BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Do we need bigger shoes?
      02-25-2013, 05:08 PM   #1
m2michael23
Drives: G82 M4 Competition
I am still waiting for my EBII 335 to come. I would raise another discussion with you all.
As the title, do we need bigger shoes to get better grip for our f30?
i am thinkg 19' bbs ch-r. can they go 245 front, 265 rear? and what are the offset should be ?
      02-25-2013, 05:18 PM   #2
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
I went with 275s rear and 245s front.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      02-25-2013, 05:57 PM   #3
TheObviousChild
TheObviousChild's Avatar
323
Drives: '23 M3 Comp xDrive - '21 X3M40
Thought this was going to be a heel-toe discussion.
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      02-25-2013, 06:13 PM   #4
Jackson743
Drives: 335i M-Sport/EBII/ED 12/5
I also went 245 fronts and 275 rears on 19's. Offset 35 front and 38 rear. Good luck.
EB 335i M-Sport / Euro Delivery / M-Performance Brakes / M-Performance Exhaust / Adaptive M Suspension / 19" M5 Reps / Michelin Pilot Super Sports
My European Delivery Thread http://www.f30post.com/forums/showthread.php?t=807429
      02-25-2013, 07:05 PM   #5
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
I have the 18" square setup on 8" rims - I'll be replacing the factory 225 rubber with 245 RE-11's on all corners when these P7's wear out
      02-25-2013, 07:41 PM   #6
M3takesNYC
Drives: m3
For a 328 with 250 hp? That much weight your lugging around only kills rotational weight and performance. That is more than the e90 m3 has and the m has plenty of grip with 420 hp.
      02-25-2013, 07:52 PM   #7
Jamesons Viggen
Traction is privy to torque even more so than hp.
My car is tuned and the exhaust goes back on which added 20lbs of tq to the wheels. I will also upgrade my tune to stage 2 so I will be at OVER 300ft lbs of torque to the wheels.
You will note your M3 has 295ft lbs crank, or about 260 ish at the wheels which my car does stock.
So yeah, 275s are 20mm wider than stock which will be put to good use with the added power.
Your concerns with weight are also unfounded as I bought wheels and tires that are 4lbs lighter than stock for a 20% reduction of unsprung weight.
Enjoy your M3 though!
      02-25-2013, 08:24 PM   #8
M3takesNYC
Drives: m3
Won't bother explaining the whole torque thing here. Enjoy!
