BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > F30 335i sport oil change
      05-03-2012, 09:11 PM   #45
RPM90
Drives: 340i M-sport AT
Originally Posted by rfx45 View Post
Same engineers that has made BMWs reliability so notorious?
BMW's are quite reliable mechanically.
Generally, BMW's get dinged on those surveys due to the overly complicated electronics they implement, as BMW likes to be at the forefront of technology not behind it. If you're an innovator there is always a risk with being an early adopter.
However, over time BMW does respond to the problems and makes serious attempts to fix the issues.
When it comes to mechanical things, and especially engines, BMW's are very reliable.
The HPFP issue did hurt BMW, but they found an answer, offered a solution, and gave extended warranty on the affected part.
That's pretty good imo. Toyota buried their sludging problem pretty well.
Think back, when was the last time you heard of BMW engines having problems with extended mileage use? When have you heard of engine problems resulting from a too long oil change interval?
For that matter, think about most all car makers. Modern engine building has come a LONG way from the days of leaky gaskets, and faulty rings where blue smoke from the tailpipe was a common feature in nearly all engines. I remember when all GM small blocks were expected to start burning oil by 100K miles, it was given. If you had one of those engines and it didn't smoke it was considered exceptional. Now, if your engine burns oil by 100K miles, that is the exception and not the norm.
Those were the oil smokey days of 3000-5000 mile oil changes. It sure didn't help those cars. That was due to engine manufacturing of that era. It's a different manufacturing world now. As well, oil technology is not what it was back then. Even non synthetics are better than they were, and synthetics are amazing at what they can now offer. We have higher powered engines and better MPG these days. Oil tech is part of that success.
      05-03-2012, 09:16 PM   #46
m6pwr
m6pwr's Avatar
38
Drives: '14 335i M sport
Originally Posted by Elk View Post
m6pwr, you are overstating your "data." At best, we have a large range of mileage at which one can reasonably change the oil.
There is no "correct" answer and no one is going to be "right."
If all engineers and manufacturers agreed as to the specific mileage to change an oil fill we would all know by now.
We can all agree that if the oil is older than a year, change it. Let's leave it at that.
Elk, I agree with you, man. I'm just presenting a viewpoint (and data, as meager as you think it is) - - one that is different than what some seem to think and advocate (that oem's oci's are crap and that you have to shorten them if you want your car to last). I'm not on a crusade to assert that everyone MUST adhere to BMW's oci. And I'm responding to a question. The questioner, and others who have viewed this thread, can make up their own mind. Let them decide if the data is overstated, and how they want to proceed. I agree that people can change their oil whenever they want and live happily ever after.
# # # Finis # # #
'14 328d, '13 M3 ZCP, '12 535i, '11 335d, '09 Z4 DINAN Stage II, '05 330i ZHP, '05 M3 ZCP, '02 M3, '91 328i, '90 535i, '88 528e, '88 M5, '87 M6, '95 Z3, 95 M3, '93 M5, '87 325e, '89 535i, '86 635i, '73 Bavaria.
      05-03-2012, 09:25 PM   #47
rfx45
rfx45's Avatar
Drives: E89
2012 BMW Z4  [8.50]
Look a page back?
Originally Posted by zhp43867 View Post
... look up 335i carbon buildup, or one of the many threads where higher mileage 335s are running like crap due to the issue. Also search "Direct Injection Carbon Buildup", you'll find hours of reading material. Here's the tip of the iceberg. High quality fuel and better oil than BMW supplies coupled with more frequent oil change intervals should help prevent this from happening:
http://www.e90post.com/forums/showthread.php?p=10395959
http://www.e90post.com/forums/showthread.php?t=447516
http://forums.bimmerforums.com/forum....php?t=1669210
Either way, I think you missed the joke in my post. The quote I replied to stated engineers spent hundreds, thousands, millions of hours into designing and testing these cars as if it never has problems, ever. I mean Ferrari engineers labored hundreds, thousands of hours into the 458 but thing still catches on fire.
2012 Z4
http://e89.zpost.com/forums/image.php?type=sigpic&userid=32142&dateline=132899  8397
      05-03-2012, 09:42 PM   #48
Elk
Drives: 2012 335i
Your visual inspection will mean nothing, unless you have special eyes that can see different spectrums by which to judge an oil condition.
If you believe that one should change oil when they simply "feel like it", then that as unsubstantiated as you believe BMW's recommendation is, even more so.
You are reading way too much in my little off-hand comment and, if all of this is directed at me it is misdirected.
      05-03-2012, 09:51 PM   #49
Elk
Drives: 2012 335i
Very fair, and I enjoyed taking a look at your references.
It is fascinating how complex the technology is. Each study looks into one characteristic (as is appropriate), but none appear to address the overall functional question in which we are interested.
Perhaps there will be a study of medium displacement turbocharged direct injection engines.
Then again, probably not.
      05-04-2012, 08:08 AM   #50
n55x3
Drives: n55 BMWs
Man I miss those days too. Now BMW and many other car manufacturers will say that burning a quart of oil in 3-5,000 miles is the norm.
