07-15-2014, 10:23 PM | #1 |
Rep 906
"Chassis: Drive Moderately" from coding?
Lately, I've been getting this strange message on the displays. They go away when I shut off the engine (yes, engine only).
After reading a bit on the message here, it sounds like it's a genuine hardware issue. However, I only experienced the problem after the car was coded. The message pops up once every 2-3 days, but after I coded EGS for SAT, it's starting to show up more often. So far, EGS, FEM_BODY, HU_NBT, IHKA, KOMBI, and REM_01 are the only modules that I have touched. Could coding any of these modules throw a false Chassis message?
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
07-17-2014, 08:59 AM | #2 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
When I reverted the coding, it was fine. Try reverting the coding on EGS and KOMBI and see if it still happens.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
07-17-2014, 10:41 AM | #3 | |
Rep 906
Never thought KOMBI would trigger that message, but seeing how FEM_BODY became the kitchen sink for the front side of the car, I'm not surprised either. Thanks!
07-17-2014, 07:33 PM | #5 |
Rep 1,136
It is normal, I get the same message while the coding is occurring, then it goes away after a couple minutes. It depends on what module it is that you are coding, but since it goes away I never bothered to track down exactly which module it is that causes it to pop up.
07-17-2014, 07:59 PM | #6 | |
Rep 906
Nah. I know better. I meant if the tech decides bring everything back to factory settings.
I guess we will need to wait and see. The car is in the shop and is staying there for a few days. In the meantime, I'm driving a 320i loaner. Maybe I should code the loaner and see if I can get the message to pop up?
07-19-2014, 09:55 AM | #7 |
Rep 1,136
Mine will go away after a while. For example, I code it then turn the car off. Sometimes when I come back and start the car, it will still be there, but when I drive off it'll go away after a minute or two and that'll be the last I see of it.
07-20-2014, 09:35 AM | #9 |
Rep 906
Some more data
I'm starting to believe it's a legitimate problem: I coded all the same tweaks into my F30 loaner and no message after 100+ miles of driving.
The car is still at the dealer, the line for their "diagnostics" team is quite long. Could be a few days before I get it back. Meh, could be worse. I could be stuck with a enterprise rental or no loaner at all.
07-20-2014, 10:17 AM | #10 | |
Rep 640
I'm not sure why you brought it to the dealer with your car coded on it because it's just asking for them to cause a commotion about. Not saying you did anything wrong, but they will give you hassle because it's something they would be able to blame and not have to pay for. They will find anything to try and make you pay. They can say, "You coded the vehicle for a feature you do not have, resulting in the malfunction when attempting to initialize the option." or some BS like that. I'm also not sure why you coded you 320i loaner. If these values you are coding in come from the cheat sheet, then clearly nobody else will have a problem coded them. I think that would be more helpful if you told people what you were coding. Can you list the values you are changing in these vehicles?
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
07-20-2014, 11:56 AM | #11 | |
Rep 906
You're absolutely right. Coding the car back to stock would have been a good troubleshooting step. I guess the reason why I skipped it this time was that none of my edits (attached) were "chassis" related. The only exception is EGS, but I had the problem before I coded this module.
You are also right that I should have coded the car back to stock before handing it over to the dealer. I researched it a bit and noticed most of others experiences involved either nothing or this... Quote:
The edits I made to my car and loaner come from cheat sheets and posts. I'm not the brave sort to go poking around ECU options...in German.
07-20-2014, 08:03 PM | #12 |
Rep 234
Pretty much every time I drop by car off at the dealer they push the latest and greatest software updates to my car and most of the others have the same experience as well. I suppose BMW keeps fine tuning and developing the software, etc. Coding or not, they will update & reset everything back to factory specs then diagnose the issue.
07-20-2014, 10:03 PM | #13 | |
Rep 640
Also, I checked your list and I have applied all of your codes plus a LOT more codes (except the LED turn signals, fog lamps welcome lights, and Sport Auto) and I can assure you I have no issues. Your list seems fine, make sure you coded the Sport Auto correctly. Otherwise, it's most likely an actual issue with your Chassis. Maybe something wrong with your DHP?
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] Last edited by Halsifer; 07-20-2014 at 10:10 PM.. |
07-20-2014, 10:07 PM | #14 |
Rep 5,262
please don't say "code default values" you may confuse people..... say "Code" to bring the car to the factory settings...
somebody reading this could go and click "code default values" button and screw up the whole car |
07-20-2014, 10:12 PM | #15 | |
Rep 640
There should be a big sign on the front of this subforum saying, (DO NOT PRESS "CODE DEFAULT VALUES").
2018 Audi RS7 4.0T
07-20-2014, 11:03 PM | #16 |
Rep 5,262
ya i make a CAFD backup everytime and add a changelog.txt for the record :-D
there is not such thing as too much money or too many backups |
07-20-2014, 11:10 PM | #17 | |
Rep 906
I dont think that's causing the problem though, since the message appeared well before I touched anything related to the Sports Auto tranny.
07-21-2014, 11:44 AM | #19 |
Rep 640
Well, it's in your dealers hands anyways right now. They'll fix it. Drive it uncoded once you get it back for a bit, like you suggested, and then recode it, only if you are worried though. Your coding seems fine to me. If it comes up during the recode, then maybe readdress on here. Keep us posted!
2018 Audi RS7 4.0T
07-25-2014, 07:35 AM | #20 |
Rep 906
It wasnt the coding...
I got it back from the dealer last night.
Turned out it was a bad vertical acceleration sensor for DHP and dealer replaced it. They didnt even recode any modules. I immediately VO coded SAT when I got back home, properly this time. I'll drive it coded for now, if the message comes back I'll go back to stock. Thanks to all for the help!
07-25-2014, 09:17 AM | #21 |
Rep 906
Ughhhh...
"Chassis: Drive Moderately" popped up on my way to work.
Looks like I'll be coding back to stock tonight. Should I leave the LEDs in and let them flicker for a while, or should I swap them out for the OEM bulbs?
07-25-2014, 09:20 AM | #22 |
Rep 640
LED bulbs shouldn't be and better not be affecting your Chassis sensors.
2018 Audi RS7 4.0T
