a fairly consistent 'misfire' issue on 3/4-WOT in which the engine would completely bog down, almost as if I hit a rev limiter. No CEL or codes would result and as soon as I let off and eased back into the throttle, the engine would return to operating without issue. I am running the FlexFuel wires and had set the openloopfuel setting to 60 in the JB4 interface. However, after doing a bit of forum research I believe I discovered that we should also be setting the futureuseB setting to 2. After doing that and bumping the openloopfuel setting to 75 (remember to let the car adapt too), the misfire issue is completely resolved and the engine pulls and pulls and pulls. |
07-07-2013, 06:07 AM | #206 | ||
Rep 66
Secondly is it normal for the car to be very rough on cold starts? I have found a couple of times it will start and then struggle and then turn off. When warm I don't have such a problem |
08-07-2013, 07:12 PM | #207 |
Rep 1,436
Guys I just Installed S2 on 528i F10 incase you were wondering if it's compatible because I contact John@bms but he said he didn't have any customer yet (guess I'm the first ) so I had to take the risk but you have to know you'll need longer wires for green and brown wires so you can tuck the module beside the brake booster.
08-07-2013, 07:17 PM | #208 | |
Rep 623
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara |
08-07-2013, 07:27 PM | #209 |
Rep 688
All this talk about running E85 mixtures...why doesn't anyone run 100% E85? Can anyone speak to the downsides (re: issues with the fuel system, codes) of running straight E85 with a JB4 Stage 2? It would be more convenient that to worry about mixing every time.
If this has been discussed, spare me...I'm not going to comb through every single post in the thread. |
08-07-2013, 07:39 PM | #210 |
Rep 1,436
08-07-2013, 07:43 PM | #211 |
Rep 623
After a lot of reading it seems like when the initial enthusiasm fades away, the gains are not really anything to boast about. I've never seen a before and after Dyno from your average owner (not a brand enthusiast), on average octane (91).
08-07-2013, 07:56 PM | #212 |
Rep 1,436
I live in Egypt, I use RON92, we don't have dyno here and besides I do this myself normally enthusiast here go to someone to install any bolts in the car lol I wish I can dyno my car to know how much hp under that hood.. even if there slight difference still I'm proud to take that risk.
08-17-2013, 09:22 AM | #213 |
Rep 1,436
08-18-2013, 01:59 AM | #214 | |
Life in Oversteer
Rep 20
08-19-2013, 02:09 PM | #215 | |
Rep 9
How do you change maps on the steering wheel
just had the stage 2 installed. I have the N26 engine. |
08-19-2013, 04:10 PM | #216 | |
Zooombie attaaack!!
136
Rep 1,179
Hold Volume (-) for 5 seconds, then press either (+) for map 1 or (-) for map 0. The full control from the steering wheel should be added soon. DL the JB4 comp interface from here http://www.n54tech.com/forums/showthread.php?t=15536 |
08-19-2013, 08:19 PM | #217 | |
Rep 9
08-23-2013, 09:17 AM | #218 |
Rep 115,955
Just a reminder that both the stage2 full tune and stage2 upgrade are available @ www.n54tuning.com
Mike |
08-28-2013, 08:09 PM | #219 | |
Rep 23
what code did it read? I have Icom diagnosis I can help. I recently bought stag2 upgrade, but didnt install yet. Do you have navigation CD's for the 5series, I need to try to install them. |
08-29-2013, 06:08 AM | #220 | |
Rep 1,436
No, I don't know about the navigation CD although I did coding for my car and my dad's F10 and I contact someone who's responsible for maps and he said there are no maps for Egypt but that was 3 months ago, I'm waiting for the LCI to make any changes. http://www.f30post.com/forums/showthread.php?t=853049 Last edited by rustyminded; 09-13-2013 at 02:59 AM.. |