      05-09-2012, 12:58 AM   #51
RPM90
Not all directed at you, no.
The main intent is to give a different point of view to viewpoints such as yours.
The visual inspection is a poor way by which to judge oil condition.
I didn't overstate it at all. Thinking you can judge your oil condition by looking at, is bad advice.
I'd counter that you overstated your ability.
      05-09-2012, 01:02 AM   #52
RPM90
I've head some customers with excessive oil usage get the response that a quart every few thousand miles is "normal".
Luckily, most BMW and other brands don't tend to use that much oil.
Also, turbo's tend to use more oil than NA engines.
I can accept 1 quart every 5000-7000 miles, but not under 5K miles.
But not much you can do when the manufacturer says it's "normal". You'll have a fight on your hands.
      05-09-2012, 01:17 AM   #53
RPM90
Look a page back?
Can you please clarify your comment?
My comment is not about isolated problems that can happen in any engine and brand. It's about the "whole" of the brand and series of engines.
Is there any fact or even perception that BMW engines do not last beyond 100K miles? Is there public knowledge or talk that BMW engines are of bad quality, and that it's due to long oil change intervals?
I haven't seen or read that those things are true, even since the BMW full synthetic change over in around 1999.
      05-15-2012, 09:11 AM   #54
geko29
Drives: 2023 M3 6MT
Nothing will happen if you stretch a 7,500 mile oil change to 8,000 miles a few times, but stretch (or even follow) the 15,000 mile interval a couple thousand miles regularly, keep your car for 100,000 miles, and let me know how it turns out.
Ok, I will. With the exception of one half-interval change to swap the factory fill at 7500 miles, I've exclusively changed the oil on my E46 exactly when the OBC tells me to, which turns out to be around 18,000 miles. At the change closest to 70k (forget the exact mileage), I sent the old oil out for analysis. The lab said everything was in spec, and they told me to KEEP USING IT. But alas, it had already been changed.
Now I've got 102k. Last fall I had the valve cover and the VANOS unit off to replace the seals, and I was expecting some serious sludge on the valvetrain and the inside of the cover. Nope. Both looked absolutely brand new, with a thin coat of golden amber-colored oil on everything. And again, this was at an OCI, so this oil was 18k old, and had only been changed 5 times in the vehicle's lifetime.
When I replace it with an F30 in a year or two, I have absolutely no qualms about following the recommended interval. And my E46 is in such good shape after doing so, I'm actually thinking about keeping it rather than trading it in.
      05-15-2012, 10:26 AM   #55
jrob
Bimmer God
Drives: 2003 BMW 330i
Ugh, oil thread #1 of probably 2,000 more to come...
      11-29-2012, 10:06 AM   #56
bcl0328
Drives: 2012 328i
There was a recent rant (maybe on this forum - - can’t remember) about the lack of a dipstick on some of the latest BMW engines. Actually, you should be happy. That is an indication that the motor is equipped with a neat device designed by Bosch called an oil condition monitor. It constantly measures oil level and the dielectric properties of the oil. As the oil (very, very slowly) ages, picks up wear metals, acids, fuel dilution, and oxidizes, the conductivity or dielectric properties of the oil changes. That’s where all that field testing comes in. BMW can correlate the electrical values measured at any one time to the general condition of the oil and adjust the oil change interval if the oil is in danger of becoming unserviceable. Bosch’s latest oil condition monitor even has a little transducer that bounces sound waves off the oil to measure changes in viscosity. What more do you want?
any more info on this sensor?
      11-29-2012, 02:24 PM   #57
howiegu
Member
howiegu's Avatar
Drives: 22%E2%80%99 M440
3000 mile oil changes went out with ducktail haircuts and penny loafers. Where have you been for the last half century?
Read the owner's manual and follow the oil change interval prescribed by the CBS (condition based service) computer shown in the dash. Earlier oil changes are wasteful and unecessary.
I've been told by a very experienced euro-based lubricants engineer (Doug Hillary) that BMW does very extensive field testing on each of its models to establish effective and safe maintenance and lubrication schedules. Doug currently works for Mobil, but has worked also for Castrol and in collaboration with BMW specifically on the development of the TWS oil for M cars. According to Doug, BMW uses two independent field testing outfits and he knows personally some of the engineers there. These guys know what the hell they're doing - - more so than anyone on this or any of the other BMW forums (and that includes me, for sure) when it comes to lubrication.
Shortening the factory specified oil change intervals achieves nothing with regard to the longevity/durability of the engine, other than conveying that elusive "peace of mind", and this includes the practice of dumping the factory fill at 1500 mi to wash out all those nasty wear metals (even if BMW says it’s not necessary on your car - - after all what does BMW know – they only make the engines). The practice of gearheads dumping the factory fill at 1500 mi on a new car is a holdover from the days of push rods, carburetors, and bias ply tires.
