BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Is there a way to get the M HUD on a 435i?
      11-11-2021, 02:25 PM   #1
CamTaylor11
Drives: 2016 435i M Sport (Manual)
Hello everyone, I currently have a 2016 435i M sport coupe that is equipped with the Hud. I was wondering if it was possible to get the M HUD. I drove my bosses M6 coupe and his HUD provides so much more data and I was wondering if there is a way to either replace or unlock that kind of display for my 435i.
      11-11-2021, 02:38 PM   #2
djacinto
djacinto's Avatar
Drives: F32 428i Xdrive
2014 BMW 428i xdrive  [0.00]
2013 128i  [0.00]
Well you've got quite a lot to do on that retrofit!
There's a display module that has to be fitted into the dashboard. You could cut into yours our purchase one that already has the slot open, or cut into your own. Additionally, it has to display onto the window, which also has to be replaced with a special polarized glass.
Also, I'm sure there's plenty more that I'm missing but from what I've read, that's the beginning lol
-2014 F32 428i Xdrive "Bella"
Follow the build!
-2013 E82 128i "Austin"
Follow the build
EuroFever
      11-11-2021, 02:44 PM   #3
CamTaylor11
Could you attach or state where you got your info from please?
      11-11-2021, 02:47 PM   #4
djacinto
djacinto's Avatar
2013 128i  [0.00]
I mean they're all over the place, I don't have one in particular to reference
Here's the first one that comes up on google
https://f30.bimmerpost.com/forums/sh....php?t=1345464
Follow the build!
Follow the build
EuroFever
      11-11-2021, 03:18 PM   #5
SuperLomi
Drives: 2013 335i M-Sport
I think their car already has a HUD, if that's what you mean by display module?
I'm no expert but I've read you need to retrofit the M Kombi in order to achieve this. not sure what else is involved, or even what's involved in making that work though. I think the Kombi need's to be re-programmed in order to scale correctly/use the right inputs? I'm not sure anyone has successfully done this.
      11-11-2021, 03:41 PM   #6
djacinto
djacinto's Avatar
2013 128i  [0.00]
Got you, my bad for misreading OP! I'm sure it's just a coding thing then
Follow the build!
Follow the build
EuroFever
      11-11-2021, 04:00 PM   #7
SuperLomi
It's not. Unfortunately. I know that much.
djacinto373.00
Wires1645.50
      11-12-2021, 09:52 AM   #8
smrtypants44
smrtypants44's Avatar
Drives: 2017 440i
IIRC The only thing that the M hud has over standard is a rev counter. Other items are dependent on the options your car has and are available in either
i.e.
music info
speed limit
nav info
ACC info
      11-12-2021, 10:39 AM   #9
Wires
Drives: 2016 340i xDrive
Doesn't the M HUD have gear indicators and a shift light too? Or am I blending some sort of made up fantasy?
435i, hud, msport
