01-05-2014, 02:31 PM | #133 |
Rep 458
OK. I've just followed the above instructions and found the following.
* With the new iDrive controller connected I get a TIMEOUT either trying to read the CAFD or Code ZBE3 * When Coding the HU_NBT it goes through the full process, but still at the very end reports the error above. You see it reboot so it looks like it takes. Could this be because it doesn't match the cars VIN? * KOMBI is coding fine without any sign of errors. But I do see a little yellow triangle once I start the car in the top right corner of the black panel display. Could this simply be the time not set or noticing there is an issue with the Kombi? Can I now assume the iDrive controller is actually faulty? I couldn't work out how to read the ECU to get the VIN for the HU_NBT. I went through the same process as for VO coding and clicked Read ECU but it didn't change what was in square brackets after the module name or mention a different VIN anywhere on screen. I also tried it on the CAFD with the same results. Probably doing something silly. Many thanks again |
01-05-2014, 03:18 PM | #134 |
Rep 40,786
Is the new iDrive Controller the standard one or the new iDrive Touch contoller?
If you are still getting the error displayed in Post #149, "...processed with error" then the VO Coding is not successful. It would be strange too that it rebooted afterwards though. Is it the same exact error? Kombi exclamation is the Time / Date setting. The SVT is displaying car VIN for the NBT VIN because the emulator is doing its job, and lying about the VIN. Go to E-Sys => Comfort Mode => FSC => Check FSC Status, and look in the header of the log window, and see what VIN is displayed based on the FSC Codes in NBT.
01-05-2014, 03:30 PM | #135 |
Rep 458
I've been searching the logs to see if I can spot the errors that come up when coding. I found the following:
** Coding of the ZBE3 ** negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: ZBE3_67_ETHERNET severity: ERROR ** Coding of the HU_NBT ** job failed with negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; ECU: HU_NBT_63_ETHERNET severity: ERROR Timestamp: Sun Jan 05 20:12:18 GMT 2014 SessionId: default ErrorCategory: VEHICLE_ERROR ID: 433 |
01-05-2014, 03:31 PM | #136 |
Rep 458
It is the older iDrive controller with the Nav buttons, but it isn't the Touch model.
There is no Emulator installed currently. Iv'e fitted it without that for the time being. I will fit that mid week once it arrives. |
01-05-2014, 03:33 PM | #137 |
Rep 40,786
This is usually the wrong target was selected (wrong chassis or the right chassis but the one with _DIRECT after it), or at the bottom of target window selecting "Read VCM" instead of "Series I-Step", or Series I-Step is selected but selected values from the drop down boxes are used when they should be kept blank.
01-05-2014, 03:35 PM | #138 |
Rep 40,786
Well, with no Emulator, I don't know how coding will work with VIN Mismatched...
You can still check NBT VIN with Check FSC Status. You can also try Read ECU instead of Read SVT, then read NBT and see what VIN shows in the brackets.
01-05-2014, 04:00 PM | #139 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
Are you sure that everything is properly connected to your main connector that goes into the NBT? With the iDrive knob not working, that might point to something. 1lyfe took my spare CIC controller and was able to plug it in underneath the trim and it worked fine without any coding. He currently has my CIC head unit, 8.8" screen and spare CIC iDrive knob all running on his vehicle without any problems.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 01-05-2014 at 04:10 PM.. |
01-05-2014, 04:15 PM | #140 |
Rep 458
Sorry Shawn. I had gone through the usual process of Read FA, Activate FA, Read SVT, then selected the HU_NBT and clicked Read ECU. What are you saying I should have done differently?
01-05-2014, 04:16 PM | #141 |
Rep 40,786
Read ECU instead of Read SVT.
01-05-2014, 04:18 PM | #142 | |
Rep 458
What is the MOST cable in this scenario? Is it the big black cable bundle connector on the back? If it is, then I can't imagine any of the above would work if it wasn't connected. |
01-05-2014, 04:19 PM | #143 |
Rep 458
01-05-2014, 04:30 PM | #144 | |
Rep 1,976
My combox always conflicts with the built in combox on the NBT so I have to keep the combox disconnected in order for the USB, Bluetooth Audio and Apps to work properly. However, when I do this, the NBT stops communicating with the KOMBI and I won't be able to see the time or any vehicle data on the car. When I have E-sys connected, I get the exact same message you get trying to read KOMBI because the MOST connection is not available since the combox is unplugged. When I plug the combox back in, the KOMBI reads fine without issue.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
01-05-2014, 05:19 PM | #145 |
Rep 458
I got it. See what you mean now, when you read it, the VIN shows in the log window. The VIN shows me it is a European F31 10/2012 with the following options. I suspect some of these are extras you would normally pay for but don't know for sure:
S609A Navigationssystem Professional Navigation system Professional S612A BMW Assist BMW Assist S614A Internet Vorbereitung Internet, preparations S615A Erweiterte BMW Online Information Expanded BMW Online Information S616A BMW Online BMW Online S676A HiFi Lautsprechersystem HiFi speaker system S698A Area-Code 2 für DVD Area-Code 2 for DVD S6AAA BMW TeleServices BMW TeleServices S6ABA Steuerung Teleservices Control for Teleservices S6NLA Anbindung Bluetooth + USB-Geräte inkl. Connection Bluetooth + USB devices incl Despite what I was told, it looks like it was a German car, not a UK car. |
01-05-2014, 05:26 PM | #146 |
Rep 458
I've looked through some of the differences between configured FDL settings on the HU_NBT and the ones on HU_Entry. I've come across the following differences which I believe relate to the Stereo. My car is HK audio, and the donor car is HiFi audio.
