06-15-2016, 01:56 PM | #1 |
Rep 195
Brake light LED conversion
Hello,
I am looking to finish upgrading my exterior lights to LEDs, which leaves me at the brake lights. Currently I have Phillips 12356 12v 21w halogens. Has anyone changed them to LEDs without coding and modification to the bulb hole itself? Doing it on a 2014 428xi |
06-15-2016, 03:29 PM | #2 | |
Rep 312
06-15-2016, 03:58 PM | #3 |
Rep 499
Drives: 2021 X3 M40i
Coding will be required no matter if the bulbs are error free or not. LED's just don't have the resistance for the bulb checks. Coding is pretty simple to do yourself or if someone does it for you, get other things coded while you are at it.
2021 G01 X3 M40i Carbon Black Cognac Vernasca
Retired: 2013 F30 335i Glacier Silver Metallic Coral Red Dakota Retired: 2011 E90 328i Space Gray Black Dakota |
06-15-2016, 06:06 PM | #4 |
Rep 195
I've been using WeissLicht LEDs for the directionals, I already paid for someone to code once before. It is what it is I guess, just need to know which bulbs people have tried and works the best
06-16-2016, 07:47 AM | #5 |
Rep 700
I have the Weisslicht bulbs in front and rear directionals (both amber) and in the brake lights. Trying to find a red LED for the rear fog and I'll be done with the taillights
06-16-2016, 09:16 AM | #6 | |
Rep 195
06-16-2016, 11:34 AM | #8 | |
Rep 195
06-16-2016, 08:49 PM | #9 | |
Rep 700
I'm $200 for the rear brakes and turn signals, and another $100 (I think when I bought them they were $89 + $10 for shipping) for the front turn signals. |
06-17-2016, 01:22 PM | #11 |
Rep 86
Since the lenses are red, you probably want to order your bulbs in white. I've done red LED with red lenses and it was dramatically dimmer that white LED.
06-18-2016, 09:45 PM | #12 | |
Rep 700
Not with the Weisslicht bulbs, the white shines through pink. The Weisslicht bulbs are bright enough that the amber rear turn signals shine amber through the red. The brake light bulbs are along the same color as the F10 led's, but WAY brighter. |
06-20-2016, 06:33 AM | #14 |
Rep 700
I remember someone saying that the 4 series had different brake lights.
They do have the H21w listed on the site, just not in red, Last edited by Adamr916; 06-20-2016 at 06:50 AM.. |
06-20-2016, 09:16 AM | #15 |
Rep 195
Yeah, guess I'm gonna have to wait. Also don't see brake lights listed on the coding cheat sheet either
06-23-2016, 10:20 AM | #17 |
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
06-27-2016, 08:52 AM | #19 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Hi,
I have a 2014 F30 and have switched out my rear turn signals & back up lights with LEDs; for each bulb as has been stated, there are three items to change the coding. Attached is my bulb card which some may find useful. Hope that helps
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
Adam_F309.00 |
06-27-2016, 10:55 AM | #20 | |
Rep 1,076
06-27-2016, 11:10 AM | #21 |
BMW Fanatic
331
Rep 1,076
Attached a PDF. You probably can't see it because you're on the iOS-Android application.
