BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > NEW RELEASE: DINANTRONICS Sport (N20/N26)
      07-10-2016, 08:04 PM   #23
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Originally Posted by ACR3597
Originally Posted by Dinan_Engineering
Originally Posted by ACR3597 View Post
If it rains and water somehow gets into the module, it won't break the module will it? Also, where are we supposed to put the module after you connect it to the car?
No, it will not break. Installation instructions can be found at the link below but the unit is just zip tied to existing harness where it suits you.
http://files.dinancars.com/webresources/datasheets/fe87c3c87395f27075d01be824ea0dc5.pdf
Originally Posted by bateau View Post
Do customers without access to 93 octane need to do anything special? In Seattle we only have 92 available.
Nope. Works on 91 and up just fine but will just have slightly lower gains is all.
What gas is suggested for best performance?
93+
      07-11-2016, 04:14 AM   #24
enemigo13
Drives: F30 335xi TTH450
what about mixing in e85? as I check in ISTA putting 15-20% of e85 increases multiplicative adaptation values, so AFR should be probably ok, what about power ?
Originally Posted by Dinan_Engineering View Post
93+
      07-11-2016, 09:47 AM   #25
Dinan_Engineering
Drives: Any BMW
Never mess with E85 so I couldn't tell you.
      07-11-2016, 12:09 PM   #26
lesnica
Drives: 2013 328i xdrive
Hmm i wonder which is the better buy, this or bms stage 1?
      07-11-2016, 07:33 PM   #27
ACR3597
Drives: 2013 BMW 328i MSport
93+
Do you know if the tune is out of stock or on back order?
      07-11-2016, 07:41 PM   #28
Dinan_Engineering
Drives: Any BMW
No backlog but we are getting close to running out of our initial run already. I have 15 units in the system that didn't make it to be shipped before UPS picked up but everything else has shipped that has sold.
      07-11-2016, 07:43 PM   #29
ACR3597
Alright sweet, I ordered the tune Saturday night and it said it hasn't shipped yet. Just making sure because I just wanna get my hands on it, you know?
      07-11-2016, 09:29 PM   #30
bateau
Drives: 2013 328i Sedan
I ordered Dinan's new unit and BMS stage 1. Will dyno both on 2013 328i this weekend with BMWCCA Puget Sound chapter and post results next week.
      07-12-2016, 03:14 PM   #31
rambi
Drives: BmW F30
I have to use my cell phone to change settings on the app, that's asking for a ticket on normal street.
      07-13-2016, 01:44 PM   #32
wsoto
Puerto Rico
Drives: BMW F30 328i
As per Dinan website, the tuner has multiple settings. But I can't find in any part of description information about settings. What different between Sport, Sport+ vs Race? What other settings can be change or adjust by application?
      07-13-2016, 02:35 PM   #33
Simons975
Sweden
Drives: 328i Xdrive M-Sport
Will the hp gain from this tune be affected by a larger intercooler? I have a Wagner IC.
2014 BMW F30 328i Xdrive M-sport Alpine White. Wagner IC. Kelleners sport springs and Bilstein B8s.
      07-13-2016, 02:55 PM   #34
Dinan_Engineering
Drives: Any BMW
Valet is -3PSI, Stock is stock, Sport is +2 PSI, Sport+ is +3 PSI, and Race is +4 PSI.
No. Not directly. The tune will not optimize to various mods. Its simply a set boost controller. That said the addition of the intercooler will help cooling properties and then make the mid / upper rev range potentially more efficient so that same amount of boost increase may net you some slight increases in power.
      07-13-2016, 03:51 PM   #35
m95roadster
Drives: F30
Can the Race setting be safely used with CA 91 octane gas?
      07-13-2016, 05:31 PM   #36
Dinan_Engineering
Drives: Any BMW
Can it be used, yes. But there are a bunch of conditions that may affect the drivability with 91 on that setting. We ship the units in Sport+ / advertise numbers in Sport+ just because no matter the octane and mods that will work just fine no matter the conditions. The fact of the matter is not all 91 octane fuels are created equal and not all cars have the same tolerances so ultimately I would recommend keeping it in the sport+ setting when running 91 but you may find your vehicle works fine with no issues in the higher boost. You are free to try the higher stage though and if you don't like the way it feels you can simply dial back the power a bit.
      07-13-2016, 09:59 PM   #37
K320
Puerto Rico
78
Drives: 328i sportline
It will be interesting changing power levels with the phone. Actually for me to accomplish that i need to turn the racechip nob to the left.
      07-14-2016, 07:02 AM   #38
wsoto
Puerto Rico
For race setting +4 psi, the only recommendation is 93 gas? Or need exhaust and intake? Intercooler?
      07-14-2016, 09:24 AM   #39
Dinan_Engineering
Drives: Any BMW
Again, not all cars are created equal so there is a chance that you may want an additional piece to help the car out but all of the test cars thus far have ran fine in race mode with at least 93 octane and everything else being stock.
      07-14-2016, 11:36 AM   #40
E46nowF30
Drives: e46 M3, F30, F36
Just out of curiosity since Dinan is in California. Why test with 93 when there is only 91 available here?
      07-14-2016, 11:44 AM   #41
Dinan_Engineering
Drives: Any BMW
Because 93 is the premium fuel that is available in the majority of the country.
      07-14-2016, 12:35 PM   #42
E46nowF30
A lot of states only have 93 in select gas stations. However, I feel it should be tested with 91 since a large percentage of Dinan buyers are in CA as well as the fact that you guys should be testing with gas local to you.
      07-14-2016, 03:57 PM   #43
15Blk428i
Drives: 2015 Black sapphire metallic
Will this unit void the factory warranty? Will the dealer be able to detect if removed before maintenance?
      07-14-2016, 05:04 PM   #44
Dinan_Engineering
Drives: Any BMW
Warranty is not like a typical Dinan product. This unit only holds a 1 year product warranty. Essentially a defect and craftmanship warranty.
As far as detection and the factory warranty.... I will copy a response I did in another thread to save some time...
None of these devices are completely invisible. They all leave bread crumbs that can be deciphered to indicate a tune was on the vehicle. Anyone that tells you otherwise is lying to you. That said, the methods to get down to the information needed to see that level of detail are pretty extensive and the dealership itself with the limited resources on hand most likely will not be able to tell anything if the various devices are removed. The problem comes in on major repairs where PUMA is called in. On anything that's a major warranty claim, engine/tranny/etc, the dealerships are required to have a field technician come out and diagnose (BMW doesn't want to pay a big warranty claim if they can avoid it so these guys are there to ensure its legitimate). These individuals have much more sophisticated tools at their disposal that can dig further into the system to extract data which indicates a tune was used. These are advanced cars after all and equipped with the equivalent of a black box that logs nearly everything the car is doing at all times.
BMW would still, by law, have to prove that the tune is the cause of the failure but the reality is if they choose to deny the claim you would still be the one that would have to start the litigation process to fight that decision. Chances are BMW has deeper pockets so that route isn't pretty...
