01-05-2020, 12:54 AM | #1 |
Rep 289
Copied and pasted from my BM3 FB post to try to learn more on datalog reading:
Im new to this BM3 life but here are logs of the new V7.0 Stage 2 E30 on my N55 EWG. This is my 1st ever log using the BM3 software and honestly Im gonna need to build one of those wifi things...Its difficult to do this one man on the road...lol http://www.bootmod3.net/log?id=5e117542ae729b7e8357b89f http://www.bootmod3.net/log?id=5e117565ae729b7e8357b8a0 http://www.bootmod3.net/log?id=5e117617ae729b7e8357b8a3 Having some overall "smoothness" issues as you can see ( sorry for such a shitty log , I live in the heart of Bay Area California so open road is tough). My two homies above dropped there input just wondering if anybody else had same issues on the latest V7.0 map so far? I made a case already and Ill update it soon with PTF but figured this is my 1st ever BM3 datalog would be nice to share everyones inputs.. -plugs are new less than 500 miles right before i went stage 1. ( OEM ) -regapped them this morning to .022 as recommended thanks hopefully this doesnt become a massacre of my noobness.... |
01-05-2020, 10:59 AM | #2 |
Rep 142
I’m not sure if it’s your fuel quality or your original plugs, but your timing is not looking too good in some places, with it going to 0.something or lows like 3 or 4. I know since you're 6 speed that logs will look different than an 8 SPD auto, but shouldn't be too different, because you are getting significant overboost to over 20psi and maybe it's throttle closure creating your timing. What's your E %? Right before at 30% or more? HPFP PSI also sagging in places to 1400 from 2800 Target. Maybe too much E.
01-05-2020, 11:02 AM | #3 | |
Rep 289
What part of the reading state it could be too much E ? I'd like to learn ! |
01-05-2020, 11:18 AM | #5 |
Rep 289
01-05-2020, 09:00 PM | #6 | |
Rep 289
Debating just running the rest of the half tank of e30 and try to see if the V7.0 stage 2 will be better. The V6.4 e30 Stage 2 map was a lot smoother also but no logs.... lol |
01-06-2020, 11:36 AM | #8 |
Rep 142
I recommend sending PTF a log of the new 7.0 map if you haven’t already and be sure to let them know that you are 6 speed. They’ll revise the map for you. Good luck!
01-06-2020, 11:38 AM | #9 |
Rep 289
01-06-2020, 02:54 PM | #10 |
Rep 289
update:
Got response from PTF, they like me to do the pulls at 3500rpm forward / log. I told them ill flush my fuel tank with a few tanks of 91 to start fresh and will log e30 in a few weeks. |
01-06-2020, 04:12 PM | #12 |
Rep 289
yeah ill probably have to do this at 3am or so next time , its tough living in the major city to find open road. Also my 1st time doing logs on BM3 and the first 3 logs before the ones above I had issues connecting to my hotspot... I ended up doing logs "offline" .... I truly miss some cobb accessport logging lol.
01-06-2020, 04:13 PM | #13 |
1297
Rep 3,536
It over boosts then boost goes way low... am i reading this wrong?
01-06-2020, 04:13 PM | #14 |
Rep 289
01-06-2020, 04:17 PM | #15 | |
Rep 289
Im still trying to learn whats going on but thats all I can see... |
01-06-2020, 04:23 PM | #16 | |
1297
Rep 3,536
http://www.bootmod3.net/log?id=5e1105b0ae729b7e8357b6f4
01-06-2020, 04:41 PM | #17 | |
Rep 289
01-06-2020, 04:58 PM | #18 | |
Rep 7,613
Also, did you spin or hit a bump? You have a spike then drop in RPM which should only be attributable to one of those two things. |
01-06-2020, 05:02 PM | #19 | ||
Rep 289
01-06-2020, 05:42 PM | #20 |
Rep 7,613
Stock/OEM/original clutch? Could be clutch slipping... It occurs right when you start getting hit with high boost/overboost. Disable everything except RPM and MPH and you can clearly see it. If the wheels were not spinning the clutch was probably slipping. I dont see any other explanation for the disconnect between engine rpm and vehicle speed. I think 17 psi on a ethanol tune produces around the torque limit of a OEM clutch.
01-06-2020, 05:56 PM | #21 | |
Rep 289
Clutch slip even if im in 3rd gear starting to do pull at 2500rpm ish? You are right thought wheels dont spin just overboost and then limps down. |
01-06-2020, 07:46 PM | #22 | |
Rep 7,613
45k is not a ton, but also not low, especially if the PO was launching a lot or doing fast shifts with the stock CDV still there. |
akgambino271.50 |
