03-17-2015, 10:24 PM | #1 |
Rep 265
Drives: 2014 328i AW
F30 steering wheel upgrade to sport with paddle shifters
I just purchased a new steering wheel to upgrade to paddle shifters. What else is needed to get the paddles working? I assume some coding? ID rather not take it to the dealer if I don't have to.
MODS: afe intake, afe scoop, afe scorcher module, 19" AG M580's, H&R Sports, AWE Tuning exhaust, LED conversion,wrapped interior, msport steering wheel, msport aero kit
03-17-2015, 10:42 PM | #2 |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
I just bought a wheel too with Paddle Shifters and will have to get it working once I get the wheel.
Check this post which I've bookmarked - http://f30.bimmerpost.com/forums/sho...0&postcount=82 Essentially you'll need a wire from FEM Pin 5 of A173*7B to SZL Pin 3 of A83*2B if the wire harness doesn't have the wire. You can easily check if under ICM Module in E-Sys, doesn't have 3190 > Paddles_verbaut. The connectors required for the PIN are 61 13 0 005 197 x2. Let me know the result as well, as this is what I took from the posts. |
Brotherhef43.00 |
03-18-2015, 08:32 AM | #4 | |
Rep 265
03-18-2015, 11:17 AM | #5 | |
Rep 1,397
works perfectly tapping into those pins |
03-18-2015, 01:33 PM | #6 |
Rep 987
Actually instead of the M-Sport wheel we usually see, i got the M-Sport wheel from the F20 with the same airbag as the normal Sport wheel.
Prices vary on eBay. Thread - http://f30.bimmerpost.com/forums/sho...d.php?t=825228 |
03-18-2015, 03:10 PM | #7 | |
Rep 265
Thanks and your wheel looks great!
03-20-2015, 07:51 AM | #8 |
Rep 265
I just ordered the connectors, are these difficult to pin out? I've never done this before.
03-20-2015, 09:16 AM | #9 |
1/2 Asian Sensation
217
Rep 397
Drives: 2011 BMW M3 e92 ZCP
goon. It's awesome you're doing this because I'm getting ready to be doing this... and you can help me when I do! lol
All too easy...
03-20-2015, 10:27 AM | #10 | |
Rep 265
It seems like this needs to be check to make sure it's not there? I have no experience coding but I'm paying for a session and I'd like to have this included
03-23-2015, 07:18 AM | #11 |
Rep 3
Can I ask a potentially dumb question? I have been searching the forum and have yet to find an answer. What steering wheels have heat AND the active blind spot vibrator? I have a no-line car with heat and blind spot but no paddles.
03-23-2015, 12:10 PM | #12 | |
1/2 Asian Sensation
217
Rep 397
http://www.ebay.com/itm/BMW-F15-F20-...1691d8&vxp=mtr http://www.ebay.com/itm/2013-BMW-328...734871&vxp=mtr
All too easy...
03-23-2015, 04:36 PM | #13 |
Rep 232
I bought a sportline wheel to upgrade from my no-line wheel with heat and I noticed it had the vibration generator in it. So I can confirm you can get the sportline wheel with those options.
2016 528i Msport/Premium/Drivers Assist II/ACC/Cold Weather/Harmon/Pwr trunk
2012 Kawasaki ZX10R ABS 1978 Honda CB750k, 1977 Yamaha XT500 1975 BMW R90/6 & 1969 R69S |
03-23-2015, 05:01 PM | #14 |
1/2 Asian Sensation
217
Rep 397
Looks like that airbag got snatched up.
All too easy...
03-23-2015, 09:24 PM | #15 |
Rep 265
What gauge wire did you use and where did you purchase it from?
03-30-2015, 04:15 PM | #17 |
Rep 265
I just installed my new steering wheel today with paddles. Just to test and be sure I took it for a ride, and as expected the paddles don't work. I now need to figure out this wiring project. I wish there was a DIY for this, as the information is a bit scattered here. I am not an electrician so I really don't know what I'm doing. I'm going to check with my pro shop to see if they'd take it on. More soon...
04-02-2015, 10:13 PM | #18 | |
Rep 987
If in E-SYS under the ICM module that there is no listing for 3190 > Paddles_Verbaut, it means that you need to retrofit the wire. If that listing is there, you just have to change that field to "aktiv" and the paddles should work after that change. I'll chime in once I get my wheel retrofitted... it's still in the mail. |
AndrewC198910931.00 |
04-02-2015, 10:33 PM | #19 |
1/2 Asian Sensation
217
Rep 397
I just installed mine tonight. I spent like an hour trying to get the airbag off my standard wheel through the slits. OMG. I was going nuts. I saw another video where you pop the steering column cover off and get to the springs behind the steering wheel. This was pretty easy and only took like 5 minutes. I haven't tackled the paddles yet as I don't code and will need help with this portion.
All too easy...
04-03-2015, 02:05 AM | #20 |
Rep 3,225
04-04-2015, 01:24 PM | #21 |
Rep 160
This is false. If you have the M-Sport Steering Wheel, you can indeed buy the paddles, a new connector cable to accommodate the paddles, and a rear steering wheel cover that contains slits for the paddle shifter mounts.
You need: - #4 (32307848268), - #5 (32307848335) - Varies on your options btw - Paddles |
04-05-2015, 10:39 AM | #22 | |
Rep 61
