01-25-2014, 11:46 AM | #309 | ||
Rep 458
Looking at the connector on the Touch Controller it is identical to mine. I should have it towards the end of next week so we will know for sure then anyway. |
01-25-2014, 01:55 PM | #310 |
Rep 30
@steddyman : I updated The firmware using esys. There is a whole thread for it on another forum. Let me know if you want the link (not sure if Im allowed post it here). There is a risk involved though,wasn't as smooth for me. Car should be on a charger and such and I thought I lost my nbt the first day, but it went through ok on the second attempt the next day.
@Aritaurus: No, I still don't have arrows. Don't think you'll get them unless you have kombi_mid at least. However all warnings, gongs are working and displayed immediately on nbt. I got a 2014 f32. So didn't have any combox for telematics or media built in. So it was a matter of plugging out the cables from the back of the hu basic and plugging everything back into the nbt. One more thing. My nbt now got pics of the f32 (pdc / vehicle info/ manual) after the firmware update Regarding the zbe. I'm also suspecting we got the kcan2 for the standard basic controller already. So I'm too waiting for steddyman to try out the touch controller |
01-25-2014, 03:45 PM | #311 |
Rep 458
Reseller confirmed the controller I ordered should just work in my car, so fingers crossed he is right.
Also, did you try a non-Touch Nav controller in your car already and did it work? Last edited by steddyman; 01-25-2014 at 05:22 PM.. |
01-26-2014, 02:54 AM | #312 |
Rep 30
I've tried the non touch nav controller again and couldn't make it to work. (The non touch, non nav controller which came with the 2014 car does work though). I've also been thinking if the ecu "zbe" is actually built into the controller module itself. Hence the reason it disappears from the ecu list when disconnected?!
Anyway did you also order the handwriting module which fits underneath the touch controller? How much did you pay for the bunch? Last edited by delecz; 01-26-2014 at 05:35 AM.. |
01-26-2014, 03:59 AM | #313 |
Rep 458
No, I haven't ordered any sort of handwriting controller, just the Touch Controller. I'm glad you got the same experience as me with the other Nav controllers, confirms the two I have were not faulty and validates the controller we have already may be k-can2.
01-26-2014, 08:40 AM | #314 |
Rep 458
Thanks. You are a brave man. Don't fancy going through that process with a new car.
I gave almost everything working except for BMW Live and Internet. The odd thing is BMW Live was working great in every way but Internet wasn't. I went into Options under BMW Live and Updated the Connected Drive. It downloaded then said ok, but now the BMW Live is disabled again and I can't get to any of the Live features. Apps is still working fine. Any ideas how to get Live back and why it went after an update? |
01-26-2014, 12:27 PM | #315 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
I never had to change out my CIC controller when I upgraded to NBT so I think if I was to upgrade to the touchpad, it would require a lot more work.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
01-26-2014, 12:45 PM | #316 |
Rep 458
No idea, but would assume it is built into the GW of the car that translates between all the different protocols of the different units and makes it addressable via ENET. I just get the usual 4 pin cable under the ZBE.
01-26-2014, 02:51 PM | #317 | |
Rep 40,793
01-26-2014, 05:26 PM | #318 |
Rep 458
No it isn't. But BMW_ONLINE_SERVICES is active on the NBT.
Regarding this firmware upgrade process, I guess most systems on my car will already by up to date given the age of the car. I have a few questions (yes I am getting tempted): 1. When I follow the process mentioned in that post, will it show me a list of any ECU's that need updating and give me the option of ignoring them? 2. Will it only update the NBT with a firmware that is compatible with it. 3. If I upgrade the NBT FW with the Emulator installed, will it keep it's current donor VIN or reset to the cars VIN. If the latter, can it be changed back so the FSC's still work? 4. Are there any advantages to this firmware upgrade? 5. Will it reset any FDL coding of the NBT back to VO defaults (or worse)? Many thanks |
01-26-2014, 06:05 PM | #319 |
Rep 40,793
1. Yes.
2. Yes. 3. Yes - But only if you specify Donor Vin on TAL instead of VIN from FA 4. Yes - 51.3 fixed some issues. 5. Yes - It will VO encode NBT and all FDL Coding will be wiped.
01-26-2014, 06:14 PM | #320 |
Rep 458
Thanks Shawn. Very helpful as always.
Anyone in the UK recommend an inexpensive battery charger for this that will provide enough power? For example, will this do the trick is it classed as a trickle charger? http://www.amazon.co.uk/CTEK-Multi-F...ry+charger+50a |
01-26-2014, 06:18 PM | #322 |
Rep 40,793
You can't use a cheap Trickle Charger. You need a commercial grade charger rated for 70 Amps. I have the Schumacher INC-700A 4/20/70 Amp Automatic Charger
http://www.amazon.com/Schumacher-INC.../dp/B002Z2Z7ZY
01-26-2014, 06:20 PM | #323 |
Rep 40,793
I have heard of people doing so, but I don't know. I can't image the Voltage is stable like a Microprocessor controlled charger is.
01-26-2014, 07:25 PM | #324 |
Rep 1,976
Hey Shawn, looks like I have a mandatory recall that requires a software update at the dealer for an emissions issue.
If I end up on 51.3 and my NBT is on 50.4, will I have any issues using it again or do you think I'll need to flash the NBT to 51.3 like the rest of the car?
01-26-2014, 08:48 PM | #325 |
Rep 40,793
NBT should be fine at 50.4 and rest of car on 51.3. You will need 51.3 PSdZData though to code car when you get it back.
How bad is the weather in Toronto? I am flying in tomorrow morning, and then to Montreal on Tuesday.
01-26-2014, 09:18 PM | #326 |
Rep 286
Very interesting details. I'm going to order my NBT soon through a eBay seller Aritaurus recommended. Hopefully everything goes smooth with the install. I'm going to go from an Entry_HU to NBT_HU.
Aritaurus, Wondering if you needed a new cable from NBT_HU to the display. From my understanding if I come from Entry_HU i should be able to use the same cable. Am I correct in assuming this? As the NBT's sold don't come with any cable which goes between HU and Display. If I do need to replace the cable, I guess i need to order it. steddyman, where did you get your emulator from? I need to get one as mine doesn't come with one. I prefer a plug and play one, as i don't want to splice any cables. If you don't mind can you point me in the right direction please. Shawn, We just had about 5cm of snow this evening in Toronto. Just cleared the driveway. |
01-26-2014, 09:19 PM | #327 | |
Rep 1,976
Wow, you're coming to Toronto? It's been really crazy lately, around -4F with blowing snow and it's probably going to be much worse in Montreal. I hope you're here on business and not for leisure |
01-26-2014, 09:32 PM | #328 | |
Rep 40,793
01-27-2014, 01:37 AM | #330 |
Rep 40,793
I wasn't suggesting that specific one from Amazon, just one similar that you can get in the U.K.
What else are you going to do with the big money you saved on swapping emulators? Last edited by shawnsheridan; 01-27-2014 at 01:46 AM.. |
