BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Blue smoke on cold start and oil consumption
      03-21-2024, 05:57 PM   #1
Risay_335d
Drives: BMW 335D
Hi all
Hoping someone can advise. F30 335d , dpf is gutted and I’m getting a puff of blue smoke on cold start. It’s only on cold start and never when I start if the car is warm. Also doesn’t seem to smoke while driving
I’ve also noticed that it’s consuming oil as the oil minimum warming came up so I topped up a litre and I’ve never had that before.
Any ideas on what it could be?
Any help appreciated
      03-22-2024, 03:44 AM   #2
Eddamoo
Drives: BMW 430dX
I would say to first check the PCV system. The diaphragm can break causing liquid oil (as opposed to just vapour) to trickle into the Inlet Manifold.
Failing that - it could be Turbo Seals or Valve stem oil seals possibly.
      03-22-2024, 09:48 AM   #3
Risay_335d
Drives: BMW 335D
Thanks with the PCV is it just a visual check by taking the engine cover off?
I guess with the turbo seal or valve stems there’s no tests I can do to confirm and will need a garage
Although I thought i saw a test by letting the car idle for 5 mins then revving and if theres smoke it would indicate valve stems?
      03-29-2024, 02:40 PM   #4
Risay_335d
Drives: BMW 335D
Got my car booked in at a specialist in a few weeks so hopefully they’ll resolve.
I did scan it via bimmerlink and errors came up for 5 different injectors.
Would injectors cause similar symptoms to what I’m getting?
Appreciate any help. Thanks