I wonder if it would be worth changing some of these settings in the FDL to see if the speakers would then work. I can't imagine the connector on the back is different between the two hi fi's, but it could be. Thoughts: First the HU_NBT Settings: HIGH_END_AUDIO_B_UND_W kein_menu - options kein_menu, keine_insz, nur_lichtinsz, volle_insz Werte=00 LOGIC7_SYMBOL nicht_aktiv - options aktiv, nicht_aktiv HIGH_END_AUDIO_MENUE kein_menu - options kein_menu, keine_insz, nur_lichtinsz, volle_insz Werte=00 3002 - AUDIO_TUNER_TRAFFIC AUDIO_SYSTEM hifi - options hifi, stereo, tophifi, individual_sound, hk_surroundsound, hifi_system_harmankardon AMPLIFIER_VARIANT external - options external, internal, most MULTI_CHANNEL nicht_aktiv - options aktiv, nicht_aktiv 3004 - SYSTEM_EINSTELLUNGEN ZBE_LOW nicht_aktiv - options aktiv, nicht_aktiv ZBE_TOUCH nicht_aktiv - options aktiv, nicht_aktiv Now the HU_Entry Settings: 3000 - HMI LOGIC7_SYMBOL aktiv - options aktiv, nicht_aktiv HIGH_END_AUDIO_MENUE kein_menu - options kein_menu, keine_insz, nur_lichtinsz, volle_insz Werte=00 ENT_HUDRIVE_INSTALLED aktiv - options aktiv, nicht_aktiv 3002 - AUDIO_TUNER_TRAFFIC AUDIO_SYSTEM_CC top_hifi - options stereo, hifi, m_individual_sound, top_hifi MULTI_CHANNEL nicht_aktiv - options aktiv, nicht_aktiv 3004 - SYSTEM_EINSTELLUNGEN EXTERNAL_MOST aktiv - options aktiv, nicht_aktiv ZBE_LOW aktiv - options aktiv, nicht_aktiv |
01-05-2014, 05:28 PM | #147 |
Rep 458
No I don't believe it does. Mine is a new HU_Entry with HK audio but I don't have a Combox in the boot and didn't have any form of Nav before.
01-05-2014, 05:32 PM | #148 |
Rep 40,786
Hit the SVT Reset button on bottom right, and then select Read ECU instead of Read SVT. Your SVT should populate as normal, except based on the actual ECU hardware and not what is stored in VCM. HU_NBT should be present.
01-05-2014, 05:36 PM | #149 | |
Rep 40,786
Can has 614 Internet, so maybe your Internet will work. Does it have 6NR BMW Apps?
01-05-2014, 06:35 PM | #151 | |
Rep 1,976
My donor vehicle is a 2014 model so I had to use the newer option codes since they're all routed to BMW Assist which I don't have. When I try to VO code HU_NBT with 614, 615 and 6AL, they're just greyed out and won't let me select them. Let me know how it goes.
01-05-2014, 10:58 PM | #152 |
Rep 40,786
Yes, but no problem. This is what I was talking about earlier. You can use a set of newer FSC Codes that includes 6NR, and Import and Activate them in NBT, then code car for 6NR, and you will have 6NR.
01-06-2014, 02:27 AM | #153 | |
Rep 458
What exactly does VO coding the NBT perform? I know it writes defaults to the ECU, but what defaults? I notice my NBT thinks the car is still an F31 as it shows the tailgate opening options with a picture of the estate. Also, all the sounds defaults (above) are not for my sound system. Would VO coding if it worked base all the defaults on my full FA? |
01-06-2014, 02:33 AM | #154 | |
Rep 40,786
Frankly, I don't understand why you haven't VO Coded it yet. I would not waste my time on any current NBT abnormalities unless they persist after proper coding. Until then, it's all premature.
