09-08-2016, 03:48 PM | #45 |
Rep 276
But the gearbox is very strong. The normal N55 is rated to 450nm. Some guys have +700nm. Ours is rated for 700nm..probably can handle 900!
Not much to worry about. |
09-09-2016, 01:58 AM | #46 |
Rep 931
Videooooooooooooooooooooooooooooo
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
09-11-2016, 01:19 AM | #48 |
Rep 1,291
Ended up ordering the JB4 as BR performance would require to work multiple days on the car to activate the switchable "multi-map" feature which I really wanted, plus the "pops and bangs" didn't work out for you.
All in all I think I could be better off with the JB4 and the bluetooth connector. I'll post any burble here in a couple of weeks when the device has arrived and installed.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
frackje51.50 |
09-12-2016, 12:14 PM | #50 |
Rep 1,291
Well yes i figured it would be interesting to compete with your tune with an advanced box like the Jb4.
And I want to be able to switch from stock to tuned easily (my wife drives this thing too!), so ordered their Bluetooth extension too. |
09-13-2016, 01:42 AM | #53 |
Rep 931
sound video are available ?
09-14-2016, 02:46 AM | #54 | |
Rep 931
09-14-2016, 04:02 AM | #56 |
Rep 276
Sorry for the delay. Sometimes I have some drivetrain error, today was the third time.
I'm going back tomorrow and will leave the car for a day. I recorded a short video this morning when the car had the error. Uploading now. |
09-14-2016, 07:22 AM | #59 |
Rep 931
09-18-2016, 02:30 AM | #61 |
Rep 931
good !
Any issue with eco-pro running ?
09-18-2016, 03:15 AM | #62 | |
Rep 1
When activated the ECU injects some extra fuel immediatly after releasing the accelerator pedal to be burned near the exhaust to produce that burbles. Per software that overun burbles are fully ecu controlled and depending on driving mode, accelerator pedal position, engine speed, temperature and gear. And in principal it has absolutely nothing to do with the mechanical exhaus system. The type of exhaust only amplifies the noise generated by the engine. But if there are no burbles from the engine coming, the exhaus cannot generate them. It really seems BMW did'nt want the AH3 to burble, maybe because it should be more a fuel saving vehicle for the U.S market than a sporty car where overrun burbles are more desired. So, BMW most probably just didn't program the overrun burble software function in the ECU. Therefore it won't help activating that ECU feature, because the code is missing. Most probably neither trying to just prog the PPK ECU software of the "normal" 335i model won't work, because the AH3 is a P2 hybrid with an extra e-motor which needs to be controlled by the ECU software to work together with the combustion engine. Tuners can only try to modify the existing AH3 software manually and eventually reach a level where the engine produces some (loud) blobs and bangs. But if not done correctly to much injected extra fuel can destroy the cats and/or produce ecu failures due to the exhaust monitoring (the stock AH3 ecu software doesn't expect to have extra injected fuel in the exhaust ract and therefore might produce failures)!! Sorry, but I think you will have no chance to get the stock burbles of an 335i in the AH3. |
Lancelot567.50 |
09-18-2016, 05:34 AM | #63 |
Rep 1,291
Video of Akra (stock engine tuning)
Cold start Revving up to 4k rpm
09-18-2016, 09:20 AM | #64 | |
Rep 276
This is my AH3 when I had a drivetrain malfunction. The hybrid motor was disabled and it became a 335i... No issues at all!! I need a camera like yours!! |
09-19-2016, 01:38 AM | #65 | |
Rep 931
TNX
