BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 Wind-Noise Issues
      01-22-2013, 10:13 PM   #67
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Originally Posted by jsedlak View Post
I don't have a whistle, or noise that bothers me in any way. But there are two things that stick out for me when it comes to this problem...
* There is a noticeable space between door panel and B pillar where I can see door/paint.
* The door doesn't look like it sits exactly flush with the B pillar when closed. It doesn't look bad or off by a lot, but if you look in a side mirror you can notice it.
Yep mine has this, when I run my hand by the doors and body line I can feel it uneven where the doors shut line is. Basically not aligned correctly. Also the b pillar appliqué had a lot of play in them the front door b pillar did not align to the rear door appliqué. I fixed this by putting 3m double sided tape on the inside of the b pillar but this requires removal of the top corner weather strip, don't know how many people will like doing that.
FBO-PS1 and stuff
      01-22-2013, 11:53 PM   #68
Frogman
Drives: 2012 F30 328i
Me too. When closed, if I put a business card on the read end of the front door, there is a gap of about 1mm from the front of the rear door. Both the driver and passenger sides have the same 1mm offset.
If the noise is coming from the mirror, then I don't see how this gap would increase the noise.
Can you post a picture of where you put the tape and more importantly, did it reduce or eliminate the wind noise?
      01-23-2013, 06:57 PM   #69
Sladester100
Sladester100's Avatar
Drives: F30 320d & G29 M40i First Edtn
My noise appears to he coming from around the b pillar. No real whistle just general wind / road noise. Louder than my old 2007 Vauxhall Astra!
F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies
G29 M40i First EditionFrozen Orange
      01-23-2013, 07:08 PM   #70
SamGh
The Mechanic
Drives: 2016 F30, 340 MSport
that's like my symptoms too. No major whistle really but, there is a very low vol whistles sometime, I think depending on wind directions hitting the car.
Drive Fast Not Furious
      01-23-2013, 10:11 PM   #71
Frogman
Agreed. The noise is definitely louder in a cross wind. Does that mean that there's more to the noise than just the mirrors?
      01-23-2013, 10:33 PM   #72
SamGh
The Mechanic
I feel no air leak what so ever.
      01-23-2013, 11:13 PM   #73
Frogman
I don't feel any leaking air either.
      01-23-2013, 11:22 PM   #74
Tk718
Drives: 2021 m550i
I feel a draft coming in from the bottom of the driver's side door. I started noticing it when it
Got colder outside. Even if I turn up the heat the draft is noticeable. Also above 55mph there's wind noise coming in from the windshield , this is definitely not normal and this is the first car I encountered this.
      01-23-2013, 11:23 PM   #75
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
Much ado about nothing.
F30 Sapphire Black M-Sport 335i 6MT
      01-24-2013, 12:29 PM   #76
kcidymkcus321
Drives: 2013 328i
I have the wind noise issue as well, we noticed it the very night we picked up the car...it is very annoying and to have this on a $50K car is not good!
I just dropped it off at the dealership today for this issue...thanks to this thread I told them to not mess with any seals or replace the windshield, i just want this issue noted and see if what the resolution is in PUMA, and to call me before any work is done on the car with the proposed solution...no call yet.
I am not happy that this is happening on many other F30s because that means I have an issue that is not easily resolved...if there even is a resolution for it. I prefer them not mess with the windshield, sunroof, seals, etc until they determine what the exact cause is...
I am waiting for Feb 1 to see if the new mirror caps resolve the issue as a previous poster mentioned he will update us on Feb 1 after he gets them installed...
And for everyone saying just turn up the radio, I shouldnt have to turn the radio up to avoid hearing a noise that shouldnt be there in the first place. If I have the volume low, I can still hear it and it is annoying as fkuc!
      01-26-2013, 03:23 PM   #77
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
Whistling sound resolved...
Took my car into the dealer to have the ASS re-code and to check a whistling sound coming from the passenger side A-pillar area when driving at highway speeds. Got the re-code done and the whistle resolved. It was the windshield side trim that was not tightly attached and would let air through a small gap hence the whistle. Attached is the technician's notes and a picture of the windshield trim.
      01-27-2013, 06:54 PM   #78
kcidymkcus321
Drives: 2013 328i
The post above is absolutely correct!!!
My dealership came to the same exact conclusions and notes on the paperwork match!! I just did not have time to take the picture and post the results just yet as I was busy with Gasperilla and the pirates invading Tampa...
But a resolution has been found and I am estatic!
      01-27-2013, 07:26 PM   #79
SamGh
The Mechanic
This is not the same as what I or others are talking about. This is a whistle noise at high speeds. We have the wind noise at 55 mphs.
      01-28-2013, 07:49 PM   #80
kcidymkcus321
Drives: 2013 328i
Mine started at about 50 - 60 miles an hour...it might be several different causes because in this exact thread one person said replacing the windshield worked, another said adjusting the sun roof worked, and for two of us replacing the windshield side trim solved the issue...just my two cents
      01-28-2013, 11:14 PM   #81
henryeeex
Drives: 2013 335i
You still have "Wind-Noise" at 50-60mph after your "fix"?
      01-29-2013, 04:36 PM   #82
kcidymkcus321
Drives: 2013 328i
Cool
No, thats when the wind noise would start...since the "fix", no wind noise at all!
Sorry for the confusion.
      02-01-2013, 05:53 AM   #83
EJIB
Drives: F30 Luxury 18D 143 BHP 320NM
Originally Posted by 328inGE View Post
So while I was in the dealership getting my windshield wipers problem fixed, I mentioned that the wind noise was excessive at higher speeds. my dealer contacted BMW HQ and was told to order new mirror covers. Seems there is a design change after all. I wont get them installed until 1 Feb but I will post back if I hear any improvement.
Kean to know if changing mirrors solve the wind noise issue. Any feedback yet ? As stated by some other members, I also have the impression the problem is even higher with cross winds. Also found a Malaysian wind deflector vendor offering sets for the F30. Any thoughts on that ? I hope mirror covers improve the problem before actually thinking of window deflectors......
      02-01-2013, 07:04 AM   #84
EJIB
This is what I found .... http://venttec.com.my/ViewCatalog.as...owId=9&Sortid=
      02-01-2013, 09:30 AM   #85
alex_msu
Drives: 2016 535i M-Sport
Si B51 22 12
SI B51 22 12
Body Equipment
This Service Information bulletin supersedes SI B5122 12 dated June 2012.
designates changes to this revision
SUBJECT
Wind Noise from Front Door Window Seal by Side Mirror
MODEL
F30
From start of production (SOP) to June 2012
SITUATION
The front window may have wind noise by the side mirror when driving.
CAUSE
The window guide seal is not properly fitted to thedoor.
PROCEDURE
With the window closed, confirm the location of thedeformed (folded-in) window guide seal near the mirror
triangle, and then proceed to the next step.
1. On the affected front door, check
both sides of the seal and locate
the folded-in area.
2. This close-up shows the folded-in seal area. Insert a narrow
nylon tool from above the fold
and between the window glass
and seal. Gently work the tool
downward, and pry the seal
outward to eliminate the folded
area.
3. Confirm that both the inside and
outside of the front window glass
are parallel to the seal and
uniform with no folds. The
window must remain closed for a
minimum of two hours for the
seal to “learn” the new position
      02-01-2013, 11:19 AM   #86
Frogman
Originally Posted by alex_msu View Post
SI B51 22 12
Body Equipment
SUBJECT
MODEL
F30
SITUATION
CAUSE
PROCEDURE
the folded-in area.
area.
Can you include the mentioned pictures too?
      02-01-2013, 11:50 AM   #87
alex_msu
Here you go.
      02-08-2013, 01:54 PM   #88
hav2flynow
Drives: 2013 Mineral White 328i Sport
OK Guy's..***MY Whistle is FIXED*** Mine was the Left Drip Moulding. Removed and Replaced.. NOISE IS GONE!!!!!!
noise, wind noise, wind-noise, windnoise
