      02-15-2013, 07:36 AM   #2685
BMWs
Drives: 2012 X3 35i
Originally Posted by kon View Post
Try utorrent... there are at least 10 seeders the last i checked
Thanks, I tried utorrent & qbittorrent and both no seeds I didn't change the file names except remove .pdf. Anything else I need to do?
      02-15-2013, 11:29 PM   #2686
theothernguyen
Drives: '12 Jet Black 328i Sedan
Have you tried to make sure that your torrent is properly configured to run, i.e. firewalls, ports and such? Try using the setup guide under options for utorrent. I am seeding and there are plenty of seeds going on.
      02-16-2013, 06:43 AM   #2687
BMWs
Drives: 2012 X3 35i
Thanks, was trying to download at work and firewall must have blocked it.
      02-16-2013, 09:04 AM   #2688
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Originally Posted by Frogman View Post
Make sure your clock is within a minute or two of the correct time or else the car will not sync the clock to the GPS signal.
I've coded this on 3 cars so far and we could only see it "jump" to the correct time when the clock is 1 or 2 minutes off at most.
i did and i drove across time zone few times with no change..
M Sport Line Estoril Blue
      02-16-2013, 08:26 PM   #2689
rolandleth
Drives: F30 328i
Hello guys,
Having a problem after getting 3.22 and 48.3:
When trying to access HU_CIC (honestly I haven't checked other ECUs) I get this error "error occurred while processing the est file code away.est", with this inside it "no uids within certificate", with a long list of reversed domains (com.xxx.xxx.xxx). Just like in this thread, but it's in Chinese and Google translator does a really bad job
http://www.google.ro/url?sa=t&rct=j&...42553238,d.Yms
For the record, yes I installed and configured everything properly (ODX, EST, Data folder, psdzdata, EDIABAS)
Any idea? Should I just uninstall 3.22 and put 3.18 back? I'd really like to make 3.22 work though, the loading time difference between the two is substantial; for me at least.
      02-16-2013, 10:52 PM   #2690
Frogman
Drives: 2012 F30 328i
I don't think the clock will change time zones automatically. GPS is always GMT/UTC anyway.
I think you just need to adjust the time zone setting. I'll try that tomorrow when I'm out.
      02-16-2013, 11:04 PM   #2691
Frogman
Originally Posted by rolandleth View Post
Hello guys,
First, it looks like you are trying to use 48.3 with the old Code Away EST file. That token no longer works on 48.3 on F30's.
The link you sent references using 46.3, so are you using 48.3 or 46.3? It makes a big difference.
my .est file is also 3KB, so it looks like the right size. I also see that the .est file path is padzdata, it's usually psdzdata. Is the issue simply a typo in the path name?
      02-17-2013, 05:01 AM   #2692
pixelfreak0410
Drives: Ordered: M440i Convertible RWD
Where can I get or generate a working fake VIN for activating BMW Live and Internet via Bluetooth?
      02-17-2013, 05:02 AM   #2693
rolandleth
Drives: F30 328i
I meant the error is just like in that thread, there's a screenshot of it
I had no idea est files are different, when I installed Esys 3.22 I had nothing but the executable file, so I had to take it from the Esys 3.18 archive I had lying around. Where do I get this new est file from? I downloaded the 3.22 Esys and 48.3 psdzdata from the torrent someone posted a few pages ago and there was no new est file, or I totally missed it. :S
As I said, everything is set up properly.
      02-17-2013, 08:47 AM   #2694
shawnsheridan
shawnsheridan's Avatar
PM sent.
      02-17-2013, 08:48 AM   #2695
shawnsheridan
You don't generate it. You need to find a real VIN that has factory Options 614 and 615.
      02-17-2013, 10:32 AM   #2696
kitster
Drives: G31 M Sport
Hi, I've got the following files from this thread previously - E-Sys 3.18.4 and PSDZDATA 47.7.
As pointed out to me by another forum member the PSDZDATA only works for particular firmware versions. School boy question but how do I know what version is running in my car?
      02-17-2013, 10:41 AM   #2697
RayF31
Netherlands
Drives: F31 320iA HE M-sport
ZGW_Search won't run on Win7 64-Bit properly unless it is set to run in XP SP2 Compatibly Mode. I am not sure how it behaves inside a MAC VM. In any event, it is purely informational and not needed for coding. If your LAN Adapter is getting a Class B IP Address, I would try connecting with E-Sys.
Well, I have installed a fresh copy of windows 7 32-bit in VMware fusion. Installed and configured e-sys and pszd. Bridged the virtual network adapter to ethernet, disabled USB, bluetooth, wireless, windows and mac firewall and followed all recommendations and suggestions but it still does not work.
My physical/virtual NIC adapter detects the cable, I receive a class B ip address (ZGW nevertheless remains empty) but in E-sys the connection by VIN remains greyed out and states "no ZGW available".
Can anybody confirm he can code a F3x model produced end 2012/delivered jan 2013 ?
Could it be I have a version running on my car which is not compatible with e-sys 3.18.4 and pszd 48.1 or is my cable faulty ?
