BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > INJEN Intake DIY install supplement guide for 328i F30
      04-13-2015, 10:13 AM   #45
nyc4er
BMW Enthusiast
nyc4er's Avatar
Drives: '14 428i xDrive Coupe - Luxury
I personally like the way the injen intake looks better than the aFe momentum intake. And the injen is cheaper too! aFe looks more plasticy
2014 428i xDrive Coupe - Luxury Line - Black Sapphire Metallic / Saddle Brown Leather
      04-14-2015, 10:09 AM   #46
f30luxline
e92 - 335i
Drives: thisonetimeatbandcamp
I just recently switched from the Injen and really like the aFe better.
PRO's
1 - Lighter
2 - More quiet
3 - Plastic, could be less absorbent to heat. Injen would get too hot to touch.
4 - Simpler design, less congestion in the engine compartment. Makes installation and removal literally a 2 minutes job.
CON's
1 - Doesn't fit 100% with the BMS OCC.
2 - More expensive (I stole mine for $100)
      04-14-2015, 10:37 AM   #47
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
PRO's
1 - Lighter
2 - More quiet
CON's
aside from this. performance wise do you feel any difference, like sharper throttle than injen better end pull ect. ?
      04-14-2015, 10:51 AM   #48
f30luxline
e92 - 335i
My initial thoughts were that there was slightly more low end power. As if the power ramped up quicker. Per my recent dyno chart, the power does seem to ramp up quicker but I also have the ER IC and full charge pipes that can contribute to this new power curve.
Another big plus was that with the Injen and map 7 I would get not so smooth shifts between 2.2k and 2.8k. I thought this was the behavior of map 7, maybe the car needed to be driven harder on map 7 as shifting after 2.8k would be smooth. Also at times I would get WG flutter during these lower end shifts. Both of these symptoms have been eliminated with the aFe. Note this behavior was not consistent.
      04-14-2015, 06:57 PM   #49
nyc4er
BMW Enthusiast
nyc4er's Avatar
PRO's
1 - Lighter
2 - More quiet
CON's
Great dude, thanks for that. I've been stalling on the aFe scorcher/intake kit for some time now. That pretty much settles it.
      04-15-2015, 05:47 PM   #50
lesnica
Drives: M4
Does anyone know where I can buy the two torx screws included in the injen intake kit?
      04-15-2015, 07:19 PM   #51
RGR275MAF
Drives: 2013 328i XDrive Sportline
[QUOTE=lesnica;17750521]Does anyone know where I can buy the two torx screws included in the injen intake kit?[/http://www.injenonline.com/mm5/merchant.mvc?Store_Code=IN&Screen=PROD&Category_Co de=HD&Product_Code=X-6072
Took me forever to find this site, I kept trying to find them under the actual Injen retail website. You can find all the replacement prts here, think the order has to be like 10-20 bucks so get ready to buy some extra sleeves/liscence plate or two.
      04-16-2015, 11:01 AM   #52
lesnica
Drives: M4
[QUOTE=RGR275MAF;17751037]
Thanks, my original screws are kind of stripped, and the two screws that came with the intake literally flew away with the wind.
      04-18-2015, 12:09 AM   #53
dhurng
dhurng's Avatar
407
Drives: '19 i8
i just did my install today and honestly I am noticing my mpg decreasing pretty drastically for some reason, I double checked everything and they are all attached and seemed secure (I put the clams over the rubber sleeve which connects the two pipes to make sure there is no leak. the rubber sleave wasnt in the instructions) and no warnings and eevrything sounds great, just that gas decreases at a scary rate :/ Any thoughts? reset ECU maybe?
      04-18-2015, 08:27 AM   #54
rustyminded
248
Drives: BMW 328i
i did battery rest & let the car adapt to slow driving. go on it easy & it will be great
      04-18-2015, 11:12 AM   #55
dhurng
dhurng's Avatar
407
Drives: '19 i8
ahh I see thank you for the tip! Ill give it some time then :]
      04-20-2015, 10:28 PM   #56
bimmerillini95
Drives: BMW 328i f30
Anybody know where to get the 0.242 in self lock rivets? Its the black ones that just snap in the intake lower box. Mine broke off(they are plastic).
      04-21-2015, 06:26 AM   #57
f30luxline
e92 - 335i
Any type of panel fastener will work, 1/4" is what I used when I sold my Injen. I had to trim them down as they were too long but it works.
      04-21-2015, 09:33 AM   #58
bimmerillini95
Where exactly can you get these mate, i tried home depot and autozone, couldn't find anything similar
      04-21-2015, 09:34 AM   #59
bimmerillini95
Hey i tried the battery reset but the mpg still drops down drastically, it is seriously scaring me out right now.
      04-21-2015, 10:18 AM   #60
jmaak
Drives: 370z
I would return it to stock and see what happens. Install should be less than an hour.
      04-21-2015, 10:34 AM   #61
rustyminded
248
Drives: BMW 328i
weird, mine doesn't change at all. get it back to stock and see but make accurate comparison. it takes me less than 10min. to change intake
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
      04-21-2015, 11:11 AM   #62
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
Often people subconsciously drive the car harder with new performance parts on their car, killing mileage. Could this be you?
      04-21-2015, 11:11 AM   #63
bimmerillini95
Lol no mate been going eco pro actually these few days.
      04-21-2015, 11:48 AM   #64
bimmerillini95
Just to make sure, battery reset is by disconnecting then reconnecting the black cable on your battery at the trunk of the car right? Or do i have to disconnect both black and red?
      04-21-2015, 12:29 PM   #65
rustyminded
248
Drives: BMW 328i
just negative one & leave it for 15 to 20 min. & don't ever close trunk while battery is disconnected
      04-21-2015, 09:40 PM   #66
f30luxline
e92 - 335i
Most auto parts stores should have them. I bought mine from O'Reilly's. Here's some from AutoZone
Nylon Rivets
I never had to do this when adding an intake. Shouldn't be necessary. The only way I see this possibly being necessary is if the install was performed with the car on and even so shouldn't be required.
Nothing with adding an intake should cause poor mileage, even if if wasn't installed correctly.
However; if the MAF sensor was damaged this would send false reading possibly causing the motor to run rich.
I agree, first step of diagnoses would be returning to stock.
