11-04-2014, 12:35 PM | #1 |
Rep 63
Paddle Retrofit
While some people seem to have investigated this, I haven't really seen any solid results of someone retrofitting paddles to their f30.
I have successfully coded to enable SAT (2TB) so that my gear shows S1, S2, S3, etc... while the shift lever is in sport mode, but could not get the paddles to work. I have the steering wheel with paddles, but does anyone have clear directions in terms of wiring and such to retrofit paddles? |
11-13-2014, 06:29 PM | #3 | |
Rep 1,107
11-14-2014, 08:32 AM | #4 |
Rep 1,976
Drives: 2020 G20 320i M Sport
I'm surprised a 335i wouldn't have 2TB with paddles stock in the US. Here in Canada, it's standard on any N55 equipped car.
I retrofitted the M Sport Steering wheel to mine and the coding wasn't enough to get it to work. We had to run a wire from the steering ring over to FEM_BODY since that pin wasn't populated. Since you have a 335i, I don't know if the pre-wiring is already there. Did you VO code EGS, GWS, ICM and FEM_BODY with 2TB on your FA? You can find out about it here. http://www.bimmerfest.com/forums/sho...=664849&page=4
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
jknight22.00 |
11-14-2014, 08:58 AM | #5 | |
Rep 40,752
11-14-2014, 11:08 AM | #6 |
Rep 1,976
Wow, you retrofitted the paddles too? Did you have to replace the entire steering wheel like how I did mine or can the paddles be added onto the existing steering wheel?
11-14-2014, 12:28 PM | #7 |
Rep 40,752
I had to replace the whole steering wheel, as the base for the paddles is molded into the wheel itself.
