BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 Wind-Noise Issues
      01-08-2013, 04:51 PM   #23
MotoEV
MotoEV's Avatar
Drives: BMW Active Hybrid 3
I have zero wind noise as well.
3 series cars are assembled at several plants globally. I wonder if the problem could be associated with a particular assembly plant or part supplier to the plant since everyone is not having the problem?
For those having the problem, what assembly plant is noted in your VIN?
As other have mentioned, if you feel this is a problem warranting attention get your facts in order. Pinpoint specifically where the noise is coming from and at what speed. BMW tends to be very strict on what corrections dealers can perform.
BMW has a PUMA database and I would ask your service team to research any other vehicles having the same problem and the prescribed correction from corporate. It took BMW six months to correct a part defect in a product I own and I learned the hard way that BMW follows a strict problem remediation process.
      01-08-2013, 09:22 PM   #24
normsbimmer
Drives: 2012 328i
Originally Posted by Sharp_Cai View Post
How did they fix your passenger side??
to be honest I think they didn't even bother on the driver side. They didn't reset my service notification after my oil change. But on the passenger side they replaced the moulding according to the report. you should be able to get the car same day if you drop it off early.
      01-08-2013, 11:26 PM   #25
RPM90
Drives: 340i M-sport AT
An NHTSA recall is issued for safety reasons. This type of recall is 'mandatory' as it is a legal requirement for the company to comply.
NHTSA typically deals only with these, safety related, types of issues.
Wind noise is not a safety issue.
However, BMW can issue a voluntary recall, as they did with the high pressure fuel pump failures. When a company issues a widespread voluntary recall, they typically send out information to customers to set up an appointment.
For BMW to issue a voluntary recall for wind noise, the problem has to be widespread with a number of customer logged complaints.
So if you do have excessive wind noise, then get an appointment and make sure you're dealer PROPERLY explains the problem so that it is logged into the system.
I don't have excessive wind noise at the front of the cabin. However, there is a more than expected overall level of tire and road noise throughout the cabin, mainly emanating from the rear wheel wells. I'm thinking this is a result of BMW's weight loss program for the F30. Seems BMW may have lessened the amount of noise isolation material, and possibly are also using thinner glass all around that is letting more noise/sound get through.
I know some are saying to shut off the audio so that one can hear the noise better. I say turn the audio up so that you can fix the issue yourself while enjoying your favorite tunes.
My audio is always on when I drive.
      01-09-2013, 05:09 PM   #26
SamGh
The Mechanic
Drives: 2016 F30, 340 MSport
The noise is generated by the space (groove like) between mirror and the window. It would be exteremly odd if you dont have it. I would like to get into your car and verify!
Drive Fast Not Furious
      01-09-2013, 06:11 PM   #27
Isow
Drives: 328 Modern Alpine White
I agree with you. The noise I can hear is does appear to be coming from the rear wheel wells.
I am in the UK & obviously have a right hand drive car, I have sat in all the other seats whilst my wife drives the car and I don't hear this noise. I only hear it when I drive the car & it starts at about 15 MPH !
I have Pirelli tyres, & I blame them. Maybe I shouldn't, maybe it is lack of sound insulation.
I wonder if later built cars have more insulation ?
      01-11-2013, 10:25 AM   #28
hav2flynow
Drives: 2013 Mineral White 328i Sport
I have a Whistling Noise Too.. Sounds like the lower drivers windshield area. I have a new 2013.. Jan 1 2013.. Sounds like this problem has not been fixed. I rolled down the drivers window and could still hear the whistle.. so i know its not the drivers window.
      01-11-2013, 02:00 PM   #29
SamGh
The Mechanic
Well I believe as long as your mirrors look like mine and others there is no expected difference. You had a very good observation, which lead me to believe the issue is not a defect: roll the window down and you still hear noise!
I have noticed however, that if you are driving in windy conditions, even low winds, the issue is aggravated. Some times I go 80 and I hear little noise, sometime i'm going 60 and feel like window is cracked open.
