05-07-2013, 12:04 PM | #3587 | |
Rep 40,633
From the Command Line, enter: regsvr32 /u "C:\EDIABAS\Hardware\ENET\MSWINSCK.OCX" regsvr32 "C:\EDIABAS\Hardware\ENET\MSWINSCK.OCX"
05-07-2013, 12:09 PM | #3588 | ||
Rep 40,633
I assume you have Option 6NL, so I would change it to 6NK and VO Code the Head Unit and Combox. The other option is to instead add K-Word TELD to your VO as an HO-Wort, and VO Code the Head Unit and Combox.
05-07-2013, 12:10 PM | #3589 |
Yr1OfD1
106
Rep 900
i think that too but i called yesterday on bmw assist and they can add another services live/internet as well for $200 a year.
05-07-2013, 12:25 PM | #3590 |
Yr1OfD1
106
Rep 900
ok i have 6NL what is the difference with NK?
05-07-2013, 12:26 PM | #3591 |
Rep 11
Newbie Q ComboMedia to allow A2DP& Office
Hello,
After some long savings, finally managed to get a June-2012 F30 with low mileage, imported from Germany ... Now, I would love to get introduced to the interesting world coding, but after reading all the different threats on this forum I'm somewhat lost. The main option I would love to have enabled, is the Office functionality and if possible BT Audio Streaming. The car is equipped with CUC, NAV Prof, Combo Media box(BN2010 BE B007),BT(S6NHA), Voice D, HUD, HK Audio, BMW Live, etc. Again what is unfortunate missing are Office and Audio Streaming. Trough a forum member already tried to enable the Office option in E-SYS. ,but this is only displays the Phone Address book. Does anyone perhaps have a good doc or a workflow how to enable/re-program the existing Combo unit and get Office & if possible BT Audio streaming? Much Appreciated Newbie M.... Last edited by mdejongh74; 05-07-2013 at 12:34 PM.. |
05-07-2013, 01:14 PM | #3592 | ||
Rep 239
EDIT, IT'S REGISTERD. I had to copy mswinsck to windows/syswow64. And then register it with cmd. Going to check if it works in the car again |
05-07-2013, 04:01 PM | #3593 | |
Rep 1,892
Since you have 6NH, you should be able to change it to 6NK and VO code the HU_CIC and CMB_MEDIA and have all of the Office functions, BT streaming (A2DP), album art, etc. I've done this on 2 F30's so far with excellent results. P.S. Please refrain from cross posting. |
05-07-2013, 05:18 PM | #3594 |
Rep 1,892
S6NKA Enhanced connection of mobile devices
S6NLA Ext. connection mob. units and telematic You get 6NL when you order BMW Assist. You get 6NK when you don't order BMW Assist, but still have enhanced BT. You get 6NH (combox) when you don't have enhanced BT, but it appears that all of the hardware is there, so changing your car from 6NH to 6NK and VO coding HU_CIC and CMB_MEDIA will enable enhanced BT. |
05-07-2013, 08:45 PM | #3595 |
Rep 735
Drives: 2013 F30 335i X-Drive MSport
Need help guys, just started coding and when trying to read FEM BODY I get an error message saying it can't find that cafd file. Any idea what's up? I'm on esys 3.22.5
05-07-2013, 09:10 PM | #3596 | ||
Rep 490
To get office, the settings are purely in COMBOX & HU_CIC, everything you need to touch to get office working is in these 2 ECU. But I got it easier by simply removing the country controller (rather than manually FDL coding many line in COMBOX & HU_CIC), but this will also remove feature/settings specific to your country, but since we're only going to VO code combox & hu_CIC it should be too bad Quote:
05-07-2013, 09:14 PM | #3597 |
Rep 304
Can confirm that this works without having the CEL light on. Works flawlessly. Thanks !
05-07-2013, 09:15 PM | #3598 | |
Rep 40,633
PM sent.
05-07-2013, 09:27 PM | #3599 |
Rep 490
05-07-2013, 09:58 PM | #3600 |
Rep 735
whats funny is that i was in that module prior and everything was fine. I was working with psdata 49.2, i made the changes, then bam, it wont even Read to generate that folder where the values are. If the new data files dont work, is there a way to just refresh the car back to stock everything and undo any damage i may have done? thanks
2013 F30 335i X-Drive / AW / CR / MSPORT / PREMIUM / TECH / HK / Heated Seats / Sport Auto / PDC / M Performance Grills and Spoiler / 20% tint (sold)
1995 Toyota Supra Single Turbo (for sale) |
05-07-2013, 10:19 PM | #3601 | |
Rep 40,633
Are you getting a [C012] Missing CAFD error or some other message? Does you FEM_BODY module show a CAFD, and is the name normal looking, or is it messed up like CAFD_FFFFFFFF_255_255_255?
05-07-2013, 10:22 PM | #3602 |
Rep 735
BINGO! Im getting that messed up cafd thing. Am i screwed?
05-07-2013, 10:26 PM | #3603 |
Rep 40,633
That changes everything.
You don't need 49.3; you corrupted your CAFD. Do this: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD from newest I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. Then you can FDL Code it (with continuous power this time).
05-07-2013, 10:28 PM | #3604 |
Rep 40,633
PM sent.
05-07-2013, 10:28 PM | #3605 | |
Rep 735
05-08-2013, 08:37 AM | #3607 |
Rep 1,130
Drives: '16 340i AW MSport
So I see from poking around there is ElectricSteering values you can change, has anyone dared to venture in there and see if they can make the steering feel tighter like an e90, adding more weight to it?? I'd love to but i'm scared :P
