BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 Coilovers Options - Comprehensive Overview
      05-27-2013, 08:39 AM   #111
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
Originally Posted by AMJAM View Post
Does anyone sell BC Coilovers and Swift Springs? Seems like the ideal combination
We do.
      05-29-2013, 01:37 AM   #112
AMJAM
AMJAM's Avatar
Australia
33
Drives: 2013 Alpine 328I MSport
Pm'd
2013 Alpine White 328I M Sport ARRIVED
      07-13-2013, 02:59 AM   #113
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
Does Swift make a full coilover for BMWs? Are they planning to make it for F30?
      07-17-2013, 04:21 AM   #114
Presario
Presario's Avatar
Drives: 2018 X3 M40i, 2016 435 GC
Originally Posted by Number View Post
Here is the review of the KW V2.
PROS:
- Ride comfort is infinitely better than H&R with stock springs. Due to the increase in shock travel length and adjustable damping. These are my damping settings. Rear: 3 clicks from softest. Front: 1 click from softest. The ride is similar to a stock Sport Line but you do feel the road more.
- NO MORE bottoming out on tiny bumps! Woo!
- The damping and height is easy for the front. You do have to take the wheel off to raise/lower it, but you can twist it by hand.
CONS:
- Rear damping is idiotically difficult to adjust. You can't adjust the damping like the older models from the trunk. You have to unbolt the top hat to even reach the top of the strut. Luckily this is not too difficult to do.
- Adjusting the ride height is even more idiotic. The spaner that is provided turns the perch AND the coil top. So basically, you're going no where. Later this week, I'm going to McGuyver a remedy.
Don't know if you already figured out an easy way of adjusting the rear ride height yet, but my set of ST coilovers (rehoused KW's) on my Audi provided the same challenge. I figured out an easy solution.
Use a socket wrench and pick up a 10" extension and a 10MM hex socket. Pics of tool below.
Insert the tool from underneath the rear springs (through the opening), all the way up until it reaches the coil top. The coil top has a 10mm hex opening which will mate with the tool.
Here's the trick. You can either:
1) Hold the tool in place, which will lock the coil top from turning, and use the spanner to turn the perch to adjust the height.
2) do the opposite. Hold the spanner and perch in place and turn the socket tool. I find this method to be easier if you're underneath the car.
Hope that helps.
F36 435i * MINERAL GREY * ///M Performance | G01 X3 * PHYTONIC BLUE * ///M40i
      07-18-2013, 12:52 AM   #115
ƒ°
ƒ°'s Avatar
101
Drives: ✚
Hope that helps.
Thank you for the explanation and photos. But I already stumbled upon this trick as I searched the internet to find a solution. Coincidentally it was another Audi owner that posted it. I was excited to try it until I found out that the F30 KW V2 kit did not have the hole for the hex tool anyways; the perch is just solid. I don't know if it's just a BMW thing or just the fact that I got one of the first KW kits for the F30. During my research, I've never seen a BMW owner post up this particular solution for their BMW w/ KW. Perhaps KW added the hex hole for the Audi kits?
      07-18-2013, 12:57 AM   #116
Presario
Presario's Avatar
Dang, if this really is the case, that is a horrible oversight. Can any recent owners of V2 confirm?
Also, I'm close to pulling the trigger on either the Bilstein PSS9 or CKS. If I go with the PSS9, I'll add my findings to this post.
      07-18-2013, 01:15 AM   #117
JN1
JN1's Avatar
301
Drives: S211 AMG E63
Did I just see somewhere that the Bilstein PSS9 and PSS10 have been released for F30? I can't seem to be able to find them for sale online anywhere yet.
-JustinNApproved
      09-05-2013, 07:22 PM   #118
TPYD
TPYD's Avatar
Drives: 2012 F30 335i
Hey guys, I am new to the car scene and for my first part upgrade I am considering a KW V1 Coilover. I have a 12' F30 335i with all the packages except the M pack, with this I believe I do not have the EDC function. I wanted to ask, do I purchase a KW V1 without the EDC option? if I get it installed will this affect the sport+/sport/comfort/eco pro functions in its entirety or just the suspension portion of it? Thanks in advance for your inputs!
