03-25-2016, 06:55 AM | #89 |
Rep 960
03-25-2016, 10:48 AM | #90 |
Rep 190,634
03-25-2016, 11:32 AM | #91 |
Rep 100
anybody else having issues with the fuel gauge hijack setting not working? I turn it on and it instantly reverts to off again? I can change the map number so im using the controls correctly.
03-25-2016, 12:39 PM | #92 |
Rep 190,634
I recommend contacting Burger Tuning technical support so they can work on this issue
03-25-2016, 02:19 PM | #93 |
Rep 100
03-26-2016, 12:21 PM | #94 |
Rep 190,634
OK good, let us know when issue is fixed
03-29-2016, 09:46 PM | #96 | |
Rep 190,634
03-29-2016, 09:48 PM | #97 |
Rep 1,733
Drives: 2003 M3
Is there an expected time frame for the completion of the beta?
03-30-2016, 07:26 AM | #99 |
Rep 265
Drives: 340i M Sport
How's the fit? Any oddities come up when installing? And lastly, can you try to get a vid?
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP |
03-30-2016, 12:13 PM | #102 |
Rep 1,782
This engine is such a savage on this tune. Holy crap! Just a smidge Unger 400whp on a stock engine. Damn when PS2,s come out this engine will be a screamer.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
03-30-2016, 03:49 PM | #103 | |||
Rep 960
The only thing that I was surprised with was actually how tight the screw was to remove. (the one that you'll use to hold the intake to the body of the car) Quote:
All-in-all, a very easy product to put in: The original is held together with 4 clips around the side and a clamp... unclip the clips, unscrew the clamp and remove the top cover. Then remove the original filter and the padding inside the box. Take the original sensor out too (held in place with 2 screws). Remove screw in chassis =) Slide the BMS intake into spot. Place screw back to hold BMS intake to chassis. Tighten 2 clamps to hold everything in place securely and finally put sensor back into BMS intake and re-secure the 2 screws holding that in place. Done |
03-31-2016, 07:40 AM | #104 |
Rep 100
No to the right of the padding in the bottom of the box is an assembly with a spring loaded flap that I needed to pull out, it just pulls straight up and out.
03-31-2016, 07:58 AM | #105 |
Rep 131
Yep, looks like a winner for bmw. Too bad we need a PS2 on our cars just to match the numbers posted here. 😔
03-31-2016, 08:40 AM | #106 |
Rep 1,782
I know :/ I would love to see the numbers once this engine gets some love fro Pure. I see the rebirth of the N54 power in this engine. Maybe even more.
03-31-2016, 08:47 AM | #107 |
Rep 131
Oh man, then it'll give the ///M boys a run for their money. Maybe the stock 340 turbo will benefit the n55, if it'll fit..???
03-31-2016, 08:51 AM | #108 |
Rep 1,782
Is the stock N55 turbo bigger than the B58 turbo?
03-31-2016, 09:19 AM | #109 |
Rep 131
03-31-2016, 09:20 AM | #110 |
Rep 1,782
Sorry I misread that. Yeah that would be interesting.
