03-03-2024, 07:31 AM | #1 |
Rep 31
F30 FLA Retrofit without SZL button
Hello, is it possible to activate High Beam asistant without having button on steering switch unit (SZL) ?
I mounted FLA camera, connected to CAN but my SZL unit with FLA button is damaged |
03-04-2024, 11:56 PM | #2 |
Rep 1,581
Not in the OEM way. You may be able to take apart your switch and see if something obvious is wrong.