There is even some recent data/testing (done by Ford and Conoco Philips) that indicates too frequent oil changes may actually be counterproductive. They did tests (published in an SAE paper) that showed that what they called aged oil, or oil thats been in use for awhile, sets up and actually does a better job of lubricating, particularly in antiwear, (up to its condemnation point) than green, fresh oil. So more frequent oil changes may actually increase wear. Heresy! There was a similar study done (I wished now I had bookmarked it) specifically with regard to the antiwear add zddp, that showed fresh oil would dissolve and remove the tribological antiwear layer laid down by the old oil before it would form its own layer. Hard to believe. With respect to the direct injected turbo motors (like the N54/N55) Hillary has even said that he has seen what he calls very reliable data that indicates shortening the oil change interval "negatively affects" the formation of deposits - - the fresh oil just feeds more deposits before it stabilizes.
In spite of all this, we doubt BMW. We love the engineering that goes into the car but somewhere in our reptilian brain some atavism, some primordial fear, tells us the engineers can’t be trusted, that if we want the car to last we must halve the oil change interval to 7500 mi or 5000 mi or whatever.
I’d like to challenge anyone to post a link to a contemporary, scientific study by a reputable source that shows shortening the mfrs recommended oil change interval will increase the longevity and durability of the engine. And I don’t mean Mike Miller’s Old School Maintenance Schedule. I mean a study reported by the Society of Automotive Engineers, or the American Society of Mechanical Engineers, or the Society of Tribologists and Lubricants Engineers - - or similar.
And if you want to impress future buyers when you sell the car, show them UOA (used oil analysis) reports from a reputable ISO certified lab like Polaris (not Blackstone - - they don't do a good job on fuel dilution) showing that the oil you changed according to BMW's schedule was rockin good, and with the BMW it so well engineered that you don't have to spend $$$ doing oil changes at 5k, 7k or whatever.
Well put!
But some people still wear Members Only jacket
      11-29-2012, 02:26 PM   #58
howiegu
Member
howiegu's Avatar
I think the last issue of Car and Driver or Roundel (can't remember which) had a good article on those two sensors.
      07-05-2013, 04:40 PM   #59
Jacko
Jacko 135
Drives: 2each 2012 335 Sport lines
I have a 2012 335 and I changed my oil myself due to currently living in Germany and having BMW change it was going to cost me 280 euro. When I drained the oil at 15000 miles it was so Black and I found metal shaving in the oil and lots of it. I would recommend changing the oil at least every 7500 to 10000. I have had to put 3 quarts of oil in my car between when car was delivered to me and the 15000 miles. m6pwr it looks like you have owned a few BMWs and you worship the BMW company by the way your saying things but, I have spoken to the service techs here in Germany and they told me I would be wise to change it at the half way point between oil changes. I think it sounds like a wise thing to do.
      07-07-2013, 10:19 PM   #60
wins76
Drives: BMW 335
This is the grey area.
There is no credible reason to change synthetic oil at 3,000 miles. There is similarly no credible reason to wait until 15,000 ("BMW tells me to" is similarly unsupported, but for anecdotal insistence and supposition)..
BMW tells me to only put 91 octane gas, but I'm been putting 87 octane for years.....if BMW wants the car only to last 100k miles the easiest way to destruct the car is not to impost gasoline requirements. If you believe that ones should change oil at 7500, then ones should only put 95 or higher in BMW. BMW build the car, they know more than mumbo jumbo out there.
There is no free oil changes outside of N.A. And BMW still recommend 15000 miles change in those countries. We would hear a lot of owners in those countries raise hell if BMW engine fails prematurely because of oil change interval.
      04-23-2015, 08:35 AM   #61
AGONXF30
AGONXF30's Avatar
Drives: 2012 335i S-Line/Melbourne Red
Old thread is old, but I find a lot of the comments interesting.
I am not bothered by long oil changes, as long as there are not issues. As an engineering and someone that cares about the environment, I can see why manufacturers are also trying to extend the life of the oil and oil changes as it also eliminates a lot of waste. I can see most of you do not think about that.
      08-26-2016, 08:43 AM   #62
BimmerSkunk
Bimmer Fanatic
Drives: 18 340i
You'll need to articulate if you want to add anything to this discussion. BMW races cars but judging by the direction of some of their recent products, enthusiast oriented BMW is fading. Nothing will happen if you stretch a 7,500 mile oil change to 8,000 miles a few times, but stretch (or even follow) the 15,000 mile interval a couple thousand miles regularly, keep your car for 100,000 miles, and let me know how it turns out. They know they won't be responsible for the consequences of long oil change intervals, so they save money where they can.
Old thread is still old, but I wanted to add a data point. We have a 2009 328i that just crossed 176k miles. Mostly highway driving. Oil is changed ONLY when the OBC tells us to, so every 15k-18k miles. It has been perfectly reliable from a mechanical perspective, other than needing an oil pan gasket, valve cover gasket, and oil filter housing gasket - all of which are normal for a car this age. Looks nice and clean under the valve cover.
      10-03-2016, 09:32 AM   #63
theEZV
Russia
178
Drives: F30 335i; Looking for F80
Just got one of those "you car told us it's time to come in" emails. I bought the car about 11 months ago. It had 15k miles at the time. I've only covered 4.5k since purchase. Was going to change the oil this month anyway for peace of mind. Thought I would have to pay for it out of pocket, but I guess I'm good now that the car has "requested" it.
