BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Fault codes 420665 & 8044B0
      02-05-2022, 04:23 AM   #1
oczko98
oczko98's Avatar
Poland
Drives: F30 328i 2012
2012 F30 328i  [10.00]
Hey,
Struggled to find anyone who has had this issue via google so thought I would ask here.
Codes;
- 420665
- 8044B0
What it could be? Everything works fine (paddle shifters, speed limiter, volume buttons, etc..).
Tried to clear the fault codes and they appeared again after a few minutes.
I have new agm (oem battery).
What can I do next?
      03-16-2024, 12:41 PM   #2
drhome
drhome's Avatar
Poland
Drives: F30
Arrow
Hey, I had the same problem and same error codes. What's even funnier paddle shifters worked a bit laggy but worked well. I've found out that it might be related to a clockspring wires or even FEM which are quite expensive in comparison to just paddles.
Luckily... I've replaced just the paddle shifters (both) after that I've cleared errors and tested it for a while everything works perfectly fine. Error codes never came back
P.s. Before airbag removal disconnect the battery and keep in mind that airbag removal itself is a pain in the a** especially if you've never did that, so Good luck!
