11-01-2013, 05:03 PM | #4973 | |
Rep 40,668
For resetting BMW Assist, I told you to simply VO Code the Head Unit and Combox by right-clicking on the ECU (not the CAFD), and selecting code. So why are you trying to retrieve and replace their CAFD's?
11-01-2013, 05:25 PM | #4974 | |
Rep 524
11-01-2013, 05:38 PM | #4975 |
Rep 524
Shawn, thanks so much for all your time and help. Got BMW Assist back the way it was. Much appreciate your assistance on coding with a newbie like myself.
11-01-2013, 05:42 PM | #4976 |
Rep 40,668
Ok. Glad it is working now.
11-01-2013, 08:31 PM | #4977 |
Rep 524
Every time I try to modify something under FEM_BODY, I get the out of memory error. Everything else codes without any errors. Is there a setting to increase the memory buffer or is it something about my laptop?
Here is the error: Transaktions-Report: Aktion: FDL Codieren Abort! No more memory available! Please restart E-Sys with more memory. [C150] |
11-01-2013, 08:36 PM | #4978 | |
Rep 40,668
11-02-2013, 12:34 PM | #4980 |
Rep 40,668
Did it work though?
11-03-2013, 10:03 AM | #4982 |
Rep 83
Help with coding issue
Finally I got the cable, I have E-sys 3.23.4 and 50.4 data. Working on a 328Xi 2013, everything works fine (connection, vin read VO and SVT etc..) Read coding data works fine and shows subfolders of the ALL CAF while connected. Save the FA and SVT, backup of the NCD as usual and then disconnect from car OK. The problem I am having is when I load the saved SVT and FA with no connection to the car, I see only the green dots at the CAFD but no subfolders that can be edited also (edit FDL) is grayed out, WHAT am I doing wrong? I did not try to edit the subfolders while connected, but I think it can be done. Any help is appreciated.
11-03-2013, 12:26 PM | #4983 | |
Rep 1,892
In the FDL-Editor mode, you can load the .ncd file and explore / edit without being connected to the car. You will need to have a map of which .ncd ECU numbers map the the ECU name (like 000794 -> FEM_BODY, 00000F9 is HU_CIC, etc) as the .ncd files don't tell you which ECU they are via the file name. You can just load each .ncd file one by one and the editor will show you the ECU name at the top of the tree. |
11-03-2013, 04:30 PM | #4984 |
Rep 524
11-03-2013, 07:00 PM | #4985 |
Rep 40,668
Glad to hear it.
11-03-2013, 10:41 PM | #4986 |
Rep 44
Blinking LED in Mirror
I heard that it is possible to code the blinking LED in the rear view mirror in F30 as all have this even if they do are not equipped with the alarm system.
1) Can this be confirmed? 2) What are the coding details if so? |
11-04-2013, 06:05 AM | #4987 |
Rep 2
Hi,
I am new to this forums looking for VIN decoder for my BMW Today my friend recommend this link http://automotivevin.com/ for VIN info. But can't locate my VIN number on my car. Please help |
11-04-2013, 06:07 AM | #4988 | |
Rep 40,668
11-04-2013, 06:51 AM | #4989 |
Rep 21
Hey Shawn,
I was thinking that for folding mirrors you have just to code(or ask the dealer), but now I understand that some mechanics shall be installed in the mirrors. Is that right? how to check whether the car is capable of folding in the mirrors eventually? |
11-04-2013, 09:15 AM | #4990 | |
Rep 83
11-04-2013, 09:21 AM | #4991 | |
Rep 40,668
S430A is standard equipment on U.S. Spec'd F30. Is it not for European Spec'd F30?
11-04-2013, 09:40 AM | #4992 |
Rep 230
I don't have an alarm but I do have that giant clear thing under my rearview. It would be great if this blinked when I locked my car. I'm with you, I'd like to know if this is possible.
11-04-2013, 07:00 PM | #4994 |
Rep 40,668
You need to post an email address or wait until you can receive PM's.
