05-10-2010, 03:54 PM | #1 |
Rep 81
Low Back Pain
I have recently experienced low back pain. I have gotten a MRI and it was diagnosed as a Herniated Disc (L3-L5).
Can anybody provide methods to cure the issue as well as techniques to provide some relief as the disc heals. The pain is absolutely terrible. Somebody please help. Thanks. |
05-10-2010, 03:57 PM | #2 |
Rep 10,309
Drives: A///MERICAN!!!
My dad had this, had to get surgery. The procedure has become much more streamlined since his (1990s), and I think can unobtrusively be performed with maybe an overnight in patient.
05-10-2010, 04:03 PM | #3 |
Rep 1,288
I feel for you bro... back pain is some of the absolute worst. I've got L5-S1 issues which means I can't even walk when its bad.
I only know what helps me, but here goes. Lay on your back on the floor/bed with legs straight. Take your right foot and and bring it up with your ankle even with your left knee (your right knee should be straight up, not out to the side). Take your left arm and grab your right knee and stretch it over your left leg like you were stretching your glutes, etc. This will hurt, but in a good way. (opposite for opposite side) Another trick that helps me is when I'm laying down stuff a shit ton of pillows under both legs to your legs basically look like you are sitting (even though you are laying down). This takes a lot of pressure off of the spine and makes pain tollerable'ish. Good luck.. hopefully it goes away in a week or so... time is the best healer for this type of thing. But when you feel like you can get up and around, force yourself to do so... even though it hurts, it'll help you heal. |
05-10-2010, 04:05 PM | #4 |
One cam is enough
130
Rep 6,801
Well, depending on how bad it is, they can surgically replace a disc. I'm not sure if it's an approved procedure yet, but there was an outpatient surgery in the making where they would insert a certain gauge "wire" in there or something like that, instead of fusing the vertebrae together.
I've got a whole bunch of those (herniated discs) in all three sections of my spine, but none are intruding too badly into my spine or the nerve branches (sorry, forgot what they're called). I've been assigned to intense physical therapy to try to restrengthen my back to encourage better support and posture. You're better off consulting with a doctor to determine what's best for your scenario. Herniated discs aren't known to "heal" too well, and the action that needs to be taken depends greatly on exactly what your specific situation is. |
05-10-2010, 04:09 PM | #5 |
Long Time Admirer, First Time Owner
17939
Rep 9,377
cannibis club, here you come!
DieselOG1673.50 The Chaddening11585.00 |
05-10-2010, 04:12 PM | #6 |
Rep 81
Well I have seen the doctor a few times. I have done Physical Therapy, Strectching, Pilates, Spinal Epidural Injections, Chiropractor, Inversion...etc...BUT not surgury.
I found the best method is simply to ICE the back and rest. Taking pain meds does help but obviously its only temporary and not healthy at all to just pop pills. But at the worst times, I can't even walk. Its just so terrible. It seriously just ruins your life during the painful moments. |
05-10-2010, 04:16 PM | #7 | |
One cam is enough
130
Rep 6,801
Taskmaster2465.00 |
05-10-2010, 04:56 PM | #8 |
Rep 1,288
Dude I got to a point where I had litterally done everything I possibly could to get better... i was on this YOYO where I was good one week, down for a week, good the next week, down for a week....
It is so frustrating. Man o man.. I sincerely feel bad for you, I know its terrible. I would hope for your sake you aren't sleeping on a shit mattress are you? |
05-10-2010, 05:19 PM | #10 |
Rep 5,046
Yoga. Surgery. Core strength.
Taskmaster2465.00 |
05-10-2010, 05:42 PM | #11 |
Rep 10,309
This is the procedure I was talking about. A coworkers wife actually got it recently, but I haven't heard any good/bad other than it was very unintrusive and required little rehab. So from that POV it's good, but not sure how effective it actually is at fixing your back, as it's a pretty recent development
05-10-2010, 05:55 PM | #12 |
Rep 1,352
The absolute last option I would consider is surgery. You need someone to assess the cause of the dysfunction otherwise you're treating the symptom of a greater problem.
05-10-2010, 07:29 PM | #14 |
Rep 1,288
05-10-2010, 07:30 PM | #15 |
Where my bitches
741
Rep 1,924
Drives: Cadillac coupe deville
i tweaked my back in sports is HS and i just rotated heat and cold, but mine wasnt nerve damage just a slight pull
05-10-2010, 07:33 PM | #16 | |
Rep 1,288
Believe me though.. nerve pain is a whole other echelon of discomfort. |
05-10-2010, 07:36 PM | #17 | |
Where my bitches
741
Rep 1,924
05-10-2010, 08:37 PM | #18 |
Rep 1,517
I have the same thing. Had it since I was 19 and Im 30 now. I have to stretch about 30 mins a day to prevent the pain. I lay on the ground with my hands down and push my upper body up with my legs flat. Another great one is face down get on your elbows and get in a plank position then release the tension in your abs. I get a good crack when I do that and seems to release the pain for a bit. But its a life thing...
05-10-2010, 09:02 PM | #19 |
this chick >
36
Rep 261
Do yourself a favor and do not let doctors just 'manage' your pain with opioids such as oxycontin. Trust me, I have been down that road. Once you start narcotic pain meds and get used to them, it will be the hardest thing you have ever done to get off. Doesn't matter if you have an addictive personality or not.
As some of the other posters mentioned, try rotating heat and cold and any kind of minor stretching or natural exercise. My upper back and neck has really been giving me trouble since my car wreck 2 months ago. I have been seeing a chiropractor twice a week and it really has helped. Also, you may be able to get some temporary relief from those electronic impulse pads combined with heat. Good luck and best wishes!
Life's short, live fast ... drive a BMW
E90 325i - totaled 03/17/10 (R.I.P.) E92 328i - took delivery 04/02/10 |
05-11-2010, 10:26 AM | #20 | |
Rep 81
05-11-2010, 10:37 AM | #21 |
Rep 5,046
Chiropractor will only provide short term relief. You'll have to go constantly. Been through the chiropractor, pt, massage, biostats, acupuncture. I've got a compressed lumbar disc.
The only thing that made any bit of difference was yoga. But not initially. It wasn't until I found the right yoga teacher. The more traditional teachers accredited by whoever accredits them. No matter what you do, it will be an ongoing process. Theres no quick fix. |
05-11-2010, 10:59 AM | #22 |
Rep 336
I feel your pain man; at 25yo I have arthritis in C1-C7, and a mildly herniated disc at l2-l3 that isn't bad enough to warrant surgery, but bad enough that it can cause a helluva lot of pain at times. These injuries are a result of slipping off one of my F/A-18s when I was getting it ready for flight, fell approximately 12 feet and broke the fall with my head, and my spine absorbed pretty much all of the impact.
I went through 7 months of rehabilitation for my back and the best remedy for pain was core exercise, coupled with a TENS unit, ice and even heat. Heat WILL work but it will only help increase blood flow in the muscles and relax them, which tend to tighten up from immobility due to the back pain. However, you should only use heat after the inflammation has gone down, so ice for a couple days before you introduce heat. Stretching daily helps, I always stretch in the morning and at night before bed. There are specific stretches I was taught in rehab that I do to keep my lower back pain free. A chiropractor will work wonders, but like everyone else said, you'll have to go multiple times. Oh, and if you get to a physical therapist, they can use ultrasound, which also works pretty well. The worst thing you can do is stay immobile. I would get something like ibuprofen or naproxen to help with inflammation and pain, and ice the area 15-20 minutes per hour until the pain subsides, then do some mild stretching and walk around.
spongbobsquarepants15.50 |
