10-23-2022, 08:21 AM | #1 |
Rep 21
F30 xenon retro fit
Can anyone help me ? Iv retro fitted xenon in my f30 but carnt get the manual headlight aim adjustment to work on the wheel on light switch ...also i followed another post on the wireing modification needed but then relised it was a us version..is the uk wiring modification different ? ...
Main beam ,high beam shutter and halos currently working but have lin slave faults in ista and when i try to initiate them it error and says no communication. Any help would be much appreciated |
10-23-2022, 08:42 AM | #2 |
¯\_(ツ)_/¯
949
Rep 1,762
Why don't you just manually adjust them with the wheels on the headlights?
10-23-2022, 05:45 PM | #6 |
Rep 540
Can't help on the wiring, but a car that came with xenons from factory doesn't have the height adjuster wheel next to the light switch because it would've also had the levelling sensors fitted. I don't think it's possible to get the dial working because no car would've ever had xenons and a manual height adjuster from factory because it's something the levelling sensors should automatically handle.
Wires1661.50 |
10-24-2022, 03:05 AM | #7 |
Rep 21
Thanks Zheez much appreciated. That would explain why iam getting error with ista for the light switch not compatible ..looking like iam gona have to do switch an level sensor retrofit
