10-30-2013, 09:07 AM | #4951 | |
Rep 239
But i want to be able to open and close it with the inside button |
10-30-2013, 01:34 PM | #4952 | |
Rep 44
But then out of the nothing I found this information what I was searching for a very long time as it really annoys me that I always have to switch from 3 to 2 bars in ACC mode. I've coded it today and I can confirm: it works on F30! Thanks a lot @JesseS |
10-30-2013, 01:39 PM | #4953 |
Rep 44
Coding
Can you code BMW 1er (F20) with the F30 combo (E-Sys and PSZdata 50.4 and the individual EST)?
If so, which Type to chose in E-Sys? "F20" like for the F30? |
10-30-2013, 02:40 PM | #4954 | |
Rep 239
10-30-2013, 07:42 PM | #4955 | |
Rep 40,763
HKFM => SCH_FBD HKFM => SCH_TOEHKI HKFM => TASTER_FBD If so, set to aktiv.
10-30-2013, 07:44 PM | #4956 |
Rep 40,763
If you think its bad here, you should see my Inbox on a daily basis.
10-30-2013, 09:51 PM | #4957 |
Rep 490
10-30-2013, 10:08 PM | #4958 |
Rep 40,763
Thanks man!
10-30-2013, 11:02 PM | #4959 |
Rep 524
10-31-2013, 07:46 AM | #4960 |
Rep 34
Shawn -may I add yet another request to your in-tray?
Hi,
I've recently bought an ex-demo 328i and now I want to try out some coding changes. (Door lights, ASS etc) Could you let me have the sources for E-Sys, PSdZData + patch/token, too, please? I'd be very grateful! I'm really new to all this so I'm guessing that the latest versions (E-sys v3.23.4, PSdZData v50.4 I assume) will work on a 328i manufactured late 2012) Thanks again for any help you can offer! |
10-31-2013, 11:07 AM | #4961 | |
Rep 40,763
10-31-2013, 11:44 AM | #4962 | ||
Rep 239
11-01-2013, 09:47 AM | #4963 | |
Rep 11
Hi Shawn, I also wanna retrofit the headlights(with DRL) from halogen to xenon of 320i, could u pls share some coding guides? Thanks in advanced! FYI <?xml version="1.0" encoding="UTF-8" standalone="yes"?> <faList> <id name=""> <comment/> <ns1:fa xmlns:ns1="http://bmw.com/2005/psdz.data.fa"> <ns1:header createdBy="" date="2013-10-31+08:00" time="22:18:14" vinLong="LBV3B1409DMB22572"/> <ns1:standardFA colourCode="0300" faVersion="3" fabricCode="KCSW" series="F030" timeCriteria="0313" typeKey="3B14"> <ns1:eCodes> <ns1:eCode>A090</ns1:eCode> </ns1:eCodes> <ns1:saCodes> <ns1:saCode>1AK</ns1:saCode> <ns1:saCode>1CA</ns1:saCode> <ns1:saCode>1CB</ns1:saCode> <ns1:saCode>205</ns1:saCode> <ns1:saCode>216</ns1:saCode> <ns1:saCode>240</ns1:saCode> <ns1:saCode>249</ns1:saCode> <ns1:saCode>258</ns1:saCode> <ns1:saCode>2DV</ns1:saCode> <ns1:saCode>2PA</ns1:saCode> <ns1:saCode>302</ns1:saCode> <ns1:saCode>403</ns1:saCode> <ns1:saCode>423</ns1:saCode> <ns1:saCode>428</ns1:saCode> <ns1:saCode>431</ns1:saCode> <ns1:saCode>441</ns1:saCode> <ns1:saCode>459</ns1:saCode> <ns1:saCode>465</ns1:saCode> <ns1:saCode>493</ns1:saCode> <ns1:saCode>4CG</ns1:saCode> <ns1:saCode>4NE</ns1:saCode> <ns1:saCode>507</ns1:saCode> <ns1:saCode>520</ns1:saCode> <ns1:saCode>521</ns1:saCode> <ns1:saCode>548</ns1:saCode> <ns1:saCode>5AH</ns1:saCode> <ns1:saCode>6NH</ns1:saCode> <ns1:saCode>702</ns1:saCode> <ns1:saCode>7K2</ns1:saCode> <ns1:saCode>825</ns1:saCode> <ns1:saCode>866</ns1:saCode> <ns1:saCode>876</ns1:saCode> <ns1:saCode>892</ns1:saCode> <ns1:saCode>8AA</ns1:saCode> <ns1:saCode>8KE</ns1:saCode> <ns1:saCode>8SD</ns1:saCode> <ns1:saCode>8SM</ns1:saCode> <ns1:saCode>8TN</ns1:saCode> <ns1:saCode>993</ns1:saCode> </ns1:saCodes> <ns1:hoCodes/> </ns1:standardFA> </ns1:fa> </id> </faList> Last edited by troyleescong; 11-01-2013 at 10:05 AM.. |
11-01-2013, 11:13 AM | #4965 |
Rep 40,763
I am not sure what guide you are looking for. Once the hardware is installed and working, you should only have to add 522 to your VO and VO code FEM_BODY.
11-01-2013, 11:15 AM | #4966 |
Rep 40,763
PM sent.
11-01-2013, 01:29 PM | #4968 |
Rep 524
Was trying to code for blinking brake lights but I got an error about insufficient memory. Restarted the ESyS program but would not recognize or connect through VIN. Shut everything off, restarted and connected but when I went to read the CAFD file under FEM_BODY, got an error saying:Transaktions-Report: Aktion: Codierdaten lesen
FEM_BODY [40] [ÿÿÿÿÿÿÿ] readCPS o.k. cafd_ffffffff-255_255_255 Fehler: File for "cafd_ffffffff-255_255_255" not found! [C012] Anyway I can retrieve my original CAFD file? Also when you are changing Werte values at the bottom of the screen, how do you save them? Thank you. |
11-01-2013, 01:44 PM | #4969 | |
Rep 40,763
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE. In the upper right hand corner of the lower window where you change Werte Value, there is a Save Icon that looks like a Door with an Arrow coming out of it. Select it to save the Werte Value.
11-01-2013, 02:48 PM | #4970 | |
Rep 524
11-01-2013, 02:57 PM | #4971 | |
Rep 40,763
Repeat process for CMB_MEDIA and CMB_ECALL if you have them.
11-01-2013, 04:55 PM | #4972 | |
Rep 524
This is what I did to try to activate BMW Live and what I remembered to change back in bold to get back BMW Assist, but must still have a few settings incorrect, since it's not working: Hu_cic-3003 Telefon telematic online DUN_profile = activ PAN_Profile = activ BT_data_service = activ Online_browser = nur_bmw_internet_aktiv ONLINE_BROWSER_LIVE->aktivchange back to nonactive Online_services_gls = activchange back to nonactive Online_services = activchange back to nonactive CDMM_bt_database = activ Combox_media-3006 Telematik Sim_enabled_mb = Csimchange back to psim Combox_media-3000 General mainboard alone = mainboard alone ethernet = activchange back to nonactive If Shawn or anyone have the original settings for BMW Assist, I would appreciate feedback. Thank you. |
