View Poll Results: What Option do you think is the best | |||
Option 1 - Amp Upgrade | 6 | 60.00% | |
Option 2 - Speaker Upgrade | 3 | 30.00% | |
Option 3 - Processing Power Upgrade | 1 | 10.00% | |
Voters: 10. You may not vote on this poll |
02-15-2014, 05:59 PM | #1 |
Code Monkey
Rep 71
Best First Step Upgrade
So I have three options please vote and then list your reason why below
Option 1 : Upgrade OEM HI-Fi Amp with JL Audio XD800/8v2 View Here Channel 1/2 Tweeters Channel 3/4 Front Mids Channel 5/6 Underset woofers Channel 7/8 rear Fill Once option 2 is done 5/6 will be bridge and 7/8 bridged to send 150 to the underset woofers. ------------------------------------------------------------------------------ Option 2 : Upgrade Speakers with Gladen's One setup. Underseta woofers for Sure might switch out the front component set for some focals or other brand but for this survey purpose this is a speaker upgrade using the factory Hi-Fi Amp 25 watts per ------------------------------------------------------------------------------ Option 3 : Processing Power Adding in an Audison Bit One. With Stock AMP and Stock Speakers. I am leaving to go in the order I listed. Upgrade amp, Upgrade speakers then upgrade Processing. Adding a Dedicated sub might fit in somewhere but for now these are the three options. |
02-17-2014, 02:04 PM | #2 |
44
Rep 208
02-17-2014, 02:16 PM | #3 |
Code Monkey
Rep 71
I had considered that as an option but then I read that you cant add in aftermarket amps. Is that true? eventually I will do all three options so I don't want to spend $800 on your speakers if I will have to replace then when I upgrade the amp. If they will work with the above amp then those will be my speakers as the plug and play is a huge plus.
