03-29-2015, 05:44 AM | #992 |
Rep 103
Maybe something is wrong with the canbus filter? Because there is the connection for microfone and aux.
The GPS is positioned between the hvac ducts under the Monitor. Is it bad? |
03-29-2015, 05:50 AM | #994 |
Rep 103
03-29-2015, 05:56 AM | #995 |
Rep 162
I am not sure if there are differences between can filter for CIC and NBT, or if you really can use it for both.
But normaly the cables for Aux and Microphone will only be forwarded |
03-29-2015, 06:04 AM | #996 |
Rep 1,894
MIC1 are on pins 17(+ve) and 22 (-ve) and MIC2 is on Pins 18(+ve) and 19(-ve). I have the combox so I just ran new wires from the emulator to those pins. I've only done MIC1 but it is working. Will prob do MIC2 tonight.
I never bothered with AUX, just run my iPhone/USB stick via the USB. |
03-29-2015, 07:08 AM | #998 |
Rep 1,894
03-29-2015, 07:29 AM | #999 |
Rep 103
Did a spin on the motorway, still the old position from the previous car.
The gps is between the hvac ducts under the monitor. Is that a bad position? The mic still doesnt work. Hmm, I have no clue anymore. Can a firmaware upgrade remove the issues? |
03-29-2015, 08:44 AM | #1001 |
Rep 162
03-29-2015, 09:14 AM | #1002 | |
Rep 103
, maybe I try to reroute the pins from the emulator. It seems I am not lucky, GPS Antenna bad and also the emulator is not perfect. Last edited by BeatB; 03-29-2015 at 09:22 AM.. |
03-29-2015, 10:42 AM | #1004 | |
Rep 103
Im gonna try to hold it while pluging in. My gps antenna is from ebay, brand jinchanggps.com. 1575,42 Mhz. The cable is pretty long, maybe the tension (Volt) is getting too weak because of the lengh. Not sure. Which do u have? |
03-29-2015, 12:12 PM | #1006 | |
Rep 103
Anyway it works!!!!!!!!!!!!! I'm so happy, the issue was the pins popped out on the emulator, what I mentioned before. I manually pushed the pins in and now everything works microphone and navigation also. Only thing I need is a new USB connector. I don't know how to cut it manually and to rotate it. |
03-29-2015, 01:25 PM | #1008 | ||
Rep 1,894
03-29-2015, 01:32 PM | #1009 | |
Rep 1,894
1. Buy the addtional USB cable, bluetooth antenna and rewire the MICS. 2. Disconnect the combox and terminate the MOST loop. 3. Move the MOST cable over from the original quadlok to the emulator quadlok. Then just install the NBT like normal; @Terabyte mentioned earlier about moving to the CIC if you have the combox but for the little extra effort, I'd rather have the NBT. Last edited by kitster; 03-29-2015 at 01:43 PM.. |
03-29-2015, 02:30 PM | #1012 | |
Rep 103
THANKS FOR THE EFFORD FOR HELPING ME GUYS. |
