BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > MHD alone with PS2
      04-01-2019, 10:57 PM   #23
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Originally Posted by Munchi435i View Post
MHD currently has OTS map for EWG PS2 only.
I was trying to run the OTS PS2 map but my HPFP couldnt keep up the rail pressure on stock fueling. Currently im on a custom map through MHD and holding 16psi to redline.
Initial plan was to run stock fueling but now im considering upgrading my HPFP and LPFP to run more boost
LOG:
https://datazap.me/u/munchi/ps2-test...data=4-6-19-20
Looks great with 16psi! And load actual and target are matched perfectly Running 93AKI?
(A Dane in China)
      04-02-2019, 09:49 AM   #24
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
yes running 93 octane here in the US but most of our fuels contain about 10% ethanol.
Might add some octane booster to see how the car reacts but truthfully my setup is running strong!!
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
      04-02-2019, 08:59 PM   #25
harkes
harkes's Avatar
China
1078
Your benefit from running octane booster will be minimal. You have zero timing correction on all cyl but 6th.
I got myself in the PWG beta-program for OTS PS2 - going logging in a few hours
(A Dane in China)
      04-02-2019, 11:57 PM   #26
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Dope haven't got mine yet looking forward to yours
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles
      04-03-2019, 01:23 AM   #27
harkes
harkes's Avatar
China
1078
Not sure if MHD would want us to share beta logs so I'll refrain from that. Boost is 19.5 -> 18psi up top. Too much for my 95RON so timing is really bad. My HPFP is also having problems keeping up and is tapping out shifting into 5th. I'll turn on WMI just to test how much of an improvement that is getting me.
Suuuper smooth power delivery and no problems with WG oscillation like I have had before. This is looking very promissing
(A Dane in China)
      12-07-2023, 04:09 AM   #28
Ieside02
Drives: 08 335i 6speed
Can you explain this.. zero timing correction on all cylinders but 6..
I ask cause I run upgraded turbos with mhd stage2+ and cannot solve misfire on #6.
Wondering if there's any correlation. Tia
      12-14-2023, 08:19 AM   #29
harkes
harkes's Avatar
China
1078
Does the misfire follow the plug or coil or...?
(A Dane in China)
      03-13-2024, 11:27 PM   #30
Ieside02
No, cause I also replaced all new coils and plugs. I'm still searching for a solution. Car run good,just any WOTwill throw misfire #6
      03-13-2024, 11:36 PM   #31
Ieside02
      03-14-2024, 11:59 AM   #32
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
OK, so now if you move coil/plug from 6 to another cyl does the problem follow? New doesnt mean fixed, the plug or coil could have been damaged
