BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 F3x DIY Xenon Headlight Adjustment / Alignment
      11-20-2012, 12:50 PM   #23
TonyS
Drives: F30 335i
wait so how does one do the vertical?
I wonder if OP inadvertently did horizontal, and thus, the looked like a vertical adjustment?
As in my post just above.
      11-20-2012, 01:00 PM   #24
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
When I adjusted mine last night I noticed that as well. The inside adjustment is what adjusted the height.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      11-20-2012, 05:56 PM   #25
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
So I tried no cant see to shift the height.
Do I turn clockwise or CCW ?
Did you use a Phillips or Flat head?
It's a tight angle to get in there...
SOLD: 2012 335i Mineral Gray
      11-21-2012, 02:44 AM   #26
TonyS
Drives: F30 335i
Clockwise to raise - one turn is quite noticeable. I just used a flat head screwdriver about 6" long (excluding the handle).
      11-25-2012, 08:50 PM   #27
F30-Sport-2013
2013 328i Sport, Alpine White, w/Premium/Nav. Pkg.
F30-Sport-2013's Avatar
Drives: 2013 F30 328i Sport Alpine W.
Guys,
Just look at this video (Factory's F30 assembly line): About in the middle, (from 1:30 to 1:55) the video shows the factory technician adjusting/aligning the lights. Here is the link:
http://www.youtube.com/watch?feature...&v=HCbWSuuq1FA
Notice she's using a couple of electric drivers and the help of a computer laser guide... quite informative in my opinion. Also looks like she's using the same spots as indicated by TonyS. Additionally you can see the exact spot (screw) to adjust also the fog lights.
BTW the assembly of the front of the car in the video is just looking exactly as mine (Alpine white, Sport line, xenons).....
This week I drove my car to the dealer and they took care of the headlights (so no guessing with the screws in my case). The improvement is evident.
2013 F30 328i | Sportline | Alpine White | Leather Gray Dakota Everest | 8-speed | Navigation/HUD | Xenon Headlights | Technology & Premium | Moonroof | Anthracite Wood Trim | Heated seats
      11-30-2012, 04:22 PM   #28
nybimmer91
Drives: 320i
I can't get the black cap off the knob on the passenger side, not helped by the fact that it's in a super awkward location. Any tricks to doing it? I can't get good leverage with a screwdriver
      04-07-2013, 08:56 PM   #29
HussaMix
Drives: 320i
Same here... My headlights r aiming too low, and I can't get my cap off the knob for adjustment.. My cap is actually white.. -__- !
      04-10-2013, 03:40 PM   #30
HussaMix
Drives: 320i
Mission accomplished.. Thanks for the great well illustrated topic (y) =D
      04-10-2013, 09:26 PM   #31
shivaswrath
Drives: 2012 335i
Don't use that hole use the other one for vertical adjustment....
      05-03-2013, 03:33 PM   #32
TreDirtyFive
Drives: X3 M40i
"that's what she said"
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      05-19-2013, 06:46 PM   #33
DruNoo
Drives: 2013 328xi Melbourne Red
nice tip...thanks...
      08-24-2013, 07:02 PM   #34
Racerxy1
Drives: 2013 328i xDrive
Originally Posted by kitw View Post
Hey thanks for this! I did manage to drop one of the adjustment caps, luckily I was able to fish it out from the bottom.
The adjustment is a 6mm Allen key.
Thanks for the 6mm Allen Key info. Made life MUCH easier!!
      07-28-2014, 10:52 AM   #35
munch520
munch520's Avatar
Drives: '14 328i M Sport
Bumping this up, dealer said with lighting package/Xenons I have to get reprogrammed? My lights look a bit low, and I was hoping the adjustments in this thread would be the only fix...a reprogram for 10mm change (M performance suspension) sounds kinda nuts?
2014 M Sport
//OEM+//
      08-01-2014, 01:03 PM   #36
munch520
munch520's Avatar
Guys I just adjusted mine, super easy. I see no need to remove the plastic cap, mine has a Phillips socket in the top and rotating that with a screwdriver adjusts height.
Screwdriver length needed
2014 M Sport
//OEM+//
      08-01-2014, 02:28 PM   #37
F30EDR
Drives: Black Sapphire F30
That's not the cap everyone's talking about. It's the black colored one and only one of the two has it.
      08-01-2014, 10:29 PM   #38
munch520
munch520's Avatar
Ok so the other cap that has to be removed must be for horizontal adjustment
2014 M Sport
//OEM+//
      08-21-2014, 06:51 PM   #39
x5mad
x5mad's Avatar
Drives: iX 40
bmw  [0.00]
Mine was so low from factory. All I needed was a. Screwdriver and 2 turns and now the lighting is awesome.
      09-06-2014, 04:23 PM   #40
SOM3
Drives: SO F80
After reading this thread I have no idea which one to adjust. Are 4 series headlights different?
      09-06-2014, 05:36 PM   #41
f30GTR
f30GTR's Avatar
51
Drives: 2014 AW F30 335i M-Sport MT
That's how I feel after reading it too and I have 3 series.
      09-06-2014, 05:40 PM   #42
SOM3
Drives: SO F80
I think some of the confusion comes from horizontal vs. vertical adjustment. First of all who gives a shit about adjusting lights left to right? Second, just tell me what I need to do to move the lights up...THAT'S IT.
      09-06-2014, 06:47 PM   #43
f30GTR
f30GTR's Avatar
51
I think some of the confusion comes from horizontal vs. vertical adjustment. First of all who gives a shit about adjusting lights left to right? Second, just tell what I need to do to move the lights up...THAT'S IT.
I think problem is people are adjusting horizontal thinking it's vertical...
Original poster is wrong unless bmw changed something. But I just tried it and munch520 is correct. His pics show the correct holes.
      09-06-2014, 07:33 PM   #44
F30EDR
Try both small step at a time. Quarter turn is very noticeable. On my F30, the inner holes are for vertical aim.
