08-25-2012, 04:10 PM | #23 |
Rep 710
Here's the exhaust and actuator. There's a golf-tee method posted in this forum section.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi |
08-25-2012, 04:11 PM | #24 | |
Rep 5,803
wonder how hard it is to fix it in the open position. Nice picks, thx! what did you do to prevent the flap from flapping around?
F30 330i Alpine white/Coral red Msport 6MT
08-25-2012, 04:15 PM | #25 |
Rep 710
OMG, with it wired open (aka golf tee) it sounds like magic. Makes the hair on my neck stand up thinking about it. Turns heads everywhere. Idles like it's got 500HP. Sounds fantastic between shifts, downshifting and just backing off throttle. Jump on it and it's really sweet. A simple removal of a spring clip and some wire/vice-grips and it's wired open forever.
08-25-2012, 04:18 PM | #26 | |
Rep 5,803
Is the process the same to remove it as the stock exhaust? Is it just removing that plug with the green, purple and red wire? Hardest part for me will probably be securing the flap. Also, you have any vids? sounds epic. Thanks for all the info, really appreciate it.
08-25-2012, 04:30 PM | #27 |
Rep 710
So you don't throw a code, don't unplug. If you look at my actuator picture, you will see two opposing cylinders in-line with one mounting screw. The spring clip comes out with a pair of needle nose pliers. You'll see on the upper cylinder the wire I wrapped thru it to keep it open. This way the car does what it wants but you've kept the exhaust where you want it. Just did a lousy recording with the Blackberry and will try to upload it. Apologies in advance for the poor quality.
08-25-2012, 04:36 PM | #28 | |
Rep 5,803
And the wire you are talking about is coming out the circle on the right which i assume controls the flap...where did you attach the other end of the wire to? what kind of wire is that?
08-25-2012, 04:39 PM | #29 |
Rep 710
That's it! Spring clip goes in there. Yes, that wire is heavy guage solid wire that I wrapped around the pipe and twisted it tight with a vice-grip. Tried to post video but was denied. Will try again.
08-25-2012, 04:43 PM | #30 | |
Rep 5,803
last question lol, where do you have the rest of the wire going to(that part of the picture i can't see)?
08-25-2012, 04:45 PM | #31 |
Rep 710
Crap. Won't go. Too large a file. Looks like 500KB is max size and I got a 13MB 50-second video from the Blackberry. That won't fit in Email either. Gotta lov technology!
08-25-2012, 04:45 PM | #32 |
101
Rep 1,237
Posted this on another thread...
------------------------------------------------ Okay fellas. I finally had a day off to mess with the car a bit. Although the Golf Tee Mod is not the same as what I did, the outcome can be the same. I didn't take any pictures. Sorry. But it's quite easy to understand once you get under the car. Although disconnecting the electrical harness can leave an error embedded in the computer, it will not give you an error in iDrive. There are several ways you can do this mod. One is completely error free (at least in theory). There are 4 important components to this mod. 1. Electrical wire harness 2. Actuator that turns exhaust flap hinge 3. Clip that connects the actuator to the exhaust flap hinge 4. Exhaust flap hinge ERROR FREE METHOD (easiest) - Remove the Clip that connects the actuator and flap with some needle nose pliers. - Secure the flap with a wire of some sort in the open position. - This method will keep the actuator plugged in and working. But it will not be mechanically opening the flap. But the computer shouldn't know the difference. UNPLUG ACTUATOR - Unplug electrical wire harness from the actuator. - Secure wire harness out of the way so that it is not dangling. - Unclip Actuator with pliers. - Remove actuator all together. All you need is a 10mm socket wrench. 3 bolts. ------------------------------------------------ fshubert, I'm using your pic to explain my post. Thank you. |
08-25-2012, 04:47 PM | #33 |
Rep 710
There's someone with skills!!! Thanks Tremolo!!
08-25-2012, 04:52 PM | #34 | |
Rep 5,803
thx anyways, appreciate all the info.
08-25-2012, 04:56 PM | #35 | |
Rep 5,803
08-25-2012, 04:58 PM | #36 |
101
Rep 1,237
BTW, there are 3 bolts to the actuator but only 2 are visible in that pic. Also, even if you unplug the wire harness and remove the actuator altogether, it still will NOT throw a code. I tested this with an OBD reader. No errors on iDrive. However, I read somewhere that the dealer has a more detailed OBD reader that does show an error. Just FYI.
08-25-2012, 05:01 PM | #37 |
101
Rep 1,237
It's really up to you. Securing the flap is really the McGuyver part.... ghetto even. I used a heavy gauge copper wire and just tied it around the exhaust pipe with the wire running through the flap hinge. The flap hinge has a recess like a flat head screw. Once you get under the car and actually look at it, you'll figure it out. It's really quite simple how it works. Good luck.
08-25-2012, 05:24 PM | #38 | |
Rep 5,803
thx
08-25-2012, 06:19 PM | #39 |
Rep 710
Sure. Give me a sec.
08-25-2012, 06:37 PM | #40 |
Rep 710
Back side of earlier pic. It's a heavy duty baling wire. Run it thru the groove in the flapper stem and twist it tight. It makes sense to check it every few weeks to make sure nothing's loosened up.
08-25-2012, 06:44 PM | #41 | |
Rep 5,803
08-25-2012, 06:53 PM | #42 |
Rep 710
Yup! Twisted with a pair of vice-grips and then trimmed. I check it every week just to make sure nothing has loosened up.
08-25-2012, 07:04 PM | #43 |
Rep 5,803
Thanks bro. Looks like i know exactly what to do when my car comes to get the most from the performance exhaust. Appreciate all the advice.
08-25-2012, 07:05 PM | #44 |
Rep 710
Any time! Good luck with the new ride! It's gonna be a fantastic car!! And the stereo is nice!
