01-15-2023, 05:42 AM | #1 |
Rep 13
I recently done my spark plugs and coil packs due to a misfire in cylinder 6. Gapped my plugs to stock gap .35 am using bosch plugs(ZR5TPP33) and bosch coils. (BOS-0221504470) torqued to 17 ft lbs. Originally they were bosch plugs same part #. For the original coil packs, were delphis. After gapping to .35, .30,.22, as provided from many sources still am having misfires if not worse. Scanner reading multiple misfires now.
01-15-2023, 08:40 AM | #3 |
Rep 13
Can a misfire cause damage a injector?? The first purchase of spark plugs (ngk one step colder) gapped at .22 also new ignition coils (bosch) was running fine until I did a small pull and got more misfires this time multiple misfires started off in cylinder 6 then jumped to 6,5,3.
