01-30-2014, 12:24 AM | #1 |
Rep 68
Drives: 2013 F30 328i
2014 328 Enhanced sound, retrofit?
Hi guys
With all the talk of 2014 328's having a better engine sound, is the consensus that it is coming through the radio? If so, has anybody checked if there is an extra module in the car that is making it possible? Would really like to see if it can be retrofitted. |
01-30-2014, 12:45 AM | #2 | |
Rep 260
01-30-2014, 01:00 PM | #3 | |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
On the door frame, just near the handle there are 4 small buttons that go up and down. Gently press down on the top 2 buttons for less than a millisecond. This will enable a louder engine sound. |
01-30-2014, 07:33 PM | #4 |
Rep 40,667
If it has enhanced exhaust soundtrack, it will have ASD (Active Sound Design) module in SVT.
01-30-2014, 08:01 PM | #6 |
Rep 40,667
On new M cars it is, but not any non M car that I know of:
Active Sound Design. "Behind this marketing term is a fairly simple idea. The new M5 reproduces the car's engine sound via the in-car audio system. In other word, if you're sitting inside the car you not only hear the engine coming from outside, but also an audio track of the engine based on throttle input, speed, and engine revs. As BMW puts it, this makes for better feedback as you hear exactly what the engine is doing. Another obvious benefit is that it allows to change the noise levels based on your driving behaviour as the reproduction by the audio system gets louder and more intense in Sport and Sport+ settings."
01-31-2014, 03:27 AM | #7 |
Rep 84
Any Z4 28i, 528i, 328i, M135i, 640d e.t.c
Fluffy Russian СaT
01-31-2014, 06:50 AM | #9 |
Rep 40,667
I know it is in F10 M5, F80 M3, F82 M4, and the i8, but I have never seen it mentioned in any other chassis, nor have I seen an ASD module in any on the many F30 328i's and F10 528i's I have coded.
01-31-2014, 07:32 AM | #10 |
Rep 68
So I wonder why they say 2014 328i's sound better. There are quite a few conflicting stories in the forums.
Post No 11, 15, 18 and 20 from this thread: http://www.f30post.com/forums/showthread.php?t=925545 |
01-31-2014, 07:38 AM | #11 | |
Rep 40,667
02-01-2014, 04:47 AM | #12 |
Rep 60
Drives: 2017 330i Sport
Looks like the mounting bracket but doesn't mention the ASD ecu.
http://www.realoem.com/bmw/showparts...65&fg=25&hl=21 |
02-12-2014, 01:08 PM | #13 |
Rep 84
It's ok, you'll see
Fluffy Russian СaT
02-12-2014, 01:35 PM | #14 |
Rep 40,667
I will see what exactly? Are they adding ASD modules to new non M cars now?
02-12-2014, 01:59 PM | #15 |
Rep 1,201
It could be the intake. It sounds like louder induction noise. I don't really know how to compare parts online, but if someone does, can they look up the part numbers for the intake components on the 2014? Might be a hardware retrofit to get the sound
03-19-2014, 07:55 PM | #17 |
Rep 40,667
That would be for Active Sound Design (ASD), which would require car has ASD ECU (///M Car).
03-20-2014, 09:24 PM | #19 |
Rep 40,667
I have yet to see one, but I'll be on the lookout.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 03-20-2014 at 10:34 PM.. |
03-20-2014, 10:28 PM | #20 |
Rep 260
03-21-2014, 11:03 AM | #21 |
Rep 40,667
Personally, I have no desire to have it, but for those that would, I don't see why it couldn't be retrofitted so long as their Amplifier supports it.
This is not for F30, but it should be similar. Active Sound Design.pdf
03-22-2014, 10:55 AM | #22 | |
Rep 84
I tried to change some things through coding but there was no big difference between native sound of 428 and M4 for example.
Fluffy Russian СaT
