BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Winter Wheels for 320d GT F34 2013
      09-06-2017, 12:46 AM   #1
remussica
Romania
Drives: BMW 3 Series GT F34 LCI
Lightbulb Winter Wheels for 320d GT F34 2013
Hi everyone,
First of all, thanks for reading this. I'm looking to take a trip in Europe this Winter (where I definitely need winter wheels) and I can't seem to find any decently priced complete winter wheels (or winter tyres) for my F34. What I did find though is a lot of F10 wheels for reasonable prices with the same sizes J8 225 55 R17 but the rim offset is different. Instead of being ET34 like the GT, the offset is ET30 which means a 4 mm difference, which in turn means the wheels protrued an extra 4 mm on each side of the car.
I've phoned up my local bmw dealer which predictably told me that the part numbers do not match but I was wondering if you had any experience with this kind of situation. I've also noticed a lot of aftermarket wheels meant for the F34 didn't have the same offset either so that got me thinking ...
So I'm left with the solution of either shelling out around £800+ on F34 winter wheels from Germany, buying new winter tyres for my current 225 50 18 (around 800£) or getting the F10 wheels and risking some kind of damage.
The reason why I though it might be plausible is because I found an ad on gumtree for a set that was sold already but the ad said the wheels were used on a GT for 2 winter with no issues . (https://www.gumtree.com/p/wheel-rims...10-/1204981603)
I appreciate your help.
      09-06-2017, 07:55 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I can't see 4mm being a problem. 40mm, maybe.
      09-07-2017, 12:36 AM   #3
remussica
Romania
Does anybody have experience with actually using wheels with a different offset than the standard one (on gt is ET34) ?
      09-14-2017, 10:09 AM   #4
Arctic Drifter
Soffpotatis
Sweden
Drives: BMW M3 E92 6MT
remussica: As Billfitz said 4 mm is not a problem. I would say that almost all aftermarket rims for F34 has a different offset of 4 mm or more.
My personal experience is that my winter wheels for the Gran Tourer has aftermarket rims, the offset is definately more than 4 mm off. No problem at all!
The tires for my F34 is 255 mm wide, even if the offset is correct it adds 15 mm to each side compared to 225s.
If you are looking for a set of new winterwheels and don't want aftermarket rims I would suggest: https://www.leebmann24.de/bmw/3er/wi...urismo&first=0
Garage:
M3 6MT (E92)
      11-04-2017, 05:56 PM   #5
jeffGermanStick
Drives: 2015 335i Gran Turismo
Hi, I have a 335i GT, just bought a set of 18'' rims for winter tire, but its offset is 40, do you think it will work? I tried to check online but it want me to select between with blue caliper or not. But the fact is my front caliper is a 4 piston caliper just like MP brake. Really confused.
      11-18-2017, 12:41 PM   #6
Arctic Drifter
Soffpotatis
Sweden
Do remember that correct ET (offset) is connected to the width of the rim.
A BMW OEM rim 18x8" don't have the same ET as a BMW OEM rim 18x9". So, your new rims with ET 40, what's their width?
I have a set of E90 rims as my winter wheels. That's because I prefer to have good performance on uncleared snowy roads, and as far as I know there are no F34 rims with width less than 8"?
I want to go with 205s, and they don't look good on a rim that's 8" wide, thats why I use my old 7" wide E90 rims.
Garage:
M3 6MT (E92)
      01-22-2018, 06:39 AM   #7
Jungenwerther
Drives: f34 320d
Hello everyone.
I will be pickin up my new gt in Germany in a week- really excited.
Winter tyres are bit confusing for f34, since there are many different opininios.
Can official 225/50 r18 get replaced with 225/45 r 18?
I have also noticed a lot of you put larger tyre size on back wheels. Is this recommended for f34?
      01-22-2018, 06:47 AM   #8
Kjae
Drives: 2014 F34 335xdrive
I am running 225/45/18 winter square set. No real point in getting staggered winter set since technically wider tires in snow is worse. Plus u can rotate tires.
For summer set, i have staggered but can only rotate side to side
      01-22-2018, 07:13 AM   #9
Jungenwerther
Drives: f34 320d
Thank you
Car has 416 spoke 18inch
Tire calculator estimates 3.5% size differance.
I hope that wont cause any traction control(or similiar)problems.
      01-23-2018, 03:07 AM   #10
Jungenwerther
Drives: f34 320d
Anyone?
      01-23-2018, 07:41 AM   #11
Sportstick
Sportstick's Avatar
4654
Drives: '15 228i and '24 X3 sDrive30i
Originally Posted by Jungenwerther View Post
Anyone?
http://www.1010tires.com/Tools/Tire-...ismetric=False
That size is beyond the recommended limits. Use the calculator in the link to also see what other sizes may be a better fit.
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner
      01-23-2018, 07:49 AM   #12
Billfitz
Billfitz's Avatar
I wouldn't go with a lower profile tire. Winter roads are tough roads, and the lower the aspect ratio the greater the potential for wheel damage. For that matter if I had separate winter wheels I'd make them 17 inch. I would go with a narrower tire, say 215, all around. Narrower tires give better traction in snow because they dig through the snow to make contact with the road beneath better than wider tires. A 215/55x17 is what I'd use.
Sportstick4654.00
      01-23-2018, 08:27 AM   #13
Sportstick
Sportstick's Avatar
4654
Excellent advice....
      03-17-2018, 12:28 PM   #14
McZak
Drives: BMW F34 330d xDrive
Hello everyone.
Hi,
I have put 225/50/18” on mine. Alloys: black Matt with continental winter tyres - supplied and fitted by bmw garage. Car looks good - very difficult to notice difference downgrading wheel size from 19” to 18”.
3 series gt, bmw (3)series 2013, winter wheels
