12-16-2023, 11:48 AM | #1 |
Rep 1
do I dare make my 98k mile n55 fast or wait for a lower miled car?
I have a 2015 335 with stage 1 and I love it absolutely a great car all around but if I get gapped by a c63 one more time I’m going to end it all. I obv know it’s not a fair matchup from the gate but it’s still worth a shot. Anyway is it worth getting my car into the 500s with such high mileage. I’ve done extensive/ preventative maintenance on this car and it runs like a true gem but the thought of throwing a big turbo and doing internals on it with it having 98k daunts me. I’m not in a position to get a new car atm but can spare some to build this thing the way I’d like. I have a good amount of knowledge on cars but a bit new to the bmw scene. Please enlighten me!
12-18-2023, 03:04 AM | #2 | |
2JZ-GTE
3043
Rep 3,996
This almost seems like an ChatBot response:
Altering a high-mileage car comes with its own set of risks and factors to consider. It’s important to assess the expenses involved, potential problems that might arise, and your future intentions for the vehicle. If car modifications are something you’re enthusiastic about and you have the financial means to handle the changes and any subsequent repairs, then it could be a worthwhile endeavor. However, keep in mind that pushing your car to its limits can affect its dependability. Therefore, it’s essential to strike a balance between enhancing performance and maintaining the overall health of the car, all while keeping your budget in check. Quote:
12-18-2023, 04:01 AM | #3 | |
Rep 211
12-18-2023, 08:01 AM | #4 |
Rep 797
It ends up getting really expensive. Are you going to pull the motor out or try to do everything with the block hanging in there?
Go to real OEM look through every single section and pick out the part numbers you think it needs or you would want to replace. Add them all to cart and you're going to be probably in the 2 to 5000 range somewhere. And then you got to do all the fluids and everything which is also expensive. All the little tiny gaskets and seals and hardware it just doesn't end. There's the clutch and all the driveline stuff / suspension while you have it apart. Maybe it's a good time to get some of the paint cleaned up too. It's a good opportunity to sit there and clean all of the parts. You can save on the labor if you do it yourself, but not really, as you have to spend so much on tools specialty tools and equipment that unless you do it two or three times it doesn't make sense to do it yourself. |
12-19-2023, 11:56 AM | #5 | |
Rep 7,606
Typejlb1.50 |
01-06-2024, 08:10 PM | #7 |
Rep 135
I'm in the same boat. Car just hit 100k this year and right around the same time I did chargepipe, IC, and MHD tune. Now I'm considering adding a downpipe and I want to do it right and go with Fabspeed - from what I understand, they look stock and will pass the visual test and also will not throw a CEL without a tune (I live in CA and have to do smog).
I'm debating if I should proceed with the DP, since this particular one is almost $2k... I think it boils down to the fact that I know my car is well maintained as I do most of the work myself and I'm quite meticulous, and a recent Blackstone oil analysis tells me the engine is in great shape as far as oil contaminants go. If well taken care of, these cars should go well over the 200k mile range. I'm still back and forth on the DP but so far I feel like everything else I've done has been well worth it. It's also nice to know that I'm well out of the warranty range, so that no matter what I do, there is no warranty to "void." |
01-06-2024, 09:01 PM | #8 | |
Rep 8
01-08-2024, 01:26 PM | #9 | |
Rep 7,606
01-08-2024, 01:46 PM | #10 | |
Rep 135
I've been going to my smog guy for a few years now and all he does is use a flash light to check. It would be real nice to just throw this thing on once and forget about it... very tempting, but it's such a steep price. I understand it was much more affordable back in the day. |
01-08-2024, 03:48 PM | #11 | |
Rep 7,606
Black friday does offer significant discounts on this DP usually, but that has come and gone. |
01-10-2024, 01:42 AM | #12 | |
Rep 135
I was able to get a good price from Mike at X-PH around Black Friday, but decided to hold off as I was having valve cover issues and just changed it out myself. By the way, I think you were one of the guys who said I could get the MAD Race IC in without taking the bumper off. Definitely doable, but it was a huge pain in the ass lol. Thanks for the confidence. |
01-10-2024, 12:15 PM | #13 | |
Rep 7,606
Same experience with VRSF race IC that is identical. I gave up the first night and returned the next morning to finish. |
halcyon_waves49.00 |
02-19-2024, 10:18 AM | #15 |
Rep 16,083
03-07-2024, 12:53 AM | #16 | |
Rep 1
