View Poll Results: tuned? | |||
Stock | 8 | 14.04% | |
Bootmod3 | 35 | 61.40% | |
JB4 | 3 | 5.26% | |
Other (plz specify) | 11 | 19.30% | |
Voters: 57. You may not vote on this poll |
01-10-2020, 12:22 PM | #23 | |
Rep 38
New plugs, coils, oil every 8k km and shell v-power racing only gets into the tank. Timing chain and oil pump already have been revisited at 70k km. Also my car has been fully logged under the maximum load and everything is more then fine. For example IAT are around 30 degrees Celcius (compared to 60 degrees Celcius with the stock FMIC ). |
01-10-2020, 12:27 PM | #24 | |
Rep 38
I am curious myself, till now I have ran several 0-100km/h times with driftbox and the best I have achieved is 5.1 sec. The car is RWD. |
01-10-2020, 12:44 PM | #25 | ||
Rep 293
I have Stage 1 BM3 rn on my 320. Would recommend it. I have only heard of FloridaOranges unlucky with his engine, but you figure one engine over a few thousand or so isn't too bad of a failure rate. |
01-10-2020, 01:03 PM | #26 | ||||
Rep 2,671
You must be lucky - or part of PTF PR team - mine had 48k miles and started with a really rough idle then threw a drivetrain malfunction and did eternal damage that wasn't fixable.(joking of course about the PR) |
01-10-2020, 01:03 PM | #27 | |
Rep 191
I'm rwd and almost never spin unless I do something wrong in the launch. AWD will have slightly better 60ft times (maybe 1.7 vs RWD with 1.8-1.9) but will have a lower trap speed (maybe 101-105 with RWD at 105-109) so it ends up balancing out for the most part. The two fastest n20s currently are RWD.
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
01-10-2020, 02:04 PM | #28 | |
Rep 38
My torque seems to be high though (around 450nm at the crank, the maxium that I wanted to have due to preservation of the cylinder head and the ZF transmission) - at least according to the magic dyno . However, I have driven recently my friend's stock 330i with the b48 and I have to say that his torque does not compare lol. Top end also dies thanks to the eco-map and the cat being in place . floridaorange I had a rough idle issue too last year, swaped the coils and the problem seems to be gone. To be honest this n20 idles rough from the very beginning, even with the stock map of 180 bhp. I am suprised tbh that you had both FMIC and the downpipe installed, rigorous maintenance and the piston blew. Were the other pistons fine? Have you found out the possible cause? @[Steakpizza] Haha you are right, let's keep fingers crossed for the head not to crack and pistons not to blow . Assuming that the dyno's number are correct and a 15% drivetrain loss I am making 280wtq (ftlb), which doesn't seem too excessive but high enough. And btw. my gains seems to be similar to those of the JB4 map5 . https://f30.bimmerpost.com/forums/sh...=849566&page=5 Best regards Nait Last edited by Naiters; 01-10-2020 at 02:49 PM.. |
01-10-2020, 03:38 PM | #29 | |
Rep 91
Still looking forward to reading what people are running. Im not trying to get it to 300hp or anyhting, 240ish to the wheels stock would be the sweet spot imo. |
01-10-2020, 03:40 PM | #30 | |
Rep 91
01-11-2020, 07:59 AM | #31 |
Rep 622
Hi! I have bootmod3 stage 1 on my 2017 320i. I'm at around 260hp and around 310 torque. My 0-60 is 4.93 seconds- faster than a stock 328i/30i. I also have a k&n drop in air filter. In addition, I also coded Sports Automatic Transmission and Sport + using BimmerCode. I chose bootmod3 because it adjusts all parameters rather than just a few- which is what a piggy back does. Thus making it safer. Also, the customer support of PFT is phenomenal. They are always updating the maps which is incredible. Data logging and stuff are easy with the WiFi agent. Overall, I love bootmod3 stage 1. The power is incredible. It reallllllly wakes the car up. Especially with the transmission flash they have. Both in conjunction have brought my 0-60 to 4.93 second. And trust me, you can really feel it
Ishan Achar
Former: 2004 BMW E46 325i Current: 2017 BMW F30 320i Follow @Black_Lux_Cars on IG |
01-11-2020, 08:26 AM | #32 | |
Rep 128
Here’s dragy screen.
2018 340ix AWD B58 8AT | MGflasher ST1 |
Instagram: andreykrop Youtube: DronaMashina |
Ishan99115.00 |
01-11-2020, 08:31 AM | #33 | ||
Rep 622
Ishan Achar
01-11-2020, 08:33 AM | #34 |
Rep 128
Actually 4,93 is also very impressive for rwd and st1 tune!
01-11-2020, 08:35 AM | #35 |
Rep 622
I need to get dragy and do more accurate runs. What I would do is use the obd wifi agent and screen recorded on my phone and just trim the video down 😂
Ishan Achar
01-11-2020, 08:45 AM | #36 |
Rep 128
That’s not right)) could be completely inaccurate.
01-11-2020, 08:57 AM | #37 |
Rep 622
But it's through the obd port! It literally reads out whatever the car is saying. Maybe the inaccuracy is with the trimming of the video. If anything, my car would be faster than 4.93 because it can only allow me to trim so much.
Ishan Achar
01-11-2020, 09:04 AM | #38 |
Rep 128
But you don’t know the slope... could be downhill. But I trust dragy or RL more anyway. Both of them shows almost the same numbers as racing telemetry.
01-11-2020, 09:07 AM | #39 | |
Rep 622
Ishan Achar
01-11-2020, 09:14 AM | #40 | |
Rep 90
01-11-2020, 09:21 AM | #41 | ||
Rep 622
Ishan Achar
01-11-2020, 10:49 AM | #42 | |
Rep 38
How are you guys launching the car, LC? I can't manage to get below 5 sec 0-100 km/h (which is 0-62.14 mph). Best regards Naiters |
01-11-2020, 11:30 AM | #43 | ||
Rep 293
01-11-2020, 03:40 PM | #44 |
Rep 73
320i, bootmod3, experience, f30, jb4, stock, tune |
