BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > USB Flash Drive - Max size??
      04-19-2012, 12:48 PM   #23
AlexM
AlexM's Avatar
Drives: G06 X6 M50d
I'm going with 64gb external SSD, should work.
X6 M50d Tanzanite Blue
F36 440i GC/retired; F30 328i/retired; E92 335i/retired
      04-19-2012, 02:16 PM   #24
Micleg
iX1 2022
35
Drives: iX1 msport, 520d F11 X08
Originally Posted by Elk View Post
Did you check the tags to make certain they were correct for the affected album? My suspicion is that this is a tagging issue rather than a misread.
Maybe it is sorting by file name?
      04-24-2012, 10:24 AM   #25
Shuttlegoose
Drives: f30 328, e36 m3
Bought a 32 gig flash drive. Copied songs from my iTunes folder direct onto the flash drive. I'm hoping everything works out lol.
      04-24-2012, 11:08 AM   #26
rmm0031
Drives: 2013 335i M-Sport
2013 BMW 335  [0.00]
How does the USB music work if you go without the Tech Package (no NAV, so I assume no HD storage)? Are you just keeping the USB stick plugged in the whole time? And where is the port?
      04-24-2012, 11:17 AM   #27
Shuttlegoose
I have the tech. Yes that's my plan. Either glove box or center consil
      04-24-2012, 10:21 PM   #28
jaybeeunix
Drives: F30: 2012 328i sedan
I have a 64GB (40GB used) USB flash drive full of mp3s in my F30: It works for me.
      04-27-2012, 10:44 AM   #29
Ryan9095
Ryan9095's Avatar
60
Drives: 2022 430i
For those of us WITHOUT the technology package (aka no hard drive) is it possible to use a USB for music storage? Or do we have to stick with Y-Cable + iPod?
      04-27-2012, 11:10 AM   #30
Zirenz2006
Zirenz2006's Avatar
Drives: G80 M3 Comp IOMG
You should be able to use a USB drive
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue
Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i
      04-27-2012, 11:47 AM   #31
pcbrew
pcbrew's Avatar
29
Drives: 2012 335i 6MT
Correct, USB music playback is there as standard un US.
This link has a pick of the interface with USB drive.
It's pretty basic and you get no album art.
      04-27-2012, 11:54 AM   #32
Shuttlegoose
Loving my 32 gig flash drive so far! I ended up finding a y cable in the
Glove box, guess they threw it in lol.
      04-27-2012, 08:00 PM   #33
joey8781
Joe
Drives: 2006 325i Sedan
For FAT32 the maximum volume size should be 2TB. The device probably won't mount if it requests more than 500mA, so bus-powered hard drives probably will not work. However, SSD's in a bus-powered enclosure might, since they should draw under 200mA. I'll test when I get my 335i in a couple of months...
      04-28-2012, 03:11 AM   #34
Youputitwhere?!?
Drives: E92 coupe
Out of curiosity, what happens if you get a virus on the hard drive ?!
      04-28-2012, 09:35 AM   #35
Elk
Drives: 2012 335i
You and your car will be dead by morning.
I wouldn't worry. Someone would need to specifically design a virus to harm this system as well as method for it to replicate onto your USB drive.
If it did happen BMW would simply replace the drive and related components.
      07-09-2012, 08:54 AM   #36
Gerusarus
Gerusarus's Avatar
South Africa
Drives: 2010 E90 323i Ex individual
Thought this might help....
http://sourceforge.net/projects/album-art/
http://techie-buzz.com/music-tools/e...mp3-files.html
MP3Tag software - http://www.mp3tag.de/en/
      07-09-2012, 09:23 AM   #37
Silver F30
Silver F30's Avatar
Drives: F30 Sportline
I have a 750G external HDD connected to the USB in the center armrest. I popped the plastic piece where you would plug in the 3.5mm jack. I then disconnected the USB connection from that piece and carefully put my HDD down into the space open by taking that piece out. I have about 60G worth of music on the HDD and it reads all the files. If I change from one device to the other when I go back to the HDD it plays right where it left off when I switched to CD etc...
      07-09-2012, 10:42 AM   #38
PrazVT
PrazVT's Avatar
Drives: '21 M240i 6mt (soon)
I hooked up a 256GB SSD in a USB 3.0 enclosure w/ 2 usb plugs (data + power) and the drive worked. One point of caution w/ SSDs - my drive died b/c of sudden loss of power (ie. turning off the car). SSDs do some garbage collection on their own so they seem to be a little sensitive to sudden power cycling. My SSD lasted all of 2 days before it went down in Germany - thankfully Crucial is replacing it. I didn't have the 2nd usb plug plugged in to the 12v -> USB port I connected to the rear seat 12v socket. If I use that 2nd plug as well in the rear seat socket, if the car turns off, the drive will still have power to do whatever it needs to do (and the Crucial tech seems to think so).
Of course, no such issues if you're using a USB stick - used a 16GB w/o any issues after the SSD went down.
2018 Audi A4 6mt + Sport Plus (retired)
2015 228i M Sport 6mt + Track Handling Package (retired)
2012 328i Sport 6mt (retired)
      07-09-2012, 01:40 PM   #39
wayman519
Drives: E82 N52 6MT A51
2018 BMW X2  [0.00]
2009 128i  [0.00]
I have a USB Harddrive connected. The idrive detects all 250GB
      07-10-2012, 02:04 PM   #40
Elastino
Drives: F32 435i ZMM/ZTP/LED
Since the system is not an operating system like Windows, some of USB sticks may not work with larger capacity. We already have one case with 8GB which works perfectly on PC but not with BMW.
2015 F10-LCI 530D xDrive M Sports Package Black
2014 F32 435i M Sports Line Black
2012 F30 335i Sports Line Alpine White (retired)
2011 F25 X3 28i Silver
2010 E83-LCI X3 3.0 Silver (retired), 2007 E90 328i Gray
      07-11-2012, 06:57 AM   #41
rob72
/dev/random
rob72's Avatar
31
Drives: .
Assuming the device does not draw more then 500mA, it comes down to which filesystems that BMW supports.
Look for the maximum filesystem size
http://en.wikipedia.org/wiki/Compari...systems#Limits
Possible filesystems that they *may* support: FAT16, FAT32, exFAT, HFS Plus
Somebody already commented that NTFS apparently does not work.
For instance FAT32 filesystems can be up to 2TB, but you may have problems *creating* such a filesystem larger then 32GB
*edit*
ohh and be aware that you can either format a device directly with a filesystem, or partition it and create filesystems on it.
Not everything supports partitioned devices, and even if they do there are different partitioning schemes...
      07-11-2012, 07:23 PM   #42
Mahzari
Could you let me know if 32GB works? I'm thinking of picking up a 32GB thumb drive (for $19!) for my navigation-less F30
Does your car have nav?
      07-11-2012, 07:48 PM   #43
Frogman
Drives: 2012 F30 328i
I've plugged in 3 different 32GB USB sticks, all work perfectly. My car has the nav.
      07-11-2012, 11:59 PM   #44
Mahzari
flash drive, iphone, ipod, music storage, usb
