03-07-2024, 03:52 PM | #1 |
Rep 8
Should I do upgraded injectors during motor swap?
I recently had my b58 rebuilt with a stage 1 from p2uned (900whp capable). Should I upgrade to xtreme or Spool higher flow DI injectors now before I have the new motor put back in the car? I’m still using the stock auto transmission.
At some point if I ever blow the Trans I figure I will go ahead and upgrade to a pure stage 2 transmission and an even bigger full frame top mount turbo kit, but for now I’m hoping my tuner can just restrict my torque level to push my current big turbo and built motor only setup as far as possible without breaking anything else or throwing a ton more money and parts into the car right away. Any suggestions? My current mods are listed below: 2017 440i x-drive coupe w auto trans P2uned Stage 1 b58 engine rebuild w forged internals etc Vargas GC+ turbo kit New factory v-band clamp CTS downpipe CTS charge pipe CTS intake kit XHP transmission tune Dorch Stage 2 high pressure fuel pump Precision Raceworks Stage 3 dual low pressure fuel pump kit Vogtland springs Millway camber plates Hawk DCT-60 pads Wider wheels Wider rubber 245/35 fr and 285/30 rear Keis wireless OBD2 Adapter MHD BM3 Flex fuel kit Custom flex fuel tune |
