08-27-2015, 04:20 PM | #1 |
Rep 51
Engine Cleaning
I've had my car for a while now (couple months) and was wondering how to maintain the engine. What should I be doing to keep the engine in good condition besides the basics such as servicing it, etc.
08-28-2015, 03:43 PM | #2 |
Rep 109
If you are asking how to keep it clean I can help. Other than that just do your regular scheduled maintenance. Spray the engine bay down with water and it will remove any loose dirt. Engine bays are made to withstand getting wet nowadays just don't powerwash things very hard and it will be ok. After that, spray on some degreaser or all purpose cleaner. Spray it liberally and everywhere. Next take a flagged tip brissle brush and scrub everything down to loosen the dirt and grease. Then rinse away any cleaner and dirt. You will want to dry the engine down after so that you do not leave water spots on the plastic. Then if you like you can apply a dressing to the plastics or rubber parts. Many options for dressings. Really shiny greasy ones or you can go for the light sheen. It's up to you. Let me know if you need any more tips.
08-30-2015, 01:40 PM | #3 |
Rep 1,101
Start when your engine is cold. I spray engine with P21S cleaner and then give it a brushing with an ez-detail brush. Then I lightly rinse the engine off with water.
Next I wash the car...making sure I didn't let any P21s dry on the paint. When the car is clean I take it for a small drive and get the engine warm and dry. Then I give a generous spray of Chemical Guys Black on Black on the engine and the surrounding parts. I do this to my engine 3 times a year and it looks great under my hood! |
09-03-2015, 03:41 PM | #4 |
Rep 614
Drives: 2016 F36 M Sport
Great tips, I'd always been curious about this as well. I'll have to make some time for this job.
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
09-04-2015, 12:37 PM | #5 | |
Rep 4,723
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
09-04-2015, 01:46 PM | #6 |
Rep 764
Yup. My dealer does this from time to time. I only realized because they told me not to worry if I saw liquid dripping from under the engine. It's just that they gave it a quick spray and wipe.
09-04-2015, 01:46 PM | #7 | |
Rep 4,723
09-05-2015, 09:29 PM | #9 |
Rep 3,061
09-05-2015, 11:26 PM | #10 | |
Rep 1,035
I'd like to know from an experienced person who's actually done it before (not 2nd hand info), which parts of the engine bay to either avoid getting wet or better yet, cover it up or bag it to prevent it from getting wet. This is not just a case of being OCD, which 99% of forum members are here. We're talking about your $50k car not being able to start again. If i was going to play it safe, i would remove the battery terminal before i did it, then let the car dry completely before attempted to start the car again. In addition, there's probably sensitive engine components i would cover up. Just off the top of my head, i would cover up the alternator, and any other exposed electrical connector that doesn't look like it would take water well. |
09-06-2015, 01:29 AM | #11 |
25cent millionaire
252
Rep 1,219
Drives: 2020 m4 comp vert
I did a lite rinse on the motor, washed with soap and foam sponge, dried it right away with a towel, let sit for an hr, and started, car ran like a ford for over an hr, after that,,, wont ever wash the engine again like that..
09-07-2015, 06:49 PM | #12 |
Rep 51
09-12-2015, 09:16 PM | #13 |
Rep 109
Yea spraying the engine bay is fine. Just don't power wash the ecu cover. It is made to get wet. In the olden days the alternator was not protected so you had to be careful but you can spray it down as long as you are gentle with it. Also you don't have to worry about the battery because it is located in the trunk. I am a professional detailer and have done numerous cars with this technique. I also currently am a client adviser for BMW and know these cars very well. Just be gentle with the car and you will be fine. Like I said don't start putting the power washer on full blast and hold it right on the engine components. Spray it down from a distance with a good misting and do the rest with a soft bristled brush and some degreaser. Then rinse it down again and dry it off with a towel so you don't leave water spots.
09-19-2015, 06:17 AM | #14 |
Rep 21
I have always used a 50/50 solution of simple green and as hot of water as you can stand in the bottle. Wear a glove if you have to. Start with cold engine. Let idle for about 5 min. and turn off. Spray the mixture every where except things like the alternator. Let sit for about 5 to 7 minutes. Rinse off with garden hose set on rain or flat spray...NO jet stream or excessive pressure. Start car shut hood and wash outside as usuall while letting car run for 10 to 15 min. Open hood wipe off any excessive water and don't forget to wipe the under side of the hood..
I have used this method for about 25 years. The simple green does not bother any aluminium, painted , powdered coated or rubber items....and hey its bio degradable so no worries where you do it. |
09-21-2015, 01:52 PM | #15 | |
Rep 45
<iframe width="560" height="315" src="https://www.youtube.com/embed/V4ZHLRAX_tU" frameborder="0" allowfullscreen></iframe> |
09-22-2015, 03:50 PM | #16 |
BMW Fanatic
331
Rep 1,076
I've been using Sonax Cold Engine cleaner to clean all the dust off, and after that's done I top it off with Sonax Engine lacquer. This lasts for a good 2 month period without needing work done on it again. You can see my results here at http://f30.bimmerpost.com/forums/sho....php?t=1068078. I've gotten better at doing it over time, as this was my first time.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
10-05-2015, 02:29 PM | #17 | |
Rep 185
Drives: 2017 X3 35i X Drive M Sport
10-06-2015, 03:07 PM | #18 |
Rep 389
Drives: '13 F30 335i MSport
Double that a 50/50 simple green mix sprayed on and wiped off with a towel. Use a detailer brush for tight spots. Follow-up with CD2 engine detailer. It's a spray and forget type product you can get at most autoparts stores. I would NEVER recommend spraying down the engine bay with water.
2013 GSM 335i MSport
