01-29-2014, 08:28 AM | #1 |
Rep 1,919
'Standard' Sport mode seems faster...???
Hi All.
I took my car out for a drive last night ( at midnight ) to get my average MPG down a bit and for some reason the car 'seemed' to be faster in regular sport mode??? What I mean is, just selecting the driving mode as Sport but NOT pushing the gear selector over to the left appeared faster - or at least just as rapid as pushing the gear lever to the left. Does that make sense? The gear changes are definitely a lot more aggressive when pushed over to the left but other than that I'm not really sure what's happening??? Has anyone else experienced this or can someone please explain the differences to me? TIA |
01-29-2014, 09:01 AM | #4 | |
Rep 371
01-29-2014, 09:44 AM | #8 |
Rep 1,573
selecting the Sport drive mode will increase your throttle sensitivity, making it seem as if your car is moving faster with less effort from the pedal. for example in sport, if you're pressing the gas 50% of the way, it will be like pressing it 100% in comfort mode.
The sport side of your transmission (moving the lever to the left) gives sporty characteristics to the transmission....meaning it will be in a lower gear and hold the gear longer. it doesnt have THAT much of an impact on your perception of the cars speed.
2015i Cadillac Escalade ESV
01-29-2014, 09:44 AM | #9 |
Rep 1,224
Yes it would be.. When you stick the car into Sport Mode (using the button) it opens up the throttle more, thus injecting more fuel and becomes more responsive.. It's like having the sports/power button on the M3's...
Sticking the Gear Lever to the left, that only allows the engine to rev higher before selecting a higher gear.. I find this mode very boring in comparison to the first one! Whenever I decide to play, I select Sports Mode using the button.. |
01-29-2014, 09:54 AM | #10 | |
Rep 15,858
I'm in 'D' with chassis and drivetrain checked, toggle to sport mode and typically the 'box changes down one gear with higher rpm change points. Flick the stick to 'DS' and it down changes another gear with even higher change rpm. Drive in 'D' (no sport mode) and flick the stick to 'DS' at similar speeds to above and there is the two gear down change. So it appears there is a sort of "half way" gearbox sport mode on the toggle modes. Is this what you are finding? Hence the feel of it being faster. HighlandPete |
01-29-2014, 10:04 AM | #11 |
Rep 15,858
In my view the throttle sensitivity can give a placebo feeling of being faster/slower. Hence why ECO-PRO is viewed as sluggish, although maximum power is still available in ECO-PRO.
Many have stated the same sort of feeling for the 'Sprint Booster' add-on throttle adaptor/mapping for older models. No extra power, but feels better. Whereas gear selection will obviously change acceleration rates. Whatever the throttle feel, or actual movement required. HighlandPete |
01-29-2014, 10:09 AM | #12 |
Rep 1,404
Could it be something to do with diesel engines? ie max torque on a 3.0 diesel is around 1500 to 3000 rpm, so by keeping the stick in "D" it will change up a gear sooner, if you flick it over to "DS" it revs higher before changing gear thus dropping off the torque, maybe it's the torque you're noticing as you accelerate?
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras Prev - E92 330D M Sport | Black | Highline Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White |
01-29-2014, 10:15 AM | #13 | |
Rep 1,919
01-29-2014, 10:17 AM | #14 | |
Rep 1,919
01-29-2014, 10:24 AM | #15 | |
Rep 258
01-29-2014, 10:27 AM | #16 |
Rep 652
well I just got back, with the car in sports mode with ds selected it feels like there is more aggressive change through the gears but I think it does feel a bit slower than when the car is in d. But I sort of follow where d4 springer is coming from and actually d will change the car up a gear while it is still in its power band whereas ds holds the revs a bit longer and the torque drops off. Im going to have to have another play when im out next. But it probably is just a placebo and maybe we are expecting more from it, who knows.
By the way mines s drive so its faster anyways |
01-29-2014, 10:32 AM | #17 |
Rep 1,404
Maybe you've started something here, BMW's up and down the country on the commute home will be randomly flooring it to try out different modes!
01-29-2014, 10:33 AM | #18 |
Rep 652
01-29-2014, 10:41 AM | #19 |
Rep 1,919
01-29-2014, 10:41 AM | #20 |
Rep 15,858
Riding the torque of the diesel will often feel faster, in a higher gear, even if it isn't. We can't see torque in isolation from rpm and peak horsepower.
HighlandPete |
01-29-2014, 11:16 AM | #22 | |
Rep 15,858
That will fit with diesel engine characteristics. HighlandPete |