      09-20-2013, 07:34 PM   #119
AMJAM
AMJAM's Avatar
Australia
33
BC Coilovers BR model delivered today. Booked in for a September 30 install which is killing me
      09-21-2013, 05:12 PM   #120
viperez
Drives: 320D ED
Just out of curiosity, how come nobody mentioned anything about the M performance suspension? are they not available in US?
      09-21-2013, 07:38 PM   #121
OC40
Drives: 335i MSport + MPS/MPPK
2013 MINI S  [0.00]
2013 BMW 335i  [0.00]
The MPS is not a coilover system. There is another thread (or two) on it. I'm having it installed Monday!
      09-21-2013, 07:49 PM   #122
AMJAM
AMJAM's Avatar
Australia
33
As he said ^^^^^^^^^^ it only lowers the car 10mm
      09-22-2013, 03:39 AM   #123
viperez
Drives: 320D ED
Right, I must have mixed up, there is a coilover system available from BMW itself as I recall, or is it for e90 / e92 only? It comes along with a pneumatic system on adjusting damping rate electronically.
btw... pardon if this is a noob question, my last bmw was a e46 which I sold 7 years ago
      09-22-2013, 08:03 AM   #124
OC40
2013 MINI S  [0.00]
That makes you an expert compared to me. I'm not quite sure as this is my first BMW but an OEM coilover system is definitely not available for the F30. I considered a coilover system but I opted to purchase the MPS for two reasons: (i) much less of a drop - only an additional 10mm for the MSport and (ii) OEM.
My friend has a KW coilover system installed on his X6 and loves it (he needed the additional lowering capacity!)
      09-26-2013, 02:48 PM   #125
TPYD
TPYD's Avatar
Originally Posted by Camnyc View Post
How it sits as of this am.
What's your profile/height drop? Thanks.
      09-27-2013, 11:15 AM   #126
TPYD
TPYD's Avatar
Originally Posted by RC@PSI View Post
We have a few more sets of BC Coilovers in stock for the F30s.
Let me know if I can be of assistance.
Sent you a PM
      09-27-2013, 01:24 PM   #127
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Someone needs to update this thread to include the single and double adjustable TC Kline coilovers!
      10-04-2013, 09:30 AM   #128
TC Kline Racing
TC Kline Racing's Avatar
Drives: Many BMW's & Porsche's
Agreed!!
For reference:
Single Adjustable - http://www.tcklineracing.com/webdocs...Details976.cfm
Double Adjustable - http://www.tcklineracing.com/webdocs...Details977.cfm
Thank you!
      10-25-2013, 04:21 PM   #129
chugster
B0$$
chugster's Avatar
Drives: 2020 HS M2C
Fortune Auto Coilovers
http://www.fortune-auto.net/fortune5...scoilovers.htm
Fortune auto has a set of coilovers for the f30! I am currently their beta car for the coilovers and I love these. For more info contact them directly.
Prev:
2013 AW/Coral Red 328i Sportline- Mperf. Black Grills, Mperf. exhaust, Prem. pkg, Tech pkg, Lighting pkg, Heated seats, Sports 8spd w/paddles
2016 CWP STi FBO E85
      10-25-2013, 04:22 PM   #130
Sean@PSI
Sean@PSI's Avatar
We have lots of BC Racing F30 kits in stock!
      10-27-2013, 10:12 AM   #131
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25117
Drives: '22 Chalk Gray Porsche C2S
What's the quality like on the BC kit?
      10-28-2013, 06:39 PM   #132
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Here is what the two kits look like.
More info here:
http://www.f30post.com/forums/showthread.php?t=901620
http://www.f30post.com/forums/showthread.php?t=901624
