BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 Active Blind Spot Detection(Lane Change Warning) Retrofit
      05-25-2016, 03:44 PM   #23
roxxor
roxxor's Avatar
1141
Drives: 2024 iX50
Awesome, glad you were able to get it working!!
      05-20-2017, 04:41 AM   #24
jalami
Drives: f30
Hi roxxor.
What do you mean???
Electric or folding!??
Mirror Electronics, Left – 67137438145 (Only needed if you are not swapping the mirrors)
- Mirror Electronics, Right – 67137438144 (Only needed if you are not swapping the mirrors)
      05-24-2017, 10:11 PM   #25
Dino325
Drives: 2013 BMW 328xi
Just wondering, if I have BSM on my car, what more from your list of parts would I be missing?
      05-25-2017, 10:21 PM   #26
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Roxxor. You are a legend!
      07-12-2017, 09:09 AM   #27
hmoghani
Drives: BMW 328xi 2014
Hi,
Do you know if anyone does this work in New England area or NY?
Thanks
      08-09-2017, 11:04 AM   #28
dob4odob4o
Drives: f25
roxxor i can,t see the pic that you publish. Can you fix that pls.
      08-23-2017, 07:07 AM   #29
jdr78569
jdr78569's Avatar
180
Drives: F31 328d sport wag
Want to get this retrofit in. Can you please update the thread so pictures work. Thanks!
      10-01-2017, 05:52 PM   #30
drapi13
Drives: 435xi
Hi,
roxxor i have a problem i did all the steps but still i can successfully do the FlexRay initialization. And i don't see the module in e-sys or ista+. I have checked that to module get
12V power, and the FlexRay Signals cables are ok from the back to FEM and they are in the correct pin place, i have also checked if the FlexRay loop is ok. I coded every module with the new VO as you recommended. Every thing seems ok... after that i bought a new HC2 master still nothing
BUT I've bought driver assistant panel with 2 more buttons with options i don't have (pre-collision, and some other shit) may that be the problem ? Is it possible that this create the problem ? I should also add that when i push the button it responds with a green led light and on the dash info that it will start working from 50km/h.
This is the errors i get :
      10-06-2017, 06:16 AM   #31
graphys
Drives: F30
Please reupload all photos. Not show.
      10-07-2017, 11:57 AM   #32
player_pl
Drives: BMW F36 430xd
You're Welcome
      10-13-2017, 09:03 AM   #33
xnap
Drives: F30
Hi,
Thanks for the very detailed and informative post. Am still waiting for the driver assist switch (on/off) to arrive. Appreciate if you could repost the photo of where you have zip tied the switch module? Understand from your post that the stowage compartment need not be sacrificed.
Thank you so much!!
Last edited by xnap; 10-13-2017 at 09:18 AM.. Reason: Better understand of the post
      10-14-2017, 04:39 PM   #34
Popilam
Drives: BMW 435I
Originally Posted by drapi13 View Post
Hi,
Hi! i have the same problem and errors.
It seems that the FlexRay channel can be unlocked with tool32 only. Ive tryed, but it's too complicated.
Maybe someone who did it will post the exact steps to follow.
      10-18-2017, 12:53 AM   #35
Popilam
Drives: BMW 435I
So, after following the steps from this threat and played few hours with Tool32 , i finally managed to unlock flexray port 3 and now everything works fine.
I still need to do some VCM coding, because if i run Flexray initialization with ISTA, the port 3 closes again, but, as i said it's a coding thing and if i don't run the Flexray initialization, everything works great except an error in the ZGW saying that Flexray isn't initialized.
Thanks all for posting infos and PMd me.
markqu0.00
      10-18-2017, 02:56 AM   #36
graphys
Drives: F30
Can you write step by step. How are you doing this processes?
      10-18-2017, 10:10 AM   #37
aridain
Drives: F80
In Tool32 load ZGW_01 and choose job steuern_flexray_pfad and type in 0x03;0x01 and hit F5. This will open the port/channel necessary for 5AG on the F3x.
      11-13-2017, 06:58 AM   #38
graphys
Drives: F30
Can you send a screen shot?
Regards
      11-24-2017, 08:48 PM   #39
raysspl
raysspl's Avatar
992
Drives: walking, bicycle, & bus
This is fantastic. Going to get this retrofit on my F30 & keep y'all updated.
re
      12-02-2017, 10:03 PM   #40
VitaminXX
Drives: BMW E39 525i
What is the port 3 for?
      12-14-2017, 03:20 PM   #41
jdr78569
jdr78569's Avatar
180
Not sure if you can help me out. I followed the steps and VO coded my car. After VO coding it my ICM isn't responding, everything still works real time but when run ISTA its amber and when I test the ICM ecu it goes red. I'm not able to installize the flexrays since the ICM isn't responding. I have not used or familiar with tool32.
      01-02-2018, 05:28 AM   #42
Bobf31
Drives: f31
Will mirrors with LCW get the LIN bus controll unit?
Partnumber: 67 13 7 266 659
instead of 67 13 7 292 347 for left and 67 13 7 292 348 for right
When it does we can probably code the mirror tilt function as well?
      03-02-2018, 06:11 AM   #43
deneyer
Belgium
35
Where can i find a complete and working version of Rheingold? Cause you have different types and some even don't work
      03-02-2018, 09:39 AM   #44
player_pl
Look here:
link
5ag, blind spot detection, lane change warning, steelerfan
