02-11-2015, 04:52 PM | #1 |
Rep 1,086
Swapping winter/summer tires not rims
It that possible? Instead of buying a new set of rims with snow tires + sensors? Have the same rims and only swap the rubber every season? Or that would damage the tires or cause any other unexpected issue
Just curious
2016 M3, Mineral White, SO Leather, MANUAL - ED 11/26/2015
2013 335i, Blue, M-Sport, Auto w/Sport Trans - ED 06/10/2013 |
02-11-2015, 06:15 PM | #2 |
Rep 25,989
^ This is a common practice. You shouldn't have any issues
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
02-12-2015, 02:13 AM | #3 |
Rep 487
Are you intending to use the OEM run-flats as your summer tires? I've heard that the stiff sidewall of the RFTs are easily damaged with repeated mounting/dismounting from wheels. As painful as it might be, I think the better course of action might be to invest in dedicated winter wheels/tires. Plus, you can swap them out yourself with each change of season, which makes the exorbitant expense of separate rims/tires a little more bearable.
At the same time, if someone from VMR thinks it is OK, I'd probably defer to them over me! |
02-12-2015, 02:58 AM | #4 |
Rep 5,140
How long do you plan to keep the car?
After a few seasons it would be cheaper to buy some used wheels for winter use instead of swapping the tires two times a year. The tires will hold for a number of swaps, but I would recommend doing this too many times on a single tire. |
02-12-2015, 08:12 AM | #6 | |
Rep 1,086
I expect to run another 10K this year on the original tires before December arrives, I believe that by end of the year those original tires will be almost gone, so I would imagine I have to swap the original the tires only once if that even happens, and soon it is GONE for good I will keep the winter tires on those rims for good and buy myself a nice set 19" for the summer. BTW, I'm planing to keep the car for another 5 years at least. |
