08-04-2017, 11:11 PM | #1 |
Rep 2
20x8.5 et30 square set up
New member here. I have a 2014 328d sports wagon and wanted to know if 20x8.5 et30 square set up with 245/35/20 tires will fit?
08-05-2017, 12:01 PM | #2 |
Rep 243
245/35/20 is going to be a bit taller than the stock 225/35/20 but they should fit.
Wheels will also definitely fit in terms of inner clearance to struts, but they will stick out 12mm (1.2cm or about a half inch) further. This will probably be OK... My wheels are 8.5" wide in the front with a ET32 offset. They look fine. You're only another 2mm out, I'd call that unnoticeable. |
08-05-2017, 08:51 PM | #3 | |
Rep 322
