05-10-2018, 11:07 AM | #1 |
Rep 56
Upgrade path
Since I got my 340i xDrive last September, I have been researching on several upgrades (exhaust, wheels / tires, slight lowering). On the wheel / tire / suspension side of things, which mod creates the clearest upgrade path for the rest? i.e. I would like to keep things as OEM as possible hence I'd like to keep the stock 400m wheels. I'm 100% getting rid of the RFTs (square) and moving to a staggered All-Season. Would this change my suspension options down the road? I have M-Sport package, non-adaptive suspension currently.
05-10-2018, 11:35 AM | #2 |
Rep 4,327
do you currently have the 400m in 18x8 with 225/45/18 square? if so, you will not be able to run the 225/255 staggered setup on the 18x8 +34 square wheels you have now.
if you want the 400m staggered setup as bmw offers it, you will need to obtain 400m rears which are 18x8.5 +47 with 255/40/18. with the exception of f34, any oem f3x wheel/tire combinaton will not have a problem with contacting any part of the suspension or body if you lower your car. |
05-10-2018, 01:07 PM | #4 |
Rep 4,327
05-10-2018, 01:58 PM | #6 | |
Rep 4,327
if you could provide pics of the front and back wheel/tires, from a mostly frontal view, i might be able to tell you from the wheel concavity and the stretch on the tire but it would still be difficult from a pic Last edited by alohasurftoad; 05-10-2018 at 02:08 PM.. |
05-10-2018, 03:13 PM | #7 | |
Rep 56
edit: https://f30.bimmerpost.com/forums/sh...d.php?t=592598 "M Sport comes with a choice of two wheels - the 400M 18" split spoke wheels come standard and the 403M 19" bicolor wheel are optional. Both wheels run 225 tires front and 255 tires rear." |
05-10-2018, 05:19 PM | #8 |
Rep 4,327
i believe during pre-lci (328/428/335/435) the 400m was available as 18x8 square with all seasons or 18x8, 18x8.5 staggered if you got mixed performance summer. i'm not sure how or what is offered if building nowadays as they keep changing packages and options.
you can run 245/40/18 square if you want more tread. it is the max width on 18x8. here's a member on square 18x8 397's. http://f30.bimmerpost.com/forums/sho...MMMM+new+tires |
05-11-2018, 08:45 AM | #9 |
Rep 56
https://www.carsaddiction.com/en/wheels/bmw/style-400
So it looks like the staggered 400m setup only comes on the GT models. So they make slightly different 400m rims for the rear only between the models? How can I check on my car? Tires are definitely square, all season RFTs at the moment. This is important because it will determine if I buy new wheels or not. If I can run a staggered setup on these wheels, I'll keep them. If not, I'll get new wheels and tires before the RFTs wear out. |
05-11-2018, 10:14 AM | #10 |
Rep 1,827
I have 397s on my car. Came with the same square setup (225/45R18 on 18x8). The first time I had to replace my rears, I also wanted a staggered setup so I went with 245/40R18s and haven't had any issues so just know they will fit.
However...that tire is 1.2% larger in diameter than stock. I have RWD, but I've read some things about running different sizes on xDrive and the recommended max variance. Might want to look into that first before making any decisions. Like the old adage, measure twice, cut once.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
05-14-2018, 11:28 AM | #11 |
Rep 3,622
I believe that if you have 18s and all season tires from factory then you have the narrow square setup
BMW CCA Member #516012
05-16-2018, 10:12 AM | #12 | |
Rep 56
I went to Mavis to pick a real live person's brain and the tech there wasn't the most helpful, however, he did say that if you change the wheel too much from stock it could throw off sensors in the car that relate to RPM / speedometer readings. How true is this? When I search on TireRack, can I trust that the staggered wheels I find there will fit my car perfectly? I absolutely do not want a square setup after these RFTs wear out so I have about 5k-10k miles to figure out what I wanna do. |
05-16-2018, 10:32 AM | #13 | ||
Rep 3,622
If you wanted to upsize and stagger you have two choices that I would recommend. Buy some 19inch stock wheels that ppl sell cheap here on forum when they get new wheels. Or go aftermarket F19x8.5 offset: +35 and R19x9.5 offset: +40-45 On the aftermarket wheels you have 2 options in tire size that will work best. you could go with OEM 19 sizes front 225/40/19 and rear 255/35/19 OR slightly wider 235/40/19 and 265/35/19. Both would keep wheel+tire diameter within 1% of OEM spec and work perfectly for you
05-16-2018, 10:49 AM | #14 | |
Rep 56
Secondarily, would this impact any suspension options later on? It's something I want to consider also. |
05-16-2018, 11:00 AM | #15 | ||
Rep 3,622
