10-31-2016, 10:45 AM | #1 |
Rep 466
New Tires & Rims For Winter !!!
Hey Guys,
15' 335 xdrive sport package. So winter is nearing and I would like to get a square setup of 18inch 8.5 rims. Looking for recommendations on the best Tires & tire size, Rims under $500 for 4. also Offset. Thanks |
10-31-2016, 11:10 AM | #2 | |
Curmudgeon and Pedant
692
Rep 3,488
Check tirerack for options. |
10-31-2016, 12:20 PM | #5 | |
Rep 466
Hey Floyd why 8 inch ? and I live in NYC i dont think Ill need blizzaks right ? I currently run super sports on a 8.5 inch rim 245 40 |
10-31-2016, 05:38 PM | #6 | |
692
Rep 3,488
Most people go a bit narrow for winter, as you get better performance in snow/ice with more pressure per square inch to "bite" better. Here's a setup that someone else in NYC is using: http://f30.bimmerpost.com/forums/sho....php?t=1303540 Last edited by floydarogers; 10-31-2016 at 06:14 PM.. Reason: add link |
11-01-2016, 09:53 AM | #8 |
Rep 466
11-01-2016, 09:57 AM | #9 | |
Rep 466
As for 225 vs 245. Do you think the tire stretch would be a pro or con? |
11-01-2016, 10:42 AM | #10 |
Rep 1,562
While narrow tires do go through deep snow better than wider tires, both tires will have the same pressure per square inch if they are filled with the same air pressure. The weight per square inch of any tire is always equal to the air pressure in the tire. Any tire inflated to 32 pounds per square inch, for example, presses down on the pavement with 32 pounds per square inch. The weight of the car is counter balanced by the air pressure in the tires on the surface so the pressure per square inch will be the same no matter how wide the tire. The shape of the contact patch is wider for the wide tire, but shorter. The shape for the narrow tire is longer but narrower. But both will have the same contact area. We keep hearing that you should use narrow tires for your winter tires, which is true if you will be driving in deep snow, but for most of us it really doesn't matter, because most of us drive in areas where the roads are plowed, or have enough traffic so that any snow is packed down.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
bimmercar182.50 vincechase247.50 |
11-01-2016, 12:00 PM | #11 |
Rep 383
I have no xdrive 328- Never used snow tires at all in northern nevada. Just in case, I want to get some. Don't know how they are used... Do you put them on for winter and leave them on all winter? I heard that if there's no snow that they wear faster (don't know if that's true). Info appreciated. Thank you.
11-01-2016, 12:16 PM | #12 |
Rep 774
i have a set of 4 enkei raijin hypersilver 18x8, used for several months, minor curb rash on one of the wheels.
located on long island, no tires or tpms |
11-01-2016, 01:35 PM | #13 |
692
Rep 3,488
While I agree with your statement, the pressure recommendation for the square setup 225/45R18 snow tires I have (on my E90 335d) are quite different from the staggered 225/40R18 & 255/35R18 summer tires. If you look at the recommendations (on p.186-8 in my wife's 328xd owners manual), the same disparity exists. Given that, I probably would be more careful in making any statement like yours.
11-01-2016, 02:06 PM | #14 | |
Rep 466
11-01-2016, 02:07 PM | #15 | |
Rep 466
So I will stick to a 8.5 rim and maybe 245/40/18 tires. Not sure what tires Ill need for NYC. Continental DWS should do the job. Global warming been a bit sketchy though. |
11-01-2016, 02:10 PM | #16 |
Rep 466
11-01-2016, 02:11 PM | #17 | |
Rep 466
11-01-2016, 02:53 PM | #18 | |
Rep 1,562
11-01-2016, 08:21 PM | #19 |
692
Rep 3,488
11-01-2016, 08:52 PM | #20 |
Rep 1,562
And how many of the people on this forum run the numbers in the manual. I sure don't. I adjust my tire pressures as needed for conditions. Problem solved.
11-03-2016, 09:12 AM | #21 |
Rep 205
225s are a little stretched even for 8 inch. 235 fits perfect for 8s. 245 for 8.5 and 255 for 9...so on..I would personally be going 235/45/18 on some nice gloss black 18x8 inch rims.
11-03-2016, 10:51 AM | #22 |
692
Rep 3,488
I disagree about 225 & stretched. 225 is the STANDARD width for E9x and F3x tires, and 8" is the STANDARD width for wheels on same. And 8.5 is the standard rear width for a staggered set with 255 rear.
Better to say you like the APPEARANCE of slightly bulging tires. |
f30, offset, rims, winter 18" tires wheels |