I know it should work virtual (VMware fusion/Parallels) on a MacBook but I am going to arrange a laptop running windows to see what happens.
Grtz,
Ray
      02-17-2013, 11:43 AM   #2698
nidfix
Drives: M2 Competition
Grtz,
Ray
Even if you do not have the right version of file, you should still be able to connect. As having an APIPA address does not mean at all that your virtual machine is on same physical network as your car, I guess the next step is either to "snif" the network traffic from the W7 machine or to install a dhcp server on the virtual machine to verify if you can see your car requesting an IP address to your newly added DHCP server. Please note that if you set up a DHCP server on the W7 (like http://www.dhcpserver.de/dhcpsrv.htm), you will have to set a static IP address on the virtual machine interface (in any allowed private IP range - the same network will be configured for the dhcp server) and be sure to have it stopped when the virtual machine is running and your mac connected to your own LAN network (unless it may also reply to other machines on your real network...)
Good luck
      02-17-2013, 12:34 PM   #2699
awizon
Drives: 2021 BMW 540i
I have been reading this thread to get an understanding of the what software tools are necessary to recode my car (delivery sometime this week). Looking at the cheat sheet I see that the 2012 column has 'X's in a variety of colors, but nothing in the 2013 column. Is recoding a MY2013 the same as MY2012?
      02-17-2013, 01:03 PM   #2700
shawnsheridan
Connect to car, and read I-Level current:
http://www.f30post.com/forums/showpo...postcount=1403
Then cross your I-Level current to the ISTA/P:
ISTA/P 2.42.0 F020-11-07-501
ISTA/P 2.42.1 F020-11-07-503
ISTA/P 2.42.2 F020-11-07-503
ISTA/P 2.43.0 F020-11-07-503
ISTA/P 2.43.1 F020-11-07-504
ISTA/P 2.43.2 F020-11-07-504
ISTA/P 2.44.0 F020-11-11-502
ISTA/P 2.45.0 F020-11-11-502
ISTA/P 2.45.1 F020-11-11-504
ISTA/P 2.45.2 F020-11-11-505
ISTA/P 2.46.0 F020-12-03-501
ISTA/P 2.46.1 F020-12-03-503
ISTA/P 2.46.2 F020-12-03-503
ISTA/P 2.46.3 F020-12-03-503
ISTA/P 2.46.4 F020-12-03-520
ISTA/P 2.47.0 F020-12-07-530
ISTA/P 2.47.1 F020-12-07-530
ISTA/P 2.47.2 F020-12-07-530
ISTA/P 2.47.3 F020-12-07-530
ISTA/P 2.47.4 F020-12-07-532
ISTA/P 2.47.5 F020-12-07-533
ISTA/P 2.47.6 F020-12-07-533
ISTA/P 2.47.7 F020-12-07-533
ISTA/P 2.48.0 F020-12-11-502
ISTA/P 2.48.1 F020-12-11-502
ISTA/P 2.48.2 F020-12-11-504
ISTA/P 2.48.3 F020-12-11-505
      02-17-2013, 02:11 PM   #2701
shawnsheridan
All will be the same, unless the car has the new NBT iDrive, in which case HU_CIC wil be HU_NBT, and CMB_MEDIA will be built into HU_NBT (and CMB_ECALL for telematics Combox).
      02-17-2013, 02:16 PM   #2702
pixelfreak0410
Where do I find one?
      02-17-2013, 02:22 PM   #2703
awizon
NBT will first come out in '14 in the U.S. from what I have been reading. Thanks for the info on the coding.
      02-17-2013, 02:36 PM   #2704
lokito
lokito's Avatar
Puerto Rico
Drives: 335i ///M Sport
Need some assistance... I got my car last week and did some coding without problem. However, I tried to code the car to get the side mirrors to fold/unfold using the remote key but doesn't work. I don't have the Premium package with the comfort access, is that the reason why? I've set the following to "aktiv":
FEM_BODY 3110 ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
FEM_BODY 3110 ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN
Is there any other option that I have to code or any other way around it? I'm supposed to hold the Lock button for a set time? Not sure if I'm doing something wrong.
I also changed FEM_BODY 3050 FH_Tuerauf_stop_maut for uninterrupted window roll-up, but doesn't seem to work either.
Any help is much appreciated!
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      02-17-2013, 02:39 PM   #2705
shawnsheridan
It's a PIA, but I used random VIN's in www.bmwvin.com till I found one.
      02-17-2013, 06:32 PM   #2706
Frogman
For the mirror folding and windows up/down via the fob, you also have to code FEM_BODY / 3053 PwMaster / KOMFORTSCHLISSUNG_FB to aktiv (Werte=00).
Note that Werte=00 is not a typo, it's a strange one in that usually aktiv has a Werte=01 and nicht_aktiv has a werte of 00). This one does not!
Just code the function value to aktiv and leave the Werte alone and you will be fine.
I can't help you on the FEM_BODY / 3050 / FH_TUERAUF_STOP_MAUT, that only needs that one value to be changed. Note that you need to set it to nicht_aktiv (default is aktiv). You should double check that it's actually coded to nicht_aktiv by re-reading the coding data from the car.
