04-11-2016, 01:00 AM | #2 |
I want to drive a Zamboni
1128
Rep 5,554
Drives: 13 E93 M3 18 F80 M3 16 K71
Not on F30 series.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
04-11-2016, 10:12 AM | #4 |
Rep 157
I have asked myself this question many times! There has to be some way of linking a touch sensitive panel and wiring it to wherever the front doors go to. But...like most things technical, probably too much of a hassle
04-11-2016, 10:32 AM | #6 |
Rep 774
i wish...instead of fishing the key out of my pocket or walking around to the climbing into the car to reach the middle button. i park against a wall so i can't even access the passenger door handle
04-11-2016, 10:34 AM | #7 |
Rep 1,261
Yes. This is the reason I had to change the idrive settings so the car doesn't lock by itself when I am driving.
04-11-2016, 10:42 AM | #8 |
Rep 136
what if I buy the front handles and put them to the rear, if wiring is made ??coding?? it will recognize the key?? hmmmm. I'm changing the front driver handle so I was thinking if I can put it on the rear door and make it work
04-11-2016, 10:58 AM | #9 |
Rep 6,986
Not sure I understand what's being asked here...when I open my car using comfort access, it opens all 4 doors. If you have your iDrive options set to open just the driver's door, then it will do only that. whether using the fob button or either of the front door handles. Mine is set for all 4 doors.
04-11-2016, 11:01 AM | #11 |
Rep 144
Regardless of which side the wall is on, wouldn't you be able to keep the key in your pocket and reach up to touch the front door handle? Just trying to understand the functional dropoff with not having CA on rear handles, since you're within reach of the front door.
04-11-2016, 11:26 AM | #12 | |
Rep 136
04-11-2016, 12:35 PM | #14 |
Rep 6,222
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Gotta move up to a 5er.
Yes, your 5er has it.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
04-11-2016, 01:21 PM | #15 | |
Rep 4,439
Drives: '23 X1 28i xDrive
04-11-2016, 03:23 PM | #16 |
Rep 379
BMW cheaped out on this one. Once you have it (S4), you notice NOT having it. Often want to toss something in the back first (briefcase, gym bag, etc.)
04-11-2016, 05:50 PM | #17 |
Rep 497
No not possible, in addition to having to run the wires, the CA module in the F30 only has inputs for two handles. Also you must realize it's not just the capacitive touch that's wires up, you also have antennas in each of the handles, and a sensor on the handle pull as touch turns off if you leave the car sitting too long. (Over a week) but wakes up with a handle pull. so it's not just 2 or 3 wires.
Also don't under estimate the wiring for instance the CA module on the E90 it is behind the right side trim panel in the trunk so you'd potentially running the wires though the whole car. |
04-11-2016, 06:39 PM | #18 | |
Rep 1,261
04-12-2016, 07:47 AM | #20 |
Rep 6,986
Wow...modern problems, I guess. I remember having to use the key to open one of the doors manually, then reach in and unlock the others. How difficult is it to put your fingers around the front door handle to unlock the car - or, just press the unlock button on the fob? Guess some folks are just never satisfied.
04-12-2016, 07:55 AM | #21 | |
Rep 1,231
04-12-2016, 08:30 AM | #22 | |
Rep 774
for me the fob is usually buried away somewhere in my work bag since 95% of the time i never need to touch it with the comfort access.
and i can't access the passenger door handle which unlocks all the doors because its against the wall of my garage. and im' not sure if you can change teh drivers handle to unlock everything but i don't really want to always do that for the rare times i need to put something in the back seat Quote:
