10-22-2014, 03:23 PM | #133 | |
Rep 1,892
FlorinQCK-2.50 |
10-23-2014, 03:54 PM | #134 | |
Rep 30
help
FlorinQCK-2.50 |
10-23-2014, 05:07 PM | #135 | |
Rep 16
In fact, you can delete the subfolders (2014, 2015 etc.) and edit the FSC.BAT on your own by using the Windows Editor e.g. ECHO OFF CLS IF NOT EXIST fsc.exe ECHO File fsc.exe NOT FOUND ! IF NOT EXIST a.hex ECHO a.hex does NOT EXIST ! c:\EC-APPS\fsc a.hex 0x28 0x05 > code.txt IF EXIST a.hex DEL a.hex IF %ERRORLEVEL% EQU 0 ECHO File code.txt was created successfuly! PAUSE |
FlorinQCK-2.50 |
10-30-2014, 03:55 PM | #136 |
Rep 10
I've tried to update the maps (Europe Next 2014-2), but it doesn't seem to recognize my usb content, at least it doesn't prompt me for the map update/nothing happens.
Any tips? I've formatted a 32gb usb drive with FAT32 and placed "NAVD_000014B9_255_001_048" in root folder. |
FlorinQCK-2.50 |
10-30-2014, 03:57 PM | #137 |
Rep 41,031
Cannot have NAVD_000014B9_255_001_048 folder on USB Drive. Take only what is inside the NAVD_000014B9_255_001_048 folder and copy to USB Drive, but not the folder itself.
FlorinQCK-2.50 |
11-04-2014, 03:52 PM | #139 |
Rep 986
thank you
Thank you shawnsheridan and frogman
I was able to use E-Sys w/ ENET cable on Win7 64-bit laptop, extract Binary DE file, and use NBT.exe with native binary DE file and 0xA8 and 0x06 parameters for my FSC code of 2015 NEXT maps! Now I am just waiting for a 32gb flash drive to install it, but the hard part is done! Thanks again. |
FlorinQCK-2.50 |
11-07-2014, 03:28 PM | #140 | |
207
Rep 668
Thanks |
FlorinQCK-2.50 |
11-07-2014, 05:12 PM | #141 | |
Rep 1,894
If your stilling having issues PM your DE file and what map your trying to upgrade to. |
FlorinQCK-2.50 |
11-08-2014, 08:27 AM | #143 |
Rep 41,031
Incorrect. It has nothing to do with F22, and it not asking for an FSC Code this first time is only a one-time thing. The car was built late enough in the year, that even though it shipped with an older map installed, BMW AG loaded the following Map Release FSC Code in head unit, so it did not ask for FSC Code for new map as it already had it.
FlorinQCK-2.50 |
11-08-2014, 08:55 AM | #145 |
Rep 41,031
You need to update again, as Europe Next 2015-1 was released 2 days ago.
FlorinQCK-2.50 |
11-08-2014, 11:26 AM | #147 |
Rep 41,031
It is a common practice of theirs to load newer map FSC Code on new car's produced late in the year, so their customers are not complaining that the moment they buy a new $40k plus car, they also have to buy a Map Update.
FlorinQCK-2.50 |
11-08-2014, 03:51 PM | #149 |
Rep 1,894
Hi all,
If anyone has followed my post for updating maps via the DE/1B on http://f30.bimmerpost.com/forums/sho...&postcount=110 I've just upgraded my Europe NEXT 2014-2 maps to Europe NEXT 2015-1 using the above method. You will need to add the following entry to the Lookup.xml file in the Tools directory. <SgbmId id="NAVD_000014B9_255_002_181" SWID_FscShort="00A90006” name="Road Map EUROPE Next 2015-1” supplier="NTQ" sop="01.11.2014" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> I just followed the xml pattern from 2014-2, it's working for me. Good luck all. |
FlorinQCK-2.50 |
11-09-2014, 12:41 PM | #150 |
Rep 706
I'm struggling here to get the FSC code for my 2015-1 Europe NEXT Maps.
I have my DE file and saved as F708293_000DE001.fsc Have tried to use the FSC code that was generated using the following steps but car is saying incorrect code, have tried 0x06, 0x07, 0x09..... Steps: 1. open fsc.bat file with editor and look for line with 'c:\EC-APPS\fsc a.hex 0x28 0x06 > code.txt' ensure 0x28 0x06 is correct for region and year; 0x28 = Europe and 0x07 = 2015 2. open 'b64dec.exe' 3. Load 'FF708293_000DE001.fsc' 4. Save to file 'a.hex' (press search button to save) 5. Press 'decode' a.hex will be generated 6. Drag 'F708293_000DE001.fsc' over 'fsc.bat' with mouse. 7. Press any button Are the above steps correct? Would appreciate if someone try and generate the code for me. Have attached my 'F708293_000DE001.fsc' file (change extension pdf to fsc) |
FlorinQCK-2.50 |
11-09-2014, 01:43 PM | #153 |
Rep 706
I tried adding the extra lines from your previous post:
<SgbmId id="NAVD_000014B9_255_002_181" SWID_FscShort="00A90006” name="Road Map EUROPE Next 2015-1” supplier="NTQ" sop="01.11.2014" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> I got the attached error message when I tried to run the 'BMW_CIC_NBT_FSC_Generator.exe' file, any ideas where I went wrong? Have attached my lookup.xml file. (extension pdf change to xml) |
FlorinQCK-2.50 |