      01-11-2013, 02:35 PM   #30
Sharp_Cai
Sharp_Cai's Avatar
64
Drives: 2013 BMW 335i
I am almost sure it's the front windshield. I am taking my car in tmr, and hopefully they can fix it. Wish me good luck!
2016 BMW X5 MW M Sport MPPK MPE
2018 BMW M3 YMB on order.
      01-11-2013, 02:37 PM   #31
SamGh
The Mechanic
oh mate, dont tell me you are going down the path of replacing your windshield. That's going to be a costly mistake! but good luck!
      01-11-2013, 02:39 PM   #32
Sharp_Cai
Sharp_Cai's Avatar
64
I will tell the service dude to give me a heads up if they need to replace the windshield.
      01-11-2013, 02:49 PM   #33
F30AM
F30AM's Avatar
Drives: F30 330d M Sport sDrive
Wind and road roar are part and parcel of the F30 driving experience. Nearly every review has remarked on this particular lack of refinement.
Strangely, my car is very quiet. It is probably because it's got mismatched paint on the rear bumper and baggy leather on the driver seat. Small mercies.
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys
      01-12-2013, 07:14 PM   #34
Sharp_Cai
Sharp_Cai's Avatar
64
Update: Dealer service dept had a more experienced tech ride with me again this morning, and found out the wind noise is coming from the car sun roof. Let's see how it goes. Will keep you guys posted!
      01-12-2013, 08:57 PM   #35
Sladester100
Sladester100's Avatar
Drives: F30 320d ED
Interesting to know, I have teh sunroof... When I hit 50 ish I hear wind noise but it comes from my right (RHD), sounds as if the drivers window is open a crack... I have ''closed it'' when it was already closed some 7 or 8 times thinking it was open!
When passenger window open a crack, or sunroof tilted the wind noise to my right gets worse which makes me think its a seal of some sort as it changes with cabin pressure...
Will watch for your replies...
On order/Its Here! F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies
      01-12-2013, 11:52 PM   #36
Sharp_Cai
Sharp_Cai's Avatar
64
Problem Fixed!!!!!!!!!!!! Dealer adujust the sun roof from my car by 2mm. The wind noise is gone completely!!
      01-13-2013, 06:31 AM   #37
J1n
Drives: R8 V8 '14
finally problem solved nice1q`
      01-13-2013, 06:44 AM   #38
m1kal
Drives: F30 335i M-Sport
Is this problem on every f30?
2013 F30 335i Alpine White M Sport
      01-13-2013, 07:26 AM   #39
BMWinGE
Same for me, its there but not overly excessive. However, I did notice it more after getting an E90 loaner for a day.
Seems like its coming from the door and window area but that would be great if they found something in the sunroof.
      01-13-2013, 09:32 AM   #40
zofinger
zofinger's Avatar
England
43
Drives: F30 335d MSport
Nice one
      01-13-2013, 02:34 PM   #41
hav2flynow
I don't see how the Mirror can cause a WHISTLE.. I understand wind noise from air movement and that does not bother me.. To make a whistle you have to have a small space with air coming thru??? You cannot whistle with your mouth open you have to tighten your lips to make a small space...also passenger side does not whistle. I will also check the sunroof.
      01-13-2013, 09:42 PM   #42
AndDown
Just Copacetic!
Drives: 2016 F36 428i GC AlpinWeiss
I don't have the sunroof but get a whistling sound from around the right A pillar area. Will have the dealer look at it when I bring in the car for the ASS re-code.
      01-13-2013, 09:50 PM   #43
Tsuyoi
Drives: 2013 F30 328i
I have a Dec 2012 Build 328i baseline, no excessive noise or whistling that I can detect. Maybe you people are just used to much quieter cars, but I'd def say whatever sound I do here is not out of place or annoying/noticeable.
      01-13-2013, 11:11 PM   #44
hav2flynow
I have a loud Whistle.. This is my 3rd BMW.. E90, E92 never had a problem.. Im not just being sensitive.. My passengers comment as well.. I checked the sunroof, its not that either.
noise, wind noise, wind-noise, windnoise
