04-06-2018, 05:30 PM | #23 | |
Rep 906
My old e90 was known to have less than smooth shifts on occasion but it was usually when it was cold outside. She was over 9 years old when I traded her in and never ended up having an issue with the transmission. Good luck to ya |
04-06-2018, 06:57 PM | #24 | |
Rep 647
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i |
04-06-2018, 11:16 PM | #25 |
Rep 797
That sucks .. maybe it's just bad luck.
This gearbox is really slow, a redline 1->2 shift requires some patience .. it just seems natural to wait for it as there's a bit of resistance in the lever until it catches up. I feel if I forced it down, it would probably grind as I used to do with the old Honda. I don't know what it is with this one but I've yet to catch a single bad noise around town. With the Subaru, low speed around town I'd clunk up 2nd or 1st way more than I care to admit. I do have occasions where 3rd or 4th won't go in first try at low speeds. Cold ambient/mechanical temps are usually there but not always. I can't figure that out yet. I can feel something moving around downstream that blocks the lever out. Tech obviously could not reproduce the problem. It may just be me going into the gate a bit off. Do you keep your hand on the shifter? Do you have one of those clutch stops? I removed mine .. it didn't really make it all that better, and was just a different thing to get used to. I doubt the computer match or lack thereof has anything to do with an upshift grind, but you should disable that on principle. Perhaps they didn't fill the replacement up enough. Last edited by B58 parts; 04-06-2018 at 11:23 PM.. |
04-06-2018, 11:28 PM | #26 | ||
Rep 150
2020 M340i xDrive
Dravit Grey Metallic Modifications July 23rd - Dyno Tune |
04-06-2018, 11:43 PM | #27 |
Sergeant First Class
87
Rep 150
I have had my 340 for 2 months i have driven only manuals for 15 years the second gear shift going in and going to third causes the car to jerk a little like a missed shift especially if you get over 5k rpms. This makes me nervous about the 2nd gear
04-07-2018, 01:22 AM | #28 | |
2JZ-GTE
3038
Rep 3,992
I pretty much double down all the time so the rev matching never works. If you plip the throttle at all between the shifts it does not kick in. I also see the Second gear grind but when I actually take the time to concentrate on redline shifts and wait that split-second it doesn't seem to grind… Will keep an eye on it |
04-17-2018, 05:17 PM | #29 |
Rep 647
I have an update:
Took it in this morning. Just got the (expected) call confirming the transmission needs to be swapped. It is going to take 10-14 days to get here from Germany. The SA assures me he's been there for 20 years and has rarely seen this. I told him I'm nervous as I've now seen this twice and several more times on the forums. This is the first Bimmer of the 6 I've had that I've bought and not leased so I'm a bit worried about it failing again. He told me it would be $14,000 to replace out of pocket. That blew my mind. As soon as the G80 gets opened for orders, I'm jumping. In the meantime, I'll try to enjoy the....X1 they loaned me.
04-18-2018, 01:37 PM | #30 | |
Rep 906
Sorry you're going through this, really disappointing to hear. Have always thought the BMW gearboxes were "bulletproof".
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her) 2018 M2 6MT (Never retiring) |
04-18-2018, 02:07 PM | #31 | |
Rep 5,369
Now if you have a 8AT, well, that is quite pricey. You're looking at around $12,000-13,000 to swap in a re-manufactured one. Maybe that's where they got the $14,000 number.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
04-18-2018, 02:13 PM | #32 | |
Rep 5,369
The ZF GS6-45BZ tranny is stout and has been around for quite some time. The F series cars use this tranny and it's the same one used in the 1M except that the tranny was revised to have a stronger 1-2 syncros in the F series. The M2-M4 use the same tranny as well except the syncros are beefed up even more in the first 3 gears. If you own a 6MT, I think it's best you not slam the 1-2 shift unless you really need to and if you do, make sure the tranny fluid is warm (20 minutes of driving). With AWD and power mods, you're really walking on egg shells.
04-18-2018, 02:50 PM | #33 | |
Rep 647
That really explains a lot. I do not go easy on this car, but drive it like a friggin BMW is meant to be driven. 340 PLUS the added power from MPPSK PLUS AWD.... I don't want a BMW I have to drive delicately. I'm going to get a friggin M3 already.
04-18-2018, 02:57 PM | #34 | |
Rep 906
MAkes sense...I commented in another thread that my previous 2 MTs always shifted best from 1 > 2 at low RPMs...like around 2500. And I often end up just starting in 2nd gear anyway with all of the rolling stops I do....so slamming 1 to 2 is rarity for me, and maybe that's partly why Ive never had an issue with my gearboxes.
04-18-2018, 04:20 PM | #35 | |
Rep 5,369
Many say they want to drive their BMW the way it was meant to be driven. Thing is, true sports driving doesn't really involve slam shifting the gears and in most all road race situations, you're not in 1st thus no need to hit the 1-2 hard. Only in drag racing would you grab 2nd hard assuming you're going for the best ET possible. What I like about the manual is that you are in control of the shift speed. I love winding it out, slow shift, and continue to wind it out. Is it the fastest way to accelerate? Nope, but it feels and sounds great. Torque shock on shifts is great too as it add drama to the driving experience. With the auto, it's always grabbing the next gear as fast as possible and it does it so well that it often feels CVT-like in nature. Fast and quick, for sure, but boring after a while. Been there, did that.
04-18-2018, 04:57 PM | #36 | |
Rep 647
The problem seems to revolve around torque, so I would imagine there is no added risk/damage when down-shifting. On my 335 I would rev-match (which was fun), but now they have the auto rev-matching. I frequently downshift. Hoping I'm not doing any damage. This seems so silly to even type. You would think a car like this could handle it.
